Question about Cameras
How do I eject memory card froa a Phillips Photo Frame???
  • jdmproperty Apr 22, 2008
    Absolutely GREAT !!!!
    THANKS FOR YOUR HELP!!!!
    John Morgan
  • 477 Answers
There is one of 3 ways to eject a memory card.
  1. push it in and once it clicks then try to pull it out.
  2. just pull it out
  3. on the side of the card there is a little push button that you will push in twice and the card comes out.
one of these should help you.
Posted on Apr 21, 2008
Pandigital Photo Frame will not read MMC card
The new card is not compatible with your photo frame. Only thing you can do is to make sure that what you use is compatible. Your manual or website will tell you the largest memory card you can use.
Aug 27, 2016 | PANDIGITAL 7" Digital Photo Frame With...
Just want to know how to transfer photos from a NOKIA Lumia 521 to the 8" Aluratek Digital Photo Frame
Try sending the photos to a cloud service on the web, then transfer to a memory card that could be inserted into the Photo Frame. If the phone has a memory card you can get an adapter to upload to a PC then back to a memory card for the Photo Frame.
May 14, 2014 | Photography
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
I have a Philips PhotoFrame - SPF3408/G7 (SPF3408T/G7). When plugged in no picture comes on screen. Screen does not light up. I viewed pictures yesterday - but - I don't get anything today. I know...
Keep in mind that Digital Photo Frame can display the same photo continuously for 1000 hours without any damage to the LCD screen.
If you can enter to the settitgn menu, first make sure the system is properly powered. Then use a pin to trigger the reset button located on the side of the power button on the back to restore the system...
If this isnt work try...
  1. Load all the photos you want to upload to the Photo Frame in the root directory of your memory card.
  2. Power off your Photo Frame by pressing the Power button.
  3. Insert the memory card into the slot in the frame.
    A For a Compact Flash card, firmly slide card in the larger slot end first and face down.
    B For an xD, SD, MMC, or Memory Stick card slide card in the smaller slot end first and face up until it locks into place.
  1. Restart Photo Frame by pressing the Power button.
  2. After a few seconds, all photos in the root directory of the memory card will be automatically added to Photo Frame. The root directory on memory card will not be emptied after this operation.
    Please do not remove the memory card just after inserting it in Photo Frame or when Photo Frame is counting the Photo.
    Wait until the screen is stable.
    NOTE: This operation does not apply to photos in sub-directories.
If anyone of this procedures work fine, I suggest contact your local service (check if even is underwarranty).
Good luck.
Jul 05, 2011 | Video Game Consoles & Games
How to remove a memory card from digital photo frame
Most Linx frames just require you to pull out the card. Grab it with your fingernails and pull. Make sure the unit is OFF before you do that.
May 22, 2009 | Pinnacle Linx USB Plus Video Capture
Phillips Photo Frame does not recognize SanDisk 1 BG SD card
I used a format program from http://www.sdcard.org/consumers/formatter/eula/
Nether Sandisk nor Phillips tells you the card needs to be formatted FIRST if it is
new and out of the package. It works fine now.......... in the Phillips Photo Frame model 8FF2FPB
If you do not format it first - your PC software WILL NOT even know it is inserted into your device!!
I need no further help on this
Thanks
JohninTexas
Dec 29, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
Where do I get a memory card?
2 GB SD card. You can get them at Wal-Mart. Most electronic stores. Camera stores or you can order them online at amazon.com.
Dec 23, 2008 | Nextar N7 - 7 Digital Photo Frame with...
I cant transfer pictures from my PC to a Digital Frame
either transfer to a usb pen or a standard digital card and then insert in photo frame good luck
Dec 20, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
I lost instructions to my Optimus 7" Digital Photo Fram
You can change out your pictures by having an XD or SD Memory cards if you have a card reader for your computer plug in the memory card put the photos on to it that u want on ur pic frame and plug it in to the xd/sd card slot on the left hand side of the photo frame and there u go. If you want ur pics off the internal memory u can transfer them from the frame to the card via the options button or menu button that is.
Nov 30, 2008 | PANDIGITAL 7-Inch Digital Photo Frame with...
Philips digital photo frame 7FFI series
Here`s a tip i found for you...
1. Connect the frame to your PC using the supplied USB connector. Navigate to the \DCIM\100Frame directory and delete all the Phillips advertising pictures there.
2. Create a directory on your PC and put copies of all the pictures you want to display there.
3. Download the free picture resizer utility from Microsoft at:
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
(Look for Image Resizer in the right column). After installing it, "Select All" pictures in the directory you created, then right click and select "Resize Pictures" from the context menu. Choose the 640x400 radio button. Sort by size and copy all the small ones into the "\DCIM\100Frame" directory on the frame drive (Called Removable Disk on my PC).
Jun 20, 2008 | Audio Players & Recorders
Cameras Logo
67 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
