Question about Hayward 1.5hp Max Flo Inground Pool Pump # Sp2810x15
My pump will not pump water. It runs and will pump the water that is in the resevoir but it will not pump water.
Water spits in tank but all inlets are open
It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned.
HERES HOW TO DO THAT...
Empty water resevoir. Disable auto off. Pour approx 48 oz of undiluted white vinegar into resevoir. PLace large mug on drip plate, run brew cycle, dump contents of mug in sink. DO NOT USE A K-CUP.
Repeat this process until the add water light is indicated.
Let brewer stand for at least 4 hours while still on.
Discard any residual vinegar in the resevoir and rinse thorughly.
AFTER approx 4 hours...fill resevoir with water.
RINSE:
PLace a large mug on the drip plate and water brew cycle. Pour the contents of the mug into the sink.
REPEAT this brew process until the add water light is indicated.
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste.
Jun 19, 2013 | Keurig B100 Coffee Maker
I have a Zoeller Water Ridd'r II Model 48 Sump pump. The pump comes on okay, but will nit shutoff. The float is not impededd, it's just laying on the bottom of the sump. Is this a defective...
If I undrestand your description, when the resevoir is empty, the float lays on the bottom of the resevoir but, the pump doesn't shut off, after water is pumped out? You have to look at this as opposite of a toilet tank filling with water. In a toilet, the water rises and the foat turn the water flow off. In a sump the water will rise, and the float will turnthe pump on until the resevoir is empty, then it will open the system and turn off the pump. If the float doesn't rise, the resevoir will overflow and the pump won't come on at all. If the float rises and the pump comes on but, the float does "not" drop, the pump will continue to run after the resevoir is empty.
http://www.zoellerpumps.com/ProductByCategory.aspx?CategoryID=3
This is Zoellers link. I don't see your pump but they do have a support link. If the float rises and falls with the height of the water, turns pump on, then drops "all the way" and pump doesn't turn off, the switch is bad not the float. Make sure there is nothing in the way of the float dropping to it's full down position.
Jul 03, 2011 | Home
How to change water pump
remove radiator fanbelt then water pump you will need a diagram for this, the water pump has from 4 bolts or more depending on year. the main thing is to clean!!!!! the surface good. put gasket and rtv on new pump reverse task. remember to replace coolant. run with radiator cap off but don't drive. when the themostat opens fill. turn off put cap on fill resevoir
Aug 15, 2010 | Chevrolet TrailBlazer Cars & Trucks
Water not pumping into coffee maker
Sounds like a bad pump...I would contact Keurig Customer Service if your machine is still under warranty -- they will probably send a replacement.
Apr 15, 2010 | Keurig Elite B40 Coffee Maker
Water boiling back in the resevoir after running 10 min thermostat is new and so are hoses. then car starts to run bad and shuts off.
Sounds like a plugged radiator or bad water pump, assuming the thermostat was put in correctly. If you hear a loud whining noise from the water pump when running, that's probably the problem, and it's more common than bad radiators.
Sep 28, 2009 | 1995 Dodge Neon
The Home Cafe machine will not pump water
It's dirty or has scale / deposits. Use a paper towel to draw out as much water as you can from the "hole that leads into the machine" - then fill it with clear, distilled vinegar and let that sit for about 15 minutes. Fill the resevoir with a vinegar / water mixture. After the 15 minutes, run the vinegar solution through until the resevoir is empty.
After you do that, you will have to run several tanks of water through, to get the taste / smell of vinegar out, but the machine will work fine again.
Dec 07, 2008 | Black & Decker Black&Decker Home Cafe...
Hayward 1.5hp Max Flo Inground Pool Pump # Sp2810x15 Logo
35 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
