Question about GPS
I've got a garmin E-Trex Vista CX and Mapsource software. After creating routes & waypoints (for Ben Nevis, Scafell Pike & Mount Snowdon) when I download these to the GPS unit each subsequent download deletes the previous one.The latest download is O.K. withcontour lines etc. but the other two just show the route and waypoints (n0 contour lines etc.) Help, going round the twist!!
  • robindunford Apr 22, 2008
    thanks for the advice but it doesn't work. I download the map segments then individually downroad the routes. Each new route deletes the contours on the previously downloaded route.
    Any other advice or am I just doing something stupidly wrong?
  • GPS Master
  • 638 Answers
The contours are not coming from the routes and waypoints, they are coming from the mapping software. You must load all the map segments at once to your unit. You can upload routes and waypoints separately and they will not erase the other ones already on the GPSr unit.
Posted on Apr 21, 2008
  • TO Lady Apr 26, 2008
    I don't understand what you mean by the 'contours' of the routes. Contours are lines on topo maps. If you mean you can't see the line of the route, you can only see one route at a time on the mapping page of your GPSr. You can load multiple routes onto one GPS as long as each route has a different name.
Chat session ended by mistake. I need help with getting my Garmin GPSMAP 60 CX up and running. 1. I have successfully loaded Trip and Waypoint Manager on the computer 2. I have the unit hooked up to the...
You cannot load maps to the unit using the Trip and Waypoint Manager software. That software only does what it's called - it transfers routes and waypoints. To install maps onto your GPS, you will need Mapsource, which normally comes with the maps. Once it's installed on your PC, you hook up your GPS with a mini-USB cable, choose which maps you want transferred to the unit, and then the Mapsource software will knit the map segments together and transfer them over to the unit. Hope this helps.
Jan 06, 2011 | Garmin GPSMAP 60CS GPS Receiver
How do I get Map Source and related software on a laptop in addition to my desktop? I want to be able to make route and waypoint additions away from my desk for a Garmin nuvi 265WT.
Mapsource comes on a cd and is just installed like any other program. Then you access it from the start menu. Once you make your routes or poi's you connect the nuvi with the usb cable and upload.
Oct 24, 2009 | Garmin nuvi 255W GPS Receiver
How to reroute my desination i am looking for
From browsing the manual (page 20) for your Garmin nüvi 350, it looks like you will be able to do this by creating the route in MapSource, saving it as a GPX file, and then loading it to your nuvi on an SD flash memory card.
The Nuvi 350 doesn't support custom routes. You can create waypoints (or custom POIs) for each location and manually pick waypoints as you travel, but there is no way link all the points together into a route. While you can upload a GPX file to it, it won't contain the route, just waypoints. When you pick a waypoint and tell the 350 to take you there, it's going to calculate the route based on the settings (ie, vehicle type, shortest distance, etc). It won't follow a predetermined route.
Oct 08, 2009 | Garmin nuvi 350 GPS Receiver
Unable to load coordinates for a projected waypoint
There are two ways you can load a way point.
1. Hit mark on your GPS. Push up on your rocker until the coordinates are highlighted. Once they are hit enter. From here you can change the coordinates to what ever you want.
2. If you have the software (Mapsource Trip & Waypoint Manager) you can enter the waypoint by going to "Edit" then "New Waypoint" or hit Ctrl + W as a shortcut. Once you create all the points you need, plug in your GPS and turn it on, then click "Send to Device"
Make sure that your mapsource and GPS are both setup on the same datum and lat/lon style corrdinates as well or it could throw it off.
Jan 20, 2009 | Garmin GPSMAP 60CS GPS Receiver
My Garmin Foretrex has a serial port. What software is available to download tracks and history to a PC
You can download tracks and waypoints via EasyGPS for free, or ExpertGPS or Garmin Mapsource. These programmes will transfer waypoints, tracks and routes to your PC.
If this solves your situation, please come back and rate our solution. Thankyou.
Jan 08, 2009 | Garmin eTrex Legend Cx GPS Receiver
Entering map references manually
To enter a waypoint, either use Mapsource software and transfer to the unit, or else create a waypoint and then edit it to the proper co-ordinates.
Dec 01, 2008 | Garmin eTrex Legend GPS Receiver
SD Card slot Garmin nuvii 260
I have found that waypoints, routes and directions work only when I load it on the unit itself as opposed to the SD card. The SD card works more like an expansion slot for pictures or maps.
When you open up Mapsource you'll see the map on the right and the pane on the left, above the pane there are 4 tabs (Maps, Waypoints, Routes and Tracks). As you select a map or create a waypoint, route or track. It will put a number in parenthesis which will increase in numbers as you add an item corresponding to each category, for example if you create a waypoint. So once you have done that, click on the TRANSFER tab in the Menu selection bar and choose SEND TO DEVICE. A window will pop up that will say...Device: with a drop down menu if your Garmin unit has an SD card in it, if not it will just show the Garmin unit. Then right below that there will be a section that says WHAT TO SEND with 4 check boxes that will say Maps, Waypoints, Routes and Tracks. Make sure that you have selected the Garmin unit, not the SD, and the waypoints, routes or tracks you want to send. I hope this solves your problem or at least points you in the right direction...
Jun 20, 2008 | Garmin nuvi 200W GPS Receiver
Garmin ique 3600 mapsource Synch problem with XP
Are you running Vista? If so, contact Garmin for a download that allows the maps to be loaded.
Apr 13, 2008 | Garmin iQue 3600 GPS Receiver
Street Map Program for Garmin GPSMAP 295
Detailed road map data, with addresses, hotels, gas stations, etc. can be loaded into a data-card/cartridge/memory-card using Garmin's Mapsource software such as Metroguide or City Navigator. This can be changed as needed via a PC.
The 295 does not have driving routing/guidance through the streets as most of today's GPSs have, but it will show you exactly where you are on the street (but it should be switched to Road mode).
Driving routing is possible on the PC using Mapsource, but ithe route doesn't transfer well to the 295 because of the limits on waypoints.
Nov 29, 2007 | Garmin GPSMAP 295 GPS Receiver
GPS Logo
122 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
