Question about Polder Swivel Head Digital Instant Read Thermometer White
When I turn it on the screen reads ll.l what does
When I turn it on the screen reads ll.l what does this mean
Instant dig read thermometer shows LL and I can't get a reading
LL means that the sensor is below the rated temp It could be a bad sensor.
Apr 11, 2017 | Home
The humidity sensor reads "LL" ... What does that mean for a gro1 digital weather station ?
Humidity value is lower then the forecaster registers , they normally go no lower then 20% . If you are getting an LL that could mean where you are located the humidity was lower then 20%
Feb 18, 2015 | Measuring Tools & Sensors
White screen
If you see the white as soon as you hit the power button (or within 5 seconds of doing so), your Motherboard is the problem, meaning that you'll have to replace the laptop. If it turns white like 10-30 seconds after you hit the power button, then it's the software, meaning that you'll have to either replace the hard drive, or reinstall the OS.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Nov 19, 2012 | ASUS K42JC-C1 Notebook
Have a dell latitude 600 d will not boot up goes right into bios mode and no modes work right back to screen windows xp thanks
Quite simple.. I've had several D600's.
You're not going to like the answer--
You OS is borked, or your hard-drive is damaged.
I'll go with the bored OS, as my D600 has survived years... What you can TRY:
Reboot the system, press F8 constantly as it turns on.. I'm mean constantly..don't stop.
1000x is okay..
It'll go into a grey screen, asking you if you want to boot into various optiosn... select, "Last known good configuration".
See if that boots. If it doesn't, do it again..select "SAFE MODE"... and you'll need to go into the recovery screen to "Restore from a previous state".
If that fails... Insert CD...reinstall OS :-(
Hope it helps.
Oct 19, 2012 | Yaesu Fc-30 Tuner For Ft-897 Ft-897d...
My Garmin depth finder/gps combo is giving me a false depth reading,like way way outta sack,not a foot or two. It came as an extra on a boat I purchased and elsewise seems ok,just inaccurate depth. Is it...
YOUR TRANSDUCER MAY BE SET FOR HORIZONTAL MODE...MEANING FROM BANK TO BOAT, NOT DEPTH...CHECK THE TRANSDUCER TO MAKE SURE, IT IS AIMING DOWN, NOT OUT...OTHERWISE YOU'LL NEED TO CHECK YOUR MODE SETTINGS IN YOUR MENU.
YOU CAN ALSO DO A TEST ON YOUR TRANSDUCER, BY SCREWING IT ONTO A BROOM STICK ...ADJUST THE TRANSDUCER DOWN, CHECK YOUR SETTINGS ON THE SCREEN, THEN DO A SIDE TEST WITH THE TRANSDUCER TILTED SIDEWAYS TOWARDS THE BANK AND CHECK YOUR SCREEN!
THEY CAN BE TRICKY...AND ARE VERY SENSITIVE, BUT ONCE YOU FIGURE OUT, HOW YOU WANT TO USE IT, YOU'LL LOVE IT!
HOPE THIS HELPS!
Sep 03, 2011 | Garmin GPS
How to change from Spanish to English
The very first 5/6 screens were in Spanish, which you have to click through before you can change the language. Somewhere on the lower right of the touch screen there's a box that probably means "yes" or something. (Above the A/B boxes - you'll see what I mean). Once you find it it's pretty straightforward. On the first screen you have to enter at least one character before you can proceed. Then you can set the date and time etc. When you get to a certain point the unit powers down. When you switch it back on you'll see some icons. Navigate your way to settings and you'll eventually see the holy light - "ENGLISH!!!!!!
Jul 24, 2011 | Nintendo DS Lite Console
What does f-03 mean?
Hi
Error F03 in Hotpoint washer means that the thermistor is open. When thermistor turns bad it will not let the water to heat or in some cases will boil the water to extreme temperatures. You’ll need to replace the thermistor to resolve this issue. The thermistor is located in the motor control unit. Inspect the element if its open circuit, it should read 1500-1800 ohms on Rx1 on the multimeter, if not then element is bad. To check/replace the element remove the lower rear panel. Hope this helps...
Daniel
Sep 01, 2010 | Hotpoint Washing Machines
Getting an F4 reading trying to turn on oven
Hi
Thanks for using FixYa. Error F4 in your range/oven means oven temperature sensor failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 02, 2010 | Amana RanARG7302 Gas Kitchen Range
F-3 is displayed on the screen when trying to bake
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 24, 2010 | Hotpoint RGB745 Gas Kitchen Range
Polder Swivel Head Digital Instant Read Thermometer White Logo
69 people viewed this question
Top Polder Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Polder Measuring Tool and Sensor Expert? Answer questions, earn points and help others
