Question about Saeco Magic De Luxe Espresso Machine
The far left icon is red and the temp light green. I have taken everything apart and cleaned it. Now nothing happens, at first it would make the usual noises and nothing would happen.
  • Anonymous May 05, 2008
    same
    Scholar:
  • 70 Answers
Sounds like a microswitch is out.
needs to be brought in for service. No easy way around it.
there's 3+ microswitches per unit depending on the model. They go out, red light comes on, nothing works.
Machine will have to be taken apart and all of them looked at one by one.
Posted on May 22, 2008
Greetings Gurus. I have Makita charger model DC18RC, battery model is 18v BL1815...manual is of limited help. I'm trying to understand what the indicator lights mean, what the time is for charging,
I agree that the pictographs are not very helpful. You probably have one of the new chargers. I have an old one, which is a little easier to figure out.
From top to bottom
1. The flashing green light with the electric plug indicates that the unit is plugged in and ready to go.
2. The flashing red little fan means that the battery is too warm so it is just cooling it and not charging it at that moment.
3. The solid red empty battery outline means that it is charging but hasn't got very far, less than 80% full.
4. The mostly full battery outline with both solid red and green lights at the same time means it is 80% full or more
5. The full battery outline and solid green with the musical notes means it is full up.
6. The broken battery outline with flashing red and green means you've got a broken battery.
7. The yellow light with the wrench means the charger is "conditioning" the battery, whatever that means.
8. The yellow light with the fan means "cooling abnormality."
Hope this helps
Nov 01, 2014 | Drills
Trouble with Saeco Vienna Deluxe
It sounds like you are doing everything right.
From what i have read, a lot of people have had the problem of the red light coming on and staying solid.
When they called to find out what to do they were told to clean out their machines.
I would take the whole machine apart (all of the parts you are supposed to), empty all the beans and all the water. Then try putting it all back together. Remember to prime and see what happens.
Sorry that i can't be more of a help. Others have completely taken the machine apart and emptied all the beans and water, and when they put it back together it worked for them.
If this doesn't work i would phone the company and see if its still covered under the warranty.
Good Luck
Apr 16, 2008 | Saeco Vienna De Luxe Espresso Machine
How to change red blue and green color on monitor hp7540
Press the menu button on the monitor, should be the far left button...use the minus and plus buttons to scroll thru the menu. Select the function you want by pressing the far right button (not the power). The function you want is the one witht the temp icon and the letter "K". press the far right buttion again and use the the plus and minus buttons to adjust the level.
Hope that helps.
Tom Miller
Broadcast Engineering
Sep 08, 2011 | HP Compaq FS7600 17" CRT Monitor
Camera turns on, does everything it should, but when you push the shutter button, nothing happens...
What do you have the mode selector set at? That is the knurled knob top left of camera with icons for Fully Automatic shooting (Green icon under Green word AUTO). Opposite Auto are icons for Video shooting and I would guess this where your camera is set.
Set it on Auto an try again.
May 18, 2011 | Nikon D70s Digital Camera
MY EPSOM CX 5500 WILL NOT PRINT. i HAVE A RED LIGHT PERM ON BY THE INK ICON. i HAVE TAKEN OUT THE CARTRIDGES SEVERAL TIMES AND RESTARTED BUT NOTHING HAPPENS. tHE CARTRIDGES HAVE INK AS FAR AS i...
Hello, This happens with epson as it has a chip on the cartridge, which sometimes shows the cartridge empty even if there is some ink left on it. You can try this steps:- 1. With the printer turned on press the ink replace button, which will bring the print head to ink replacement position, pull out the cartridges one by one and cover the tip of the cartridge with some tape and shake the cartridges and reinsert it on the printer and press the ink replacement button once again, the printer will check the inks cartridges, if the inks is empty it will show the red light again, pressing the button once will bring the printer to ink replacement position with the cartridge to be replaced on the replacement position. you can also check on the printer software on the pc that which ink cartridge is emptied.
Hope this helps.
May 14, 2011 | Epson CX4400/CX5600
Sony xplod amp won't work it stopped for no reason
try hooking the amp up with 3 wires, the red power wire, the black ground wire, and the remote wire, do not hook up the speakers at this time
Apr 25, 2010 | Car Audio & Video
While playing game the circle is green then lights up red
If your xbox is lighting up red on the player one and player sections( being the top left and bottome left) the problem is your xbox is overheating, u need to
a) if under warranty seek microsoft advice as your fans/cooling system may be faulty OR
b) pull apart and clean and test fans for functionabilty.Good Luck.
Nov 15, 2009 | Microsoft Xbox 360 Console
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
No lights(lits)on WLAN-No acces from the computer
WLAN light will give you the status of your wireless connection. If WLAN light is off, it might be a possibility that wireless has been turned off or worse is the device had stopped broadcasting a wireless signal. you may try using 192.168.1.1 to get into the setup page of the device to check if wireless has been disabled.
Aug 29, 2008 | Trendware TEW-630APB (TEW630APB)
Green light blinks - never goes steady
Sounds like the machine thinks it is overheating. It may be actually over heating or It might just be a bad temp sensor. It can also be the Power Control Board if not the temp sensor.
Check out www.CeriniCoffee.com for more information.
Nov 07, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
85 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
