Question about Bunn BT10B Coffee Maker
It is no longer brewing really hot coffee. I drained all the water out and now I am wondering how many caraffes of water to put in initally?
  • 21 Answers
Oh no. ... ok don't panic.... put in the same amount of water your coffee Caraffe holds. If the coffee maker is one of the kinds I recall, it holds water and heats it while you pour in another pot, it pushes the hot water out to fill your caraffee pot. Then you will have to add one more pot only.
When the water quits heating it is a heating element that is acting up. Sometimes the fuse finally gives up. The trick is locating and removing fuse, and replace heating element. These require a service tech to do because of soldering, and making sure the electrical parts are put back in place properly.
Posted on May 26, 2008
Why won't the hot water empty into the coffee pot?
Make sure your caraffe has its lid on , and check the bottom of the filter. it usually has a valve preventing coffee from leaking when you remove the caraffe. the lid pushes the valve back open when you place the caraffe back into the machine.
Jul 10, 2012 | Cuisinart DCC-2200 14-Cup Coffee Maker
Coffee spilling over the top , not dripping
The caraffe lid must be on the Coffee maker while making coffee.
The lid pushes a opens the hut-of valve in the filter.
If the lid is not on the caraffe, the valve will prevent coffee from dripping out of the filter.
This is to prevent coffee leaking on the lower carafe heating element when you remove the caraffe to quickly pour some coffee. the water accumulates while you do this, so if the machine is still brewing, you should put the carafe with lid back in the cofee maker, to release the accumulated liquid in the filter.
Jun 08, 2012 | Cuisinart DCC-1200 Coffee Maker
Won't brew
Run vinegar/water solution - 1/3 caraffe distilled white vinegar and 2/3 caraffe water. Let the vinegar/water solution sit in the water reservoir for up to 20 mins before you start brewing the first batch of vinegar/water solution. Run it up to 3 times - just like you would normal coffee. Then, run a caraffe of plain water and see if all is well.
If that fails, then you have a busted or damaged hose inside.
Call Cuisinart, because that one is still in warranty - you will not need a receipt or a box for that one.
-Tha Mp3 Doctor
Apr 05, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Since I cleaned our Cuisinart 12-cup Brew Central with "Dip-it"  destainer last week, it takes about 3 times longer to brew, and it steams outrageously practically the whole time.  Using the same...
Run 1/3 caraffe vinegar and 2/3 caraffe water through the machine.
Dip-It is not the best cleaner to use with this coffeemaker - stick to distilled white vinegar.
If the cleaning fails to resolve the issue, and the unit was purchased in the last 3 years, call Cuisinart and see if you are still in-warranty.
Mar 14, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
The ''clean'' light is on my cusinart coffee maker
Let a half caraffe worth of distilled white vinegar sit in the water reservoir for about an hour. After the hour, turn the coffeemaker on and let it brew the vinegar until a small amount of vinegar appears in the caraffe. turn the coffeemaker off and let it sit for an additional 20 minutes. Then turn the coffeemaker back on and let it brew the rest of the vinegar. Then run a full caraffe of plain water to flush the vinegar out. If the self-clean light remians on - unplug the coffeemaker for 20 minutes or longer - if you unplug it for any less than 15 minutes, the coffeemaker will not reset itself. You should be good after that - as long as you do some sort of vinegar/water cleaning once a month henceforth.
-Tha Mp3 Doctor
Mar 13, 2009 | Cuisinart Coffeemakers
Coffee Machine Brewing Water
Try an experiment - brew a test cup, but use only a small amount of grounds in the brew basket (use a paper filter) [or else, put the grounds in the gold tone filter basket]. See if the machine makes coffee (albeit weak coffee). If it does not make coffee, see if the water is draining properly from the brew basket, or if it is leaking over the sides of the brew basket. Also, make sure the lid to the brew basket is completely open and in the correct position.
If you still get water only in the caraffe, replace the brew basket. The part costs about $11.95 with shipping - or even call Cuisinart to see if your 3-year warranty will cover the issue.
-Tha Mp3 Doctor
Mar 03, 2009 | Cuisinart Thermal DGB-600 Grinder
Leaks everywhere
Make sure the lid is on the caraffe and just try to run plain water through. Although, it sounds like you might actually have a crack/leak. Return to store if possible or call Cuisianrt if it really is leaking.
Dec 25, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart 14-cup coffee maker won't put out coffee
Clean it out with 1/3 caraffe worht of vinegar and 2/3 caraffe full of water - just brew the solution as if it were regular coffee - you may have to repeat this process up to 3 times.
-Tha Mp3 Doctor
Dec 21, 2008 | Cuisinart DCC-2200 14-Cup Coffee Maker
Long brewing time
Clean it out with 1/3 caraffe distilled white vinegar and 2/3 caraffe water. Once it is clean, it should take the normal amount of time and will make slightly less noise since it isn't busy steaming off as much water. Also, double-check the filter basket and make sure it is not slowing down the rate of draining coffee.
Mar 21, 2008 | Cuisinart 12 Cup Digital Thermal Coffee...
Bunn BT10B Coffee Maker Logo
207 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
