Question about Saeco Royal Cappuccino Espresso Machine
My machine does not deliver enough steam! I know how to pull apart and replace studd just need to know what might the problem be. I suspect the pump but don't know which pump!
  • 1 more comment
  • mortonkr Jul 19, 2010
    I will try what has been suggested and return if I have further issues! Thankyou
  • mortonkr Jul 22, 2010
    I've now pulled the pump apart and it all seems to be in good condition! I am not sure what to attack next! Do you think the flow meter is faulty?
  • 11,800 Answers
The water pump draws water out of the reservoir and pumps it into the heating chamber at high pressure. If the pump is incapable of delivering the correct amount of water you get low amount of steam.
Take both the pump and the heating element out and check for lime deposits. While you're there check the pipe between the pump and the heating element, it may have developed a kink that is blocking the flow.
Posted on Jul 19, 2010
  • 1 more comment
    Is the pum the little flat white thing? I pulled that part and it doesn't look like it could be high pressure? is there an exploded view available?
  • Azrael SRL Jul 19, 2010
    No, the white flat thing you are probably referring to is the heating element. To identify the pump is easy: find the water tank at the back and follow the line to the big valve and from there a long line to the pump. It is rectangular in appearance and golden in colour; this is how it looks like
    http://www.shop.partsguru.com/images/pro...
    From the pump a longer pipe goes to the heating element, situated almost on top of the coffee recipient - the steam pipe is getting out of it.
    Exploded diagram
    http://www.partsguru.com/user/2001-%20Ro...
  • Azrael SRL Jul 22, 2010
    It might be. The only way to know for sure it to check the entire water circuit, up to the steamer, and find the block.
Why no steam.Sunbeam 6910 cafe series. Turned on steam wand this morning and all I heard was a sigh, a feint try to deliver steam but not successful. Very little pump noise / action almost non-existent....
This could be 1 of many issues, usually the Steam pump (black or blue) is corroded and no longer vibrating correctly, the pump could be blocked, the pipe work after pump but before boiler could be blocked, the steam boiler could be blocked, the pipe work after steam boiler but before the steam tap could be blocked, the steam tap could be blocked, and also the milk nozzle could be blocked, if you feel competent to take it apart, it is easy to fix but if not take the machine to local service agent.
Feb 20, 2015 | Sunbeam Cafe EM6910
Krups KM9008 brews SLOW or not at all
If the cold water pumps from the bottom of the unit, you may have a problem with the one-way valve. Normally, this valve opens when the water is hot enough to pump up to the coffee basket, but closes to prevent the hot water from flowing back into the reservoir. If this valve is sticking, that could produce the symptoms you describe. Without actually seeing this unit, I don't know whether the valve itself can be replaced. This may require replacing the whole machine.
Jul 30, 2017 | Krups Coffee Makers & Espresso Machines
I have two machines : Machine 1: I think the
Hi
Machine 2 is the steam manifold leaking. You have to remove the hose clip in the back of the steam manifold. Remove the hose. Grab the trough in the back and pull up to expose the manifold. It will push out the front. If its white is very old, and if its black its a newer one. If its metal it is priobably the O-rings just need to be replaced. I still have the white one in my machine, because I cool the manifold off after using and that won't let it crack from the high heat after steaming. That is what causes them to crack.
Machine one, I would check under the red boot covers by the boiler for a bulge in the hoses. That is usually where they rupture. Make the new hose(tube) a little longer to prevent this from happening again.
Apr 24, 2011 | Saeco Incanto Classic Espresso Machine
Hello, My Pasquini espresso machine has stopped delivering hot water to the coffee basket. Hot water and steam are still delivered to the other outlets. I have tried this both with the coffee basket...
Hi
I would suspect that your 3 way valve is stuck. There is a copper line that goes from the top of the brew head to the right side of the machine to the 3 way valve. That 3 way valve may have to be replaced.
Oct 01, 2010 | Pasquini Livia 90 Espresso Machine
Lack of pressure from the steam wand used for frothing the milk.
Hello Juneyjune,
These coffee systems have a series of small rubber 'O' rings that tend to crack from condensation over time causing your low pressure problem.
The 'O' rings are connected to a heater that looks like a horse shoe mounted in back of the grinding unit.
I would recommend contacting Miele technical services. They can have a technician come out to replace the 'O' rings or you can order them from the technical services rep if you know someone that can replace them for you. Just be careful. These machines operate off of 220 volts and that is no fun to get shocked by. I have been many times with this machine
Good luck!!!
Sep 06, 2009 | Miele Coffee System
Same problem here
Hi If you are getting a short there are a lot of places that could cause it but I would suspect that you have a leak around your steam boiler hoses. It is located just above the main switch. Do you have any water under the machine? How old is the machine? Is it a Royal Pro?
Jun 16, 2009 | Saeco Royal Professional Espresso Machine
Ventilate warning came on and machine no longer works.
Hi The first thing that I would check is the tip of the steam wand for a plug. If that is clear then I would suspect a clogged flow meter. If you can get the flow meter out it twists apart and don't loose the parts and the dot on the turbine goes up. Clean out the small opening on the bottom pipes where the hoses attach. Look inside and make sure that they are clear before reassembling.
Mar 22, 2009 | Gaggia Syncrony Compact Coffee...
No steam or pump noise
get a used starbucks barista by saeco for a couple hundred...you'll be pleased. (know i am-and i only paid $25 for my year old breville esp8xl POS). verify it works-it will probably last longer & perform better. if inclined/capable, maybe you can replace the pump yourself (a new one's prob in $35-$40 range; if more, scrap the machine or sell it "as is" for parts & put the money toward a better machine. good luck!
Oct 07, 2008 | Breville ESP8XL Espresso Machine
Frother doesn't froth
Does not seem normal! You should get plenty of steam for the frothing. Since the unit is new you should take it back and get a replacement. The unit needs to increase the temperature for steam, route the steam away from the espresso group to the steam unit and the pump needs to activate to create the high pressure. Any failure in this areas will create your condition. It also possible that your steamer is blocked but this is a new machine so this is unlikely but you should make sure that it is not blocked.
Sep 12, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Saeco charisma will not prime. pump runs when turing steam/water knob but no water delivered out of steam tube
Try to take a bellow pump or similary and force in water in the water inlet, make sure you have the steam knob open when you do this.
Aug 06, 2008 | Saeco Caffe Charisma Espresso Machine
Saeco Royal Cappuccino Espresso Machine Logo
41 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
