Question about McCulloch 13HP 338 Cc Portable Generator # FG6000MK
The engine runs fine and the generator produces electricity but shortly after start up the generator head gets hot and starts to smoke. What could be the problem or solution? thanks jeff Joyce
    Scholar:
  • 142 Answers
If you really mean the "generator head", which I understand as the outer bearing cover of the generator, your problem may be a bad contact or worn out brush-ring assembly, or a bearing problem (not very much believable).
Posted on Jul 19, 2010
I have a Brute Force 750, starts OK but runs rough after a few minutes, will start smoking a smelly black/gray smoke, and most recently some blue smoke.
When the head gasket fails on a liquid (water) cooled engine the typical smoke colour is white (steam) and that becomes rather underlined by the steady drop of the coolant level and often clear evidence combustion gas is leaking into the cooling system.
Smelly black/grey smoke tends to be produced by an over-fuelling condition such as a stuck choke or strangler or other cold starting aid or perhaps carburettor flooding.
Blue or blue/grey smoke is invariably engine oil burning but I suggest you ignore that until the black smoke problem is rectified and after a short time the blue smoke might also disappear. If it doesn't it could be related to the overheating but the black smoke probably wasn't caused by that...
Mar 18, 2017 | Cars & Trucks
I have a 18hp kohler it starts and ruins for 5/ 10 seconds and them shuts down and there is a cloud of white smoke
Air cooled engine ok ,
When the engine shut off did it white smoke out the garden it could be the head gasket
Low compression and it won't start poor compression and it might start but run poorly stall easily and white smoke produce because of unburnt fuel escaping into hot exhausts and vaporizing
Jul 03, 2016 | Garden
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
KOHLER SMOKES STARTS UP ONLY HOT OR COLD,NO SMOKE WHEN RUNING
look down inside air cleaner before starting next time , if theres more than a finger full of motor oil in there then your head gaskets are going
May 20, 2014 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Have a 4000 watt sportsman generator that will not produce electric i have replaced the avr what next
Could be lost exciter current. This is how to restore it - Connect 16 or 18 gauge wires to a 12 volt battery. With generator running, insert bare ends of wires into AC outlet - one to Hot, the other to Neutral. Insert and remove quickly. There should be a flash and power will be restored. If not, repeat until you get that flash and output current restored. Using light gauge wires is so that if you are too slow to remove them once AC is restored. they will burn out before the battery suffers from the AC incoming. Be quick and be careful.
Mar 31, 2014 | Buffalo Tools Sportsman Series 4000 Watt...
Have an 05 turbo diesel 1kzte engine when cold its starts fine when hot also starts fine if i was to start the car and only move it a short distance say from drive into shed and leave it for some time it...
hi there my 1994 hiace van 1kz-te after 5mim,s of running start,s to run ruff goes puff puff out the exhurst and wee bitt of smoke then some time,s it Rev,s up smoke,s real. bad..and motor cut,s out hope you can help
Jan 09, 2011 | Toyota Hilux
After starting car it sputters and white smoke from exhast. I drive the car for 5 min, sputtering the whole time, and turn it off - will not start until it is cranked and gas pressed for couple min. Then...
White smoke is usually from water and water will make the car splutter. Did you get water in your tank at some time. If you have water in your fuel, you will have to drain the tank and refill with good fuel. The engine will run fine once it is hot but if a lot of water goes into a hot cylinder it can cause a lot of damage.
Apr 01, 2010 | 1998 Oldsmobile Intrigue
I have an EB6500 that was sitting for a while. When I started it it ran fine then after 3 minutes the generator head smokes and you get that electronic smell,even without turning on the main breaker.
Is that all you ran it was the one time? Sounds like a mouse. Or bugs got in there and built a nest, something just burning off. Get the air gun on that thing and blow it out, then try it again, hopefully it is just dust and dirt piled up in there.
Mar 01, 2010 | Honda Mmd 5000 Watt Electric Start...
Smoke comes from around engine
Probably a vavle cover gasket leak, small but enought to produce oil, in or on the surface of the motor doesnt take much to a lil smoke from aa hot engine...it could be collectiing in the canals ontop of the motor where the vlave covers sit on the head? or a head gasket problem....inspect it well after you run the car for a lil while, b4 it starts to smoke
May 18, 2009 | 1986 Oldsmobile Cutlass Supreme
McCulloch 13HP 338 Cc Portable Generator # FG6000MK Logo
279 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Mike
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
