Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
I have tried all of the suggestions posted and i still can't get rid of the code 90. Would a new sensor work? and how much are these?
  • 297 Answers
Have you tried cleaning out the plastic grid in front of your pump?
I would imagine you could buy a new sensor but I do not see one in the parts manual
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2009&source=intexstore&gid=2&lid=8738
I do not believe that is the problem
another suggestion is to get hold of intex
If you have a valid receipt and it is less than 2 years old they will send a new one right to your door
Just fill out the form they ask for and fax it to them
Usually in a few days you will receive it
Posted on Jul 19, 2010
Error Code P0430
this is the o2 sensor after the pre cat so post cat you can get a tune to get rid of code or replace the o2 sensor or get spacer that screws into the cat witch will make it not code the o2 sensor is there to just make sure the cat is there for emissions and will not effect the gas milage
Jul 15, 2014 | 2004 Audi TT
I bought a FreeFlow hot tub from a friend. The pump just continually runs for 15-20 seconds then shuts off. The temperature also is not rising, I can't seem to get it to work properly no matter what I do....
Thanks for your question. A hot tub is one of those items I personally do not recommend purchasing used, unless from a reputable dealer that can provide some type of warranty or service contract. I only say this because it\'s possible for them to have many many problems indiscernible to the naked eye.As for your particular hot tub, are there any error codes on the topside display? when the tub shuts off does it trip the breaker as well? it sounds as though there may be a problem with the circulation pump or possibly one or both of the heat sensors. it could also be the heater itself is not functioning properly and this is causing the system to shut off. Unfortunately, without more information, or looking at the tub I cannot tell you which of these to troubleshoot first. The only other option I can think of is to call a service technician to inspect the tub,a service call runs about $60-$90 per hour, If you could give me the error code(s) readout from the topside we could establish a starting point, otherwise we\'re just flying blind & I don\'t want you to spend money replacing parts that still work. If you can post again with an error code I\'d be glad to go from there, I\'m sorry I couldn\'t help more...
Oct 19, 2013 | Pool & Spa
I have a P0420 code happening on my kia.What does that mean?
Code P0420 is a code for Catalyst efficiency. The computer is seeing the post Catalytic converter o2 sensor having too much activity. The Cat. should be cleaning the exaust of Hc, co, and Nox. The post cat o2 will read the o2 content in the exhaust and if it moves up and down too much or to high and low, the computer interperates that as the cat not ridding the exhaust of it's pollutants. This indicates that the converter is unable to preform properly. The problem could be a bad cat, o2 sensor (Pre- and/or post cat)or o2 sensor wires, or an air fuel mixture problem that has caused the cat to fail. Many other engine operating system failures can cause the converter to not work properly
hope this helps
Apr 03, 2011 | 2002 Kia Spectra
-2006 Chevy Colorado Crew Cab - 4 Cyl. 2wd- I'm looking at trying to get rid of the check engine light that has become a nuisance. It first started when I had to get my emission tested here in Illinois....
P00017 is not a valid OBD2 fault code. I will assume it should be P0017 which is a CKP sensor signal problem, this can be caused by a defective sensor, engine issues or wiring and PCM computer problems. Follow the link for more information the CKP fault code P0017.
https://www.obd-codes.com/p0017
Mar 02, 2017 | Chevrolet Colorado Cars & Trucks
York, diamond 90 heating issues, on & off
try cleaning the flame sensor with some steel wool if not could be pcb
May 23, 2010 | Heating & Cooling
Just started our 8110 for year number 2. We are getting nothing but code 90. Tried cleaning, made sure all flow hoses were correct, check the hinge on the flow, all good. Still code 90! Went to buy a...
You problem is not the salt unit, your problem is PUMP related. You are getting good enough water flow. Check the pump as well as the filter. remove the filter cartridge and try the system without it. If the problem goes away then wash your filter and retest. If the problem comes back replace the filter cartridge. If the problem remains without the cartridge in place, you have a blockage in the plumbing which is preventing proper water flow.
Apr 03, 2010 | Intex Automatic Salt Water System for ...
Engine light codes 02-3151 and P0420
Code P0420 is a code for Catalyst efficiency. The computer is seeing the post Catalytic converter o2 sensor having too much activity. The Cat. should be cleaning the exaust of Hc, co, and Nox. The post cat o2 will read the o2 content in the exhaust and if it moves up and down too much or to high and low, the computer interperates that as the cat not ridding the exhaust of it's pollutants. This indicates that the converter is unable to preform properly. The problem could be a bad cat, o2 sensor (Pre- and/or post cat)or o2 sensor wires, or an air fuel mixture problem that has caused the cat to fail. Many other engine operating system failures can cause the converter to not work properly.
Sep 10, 2009 | 2000 Toyota Corolla
Abit AN7 motherboard does not boot - POST code AF
i think thats memory so try removing your ram and re installing it. maby its not pushed in all the way.
May 09, 2009 | Abit AN7 Motherboard
Error code 90
NO PC stated, it has a HP name, like DV6-12345,
no OS stated, XP , w7 , w8 or w10. we can not guess OS, ever.
start a post by telling the helper what is in your hands.
we cant look for you, you must tell it.
tapes, sounds , RELIC for sure...
May 08, 2017 | HP Computers & Internet
Codes for eurovox
29/03/09
5A 01
AA B7 D1 D9 CE 8E 83 AF
A1 38 06 29 24 29 8D 2B
Jan 19, 2009 | StarTech.com StarView SV211K 2-port KVM...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
93 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
