Question about Vtech Kidizoom Digital Camera
Changed battery won't turn on
Found daughters Kidizoom vtech camera. I changed out the batteries and now it won't turn on. We haven't used it in awhile but with brand new batteries it is dead.
    Problem Solver:
  • 5 Answers
Try inserting a tooth pick into the reset hole found just below on-off button and slightly to the left. Apparently the camera requires a reset after batteries have been changed. Our problem after resolving this problem is now the camera doesn't always stay on, i.e., turns off by itself.
Posted on Jul 23, 2010
  • Ray Sears
    Ray Sears Dec 17, 2012
    That is a feature of the camera, kids never turn off lights in the house and the same goes for their camera... Auto shut off saves our money on batteries
I fixed my sons camera. i first carefully removed the rubber 'nibs'. they conceal the 4 screws you will need to unscrew. i then opened the camera and found that one of the tint silver wires that serve as terminals to the battery was disconnected. possibly due to it being dropped. i then used a piece of polymer clay to prop it back into place. ideally, i would have soldered it back into place. it wasnt coming on at that point. i pressed reset and tried again. noth9ing. then i hooked the usb up to it with batteries installed.careful not to ground anything. i then saw the screen come on while on usb. then i unhooked usb and tried to turn it on again. and viola. it works.
Posted on Oct 24, 2011
  • mandandmatt
    mandandmatt Jun 16, 2012
    Thank you for this. I have just taken my sons camera apart and sure enough the battery wire had disconnected. Soldered it back and hey presto, it works! I'd spent ages trying to work out where the screws were, your post saved me alot of time. :-)
  • Meabh McCrystal Nov 22, 2016
    How do you take the rubber nibs off?
I have changed the batteries on my vtech kidizoom camera pressed reset button it turns on fter a while but freezes
suggestions. Different type of battery? Two different brands of battery? check the internal contacts to see that they do not have corrosion from the old ones/
Nov 09, 2013 | Vtech Kidizoom Digital Camera
How do i charge up tthe kiddizoom camera for my daughter ?? it came with a usb lead that links up to computer and one other lead to connect up to television
The Kidizoom uses four standard AA batteries. You may use disposable alkalines or rechargeables. If you choose to use rechargeables, you much charge them using a separate charger. The Kidizoom is not a battery charger.
Oct 27, 2011 | Vtech Kidizoom Digital Camera
Not sure how to charge the vtech kidizoom camera
The Kidizoom uses four standard AA batteries. The manual recommends disposable alkaline batteries. If you wish to use rechargeable batteries, they must be charged in a separate battery charger; the camera does not include charging circuitry.
You should be able to find rechargeable batteries and battery chargers at just about any department, electronics, or office-supply store.
Jan 17, 2011 | Vtech Kidizoom Digital Camera
Turns on then turn right off
Change batteries, Two phillips screws on bottom. 4aa batteries. Just happened to my daughter. Hope this helps
Dec 26, 2010 | Vtech Kidizoom Digital Camera
My daughter's Kidizoom won't turn on - I have replaced the batteries and it makes no difference - I have checked the batteries in another console and they are fine. Any ideas?
I initially thought my batteries were dead, too. Try inserting a tooth pick into the reset hole. It can be found below the on-off button and slightly to the left. Apparently after battery changes, the unit needs to be reset. This worked for me.
Jul 11, 2010 | Vtech Kidizoom Digital Camera
Camera not turning on
Try this:
1, Remove the bateries.
2, Hold down the on/off button for about 45 seconds.
3, Re-insert batteries.
4, Restart camera.
It worked for me.
Vtech Kidizoom camera. Have changed batteries but unit is not even switching on. Son has had for just over a year and it has been dropped several times.
Try cleaning the battery contacts inside the battery compartment. Do this with a cotton swab "dampened" in rubbing alcohol. You may also want to clean the battery contacts and the charging station if so equipt. Thanks, Dana
Jan 06, 2010 | Vtech Kidizoom Digital Camera
Recos for Kids Digital Camera
The battery life on my son's Vtech has been excellent. It has an automatic shut off function that keeps it from running continuosly when not in use.
Dec 30, 2008 | Vtech Kidizoom Digital Camera
Vtech Kidizoom Digital Camera Logo
5,502 people viewed this question
Top Vtech Cameras Experts
ray gallant
Tom Chichester
Are you a Vtech Camera Expert? Answer questions, earn points and help others
