Question about HP LaserJet 1100 Printer
Printer leaving an indented line horizontally down left side of page midway across, all the way down any thoughts on what would cause that? It almost like its being cut but not all the way through the paper.
  • 62 Answers
HORIZONTAL LINES ACROSS T644 PRINTER AND 930.00 ERROR CODE
The error code 930.00 indicates a problem in the laser print head section of the printer. This will cause error in the printouts like you are having. This type of problem is not user serviceable and will require an authorized service dealer to obtain and install the printhead assembly. This is directly from page 2-24 of the service manual.
Jul 24, 2012 | Lexmark T644 Laser Printer
Tip
When u print if u r getting the Horizontal or vertical line then follow these...
If the print is a dismal gray rather than a sharp black, you are probably almost out of toner. This can manifest itself evenly across the entire page or in splotches or stripes, depending on the printer.
Sometimes you can wring a little bit more out of a toner cartridge by taking it out and gently shaking it from side to side (never up and down, as toner can spill out). You can also try turning up the printer’s contrast adjustment, if it has such a knob (usually on the back side if it exists). Faded print can also result from a dirty corona wire, because a dirty wire inhibits a full electrical charge from being passed.
If the printouts are consistently varied in density, and you have to frequently remove the toner cartridge and shake it to redistribute the toner inside it, make sure the printer is sitting on an even, flat surface.
Horizontal black lines
A horizontal black line on the printout is probably the result of a dirty or damaged roller. There are lots of rollers in the printer, and you can use the space between the lines on the page to determine which roller is causing the problem. Measure the distance between the errant black lines on the page and then use Table A to determine which part might be causing the problem. Table A
Distance between lines
Faulty part
0.5”
Registration assembly
1.5”
Upper registration roller
1.75”
Lower registration roller
2.0”
Toner cartridge developer roller
2.56”
Lower fusing assembly roller
3.16”
Upper fusing assembly roller
3.75”
Toner cartridge photo drum
Regularly spaced splotches
If there are evenly spaced black spots but they don’t extend all the way across the page, the problem is probably a scratch or flaw in the drum or a build-up of toner on the fusing roller. If the spots are less than three inches apart vertically, it’s probably the drum, because the drum has a larger diameter than the fusing roller.
Vertical black line on edge of page
This can indicate an almost empty or faulty toner cartridge or (less frequently) some spilled toner inside the printer.
on Aug 28, 2008 | Lexmark X5470 All-In-One InkJet Printer
I have a grey/black line all the way down the right hand side of the page
Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
May 11, 2011 | HP LaserJet 1010 Printer
Pages printed with dark horizontal lines the entire length of the page with a repeating (lighter) images.
I have seen bad laser scanners cause this...
A black line across the page from left to right, of various widths, at various intervals, all the way down the page.
First, though, I would reseat the toner cartridge. If the problem disappears, you are in luck!
Try another Toner Cartridge to see if the problem disappears.
It could also be a bad control board.
Good Luck.
Nov 03, 2010 | HP LaserJet 2420 Printer
Horizontal lines and smudges across the page at 1.5" intervals down the page.
Judging from the distance between the lines, you probably have a defective cartridge. Smudges are generally caused by a defective fuser, which means it's time to send the printer out for repair.
Jan 05, 2010 | HP LaserJet 1012 Printer
Hp laserjet 4 plus - keep getting a horizontal black line
yes you have to catch printer making the line and then as a page is being printed you need to open door to stop paper after green cylinder(drum) as it is entering fuser, then you need to remove paper from printer without pulling through the fuser, if you see the line then rub your finger across line up and down page, if it smears at all then its the cartridge if not then the fuser
Apr 27, 2009 | HP LaserJet 4 plus Printer
Dell Print Quality Problems: Horizontal lines On One Side
Try running a cleaning sheet through the printer. Remove the drum and check you waste toner (if that is built-in to your drum then skip this). If that gets full, then some of the bad toner can spill out creating lines/smuges. I would also use compressed air to blow out the inside of the printer where the toner/drum goes. That will help remove anything that is left behind after a replacement.
Also, check the settings in the print server for anything that will clean the printer/correct horizontal lines.
Mar 16, 2009 | Dell 3010cn Laser Printer
Colour lines across the page
Hey Paul, Can you post a scan of the printed paper? It may help diagnose your problem. The most common cause of lines accross the page is either the PhotoConductor Unit or the 2ND BTR Assy.
Nov 30, 2006 | Epson Aculaser C1100 Printer
HP LaserJet 1100 Printer Logo
174 people viewed this question
Ben Johnson
