Hello! i have a problem with my router. i tried to plug it on the power supply but my router doesn't turn on. It's not lighting up. i tried to plug it again and again but its not working. i wonder how can i fix this? thanks in advance
    Scholar:
  • 163 Answers
Your power supply has died. Order a new one
Posted on Jul 19, 2010
I have a belkin router it was working fine but then it just looses all power no light nothing i try to push reset but nothing there either what do i do help
No lights on router means no power coming in. Check first if you have any loose ends on the power cord. Try plugging your router to another working power outlet as well. Sometimes, electronic equipments can operate much better if plugged in directly to power outlet than to a surge protector. If all of these doesn't work, then it must be a defective router now.
Sep 11, 2011 | Belkin (F5D7230-4) Router (587009)
Dlink wifi adapter dwa 125 wireless-g USB doesn't have lights
No lights means no power, so that's not a good sign.
Can you check that it's plugged in?
Is the transformer plugged in properly?
(Obvious one: is the plug switched on?)
Can you try another power supply to see if that's the problem?
Can you try another electrical socket to see if that's the problem?
Have you another router to try with your existing power supply to see if its a dead router?
Jul 27, 2011 | D-Link DWA-125 Wireless 150 USB Adapter...
We have been using the Netgear router WPN824 for about 3 years and all of a sudden it stopped working. No flashing strobe lights - nothing. any suggestions?
Will it even power on at all ? If there are no lights at all make sure its plugged in securely. Maybe even try a different power outlet to see if the one you are using has not gone bad. If that still doesn't help then there is a chance that your router has failed. Being 3 years old it is possible. A failure can be from a power surge, storm, manufacture defect etc. In which case you will have to replace it. Sorry for the bad news.
Thank you for choosing Fixya,
Daniel
Jun 26, 2011 | NetGear RangeMax WPN824 Router
When I turn on my set, light turns green, then after 30 seconds turns red won't come on
Sounds like there is a problem with the power supply. Try unplugging the T.V. and hold the power button for 30 seconds. Plug the T.V. back in and see if that helps. If it doesn't try switching to another outlet, and if that doesn't work then you may need to replace the power supply which would probably cost anywhere from 140 to 200 for one.
May 05, 2011 | Fujitsu PlasmaVision P50XHA40US 50 in....
My linksys wireless g router will not power up,n yes I have plugged it in but no lights are comin up on the router.it was fine this mornin but turned the the plug of as I left the house come home turned...
Try to connect the router to a different outlet and try to turn it back on, if nothing happens, theres a possibility that there is something wrong with the routers power supply.
Hope this will help... Your response is very much appreciated...
Jan 26, 2011 | Linksys Computers & Internet
I have a Linksys WRT54G2 Router, It Has Worked Fine For About A Year, And Just Suddenly It Has Problems, The WLaN Light Isn't On At All, The Power Light Is Just Blinking At A Steady Rate. I Can't Access...
Please make sure that Power, Internet and Wireless Light (or LAN light if trying to connect with Ethernet cable) is there on router if you are trying to connect it wireless .
And if only Power light is there only.Please try to power cycle the router ( turn off the router from power supply wait for a minute, plug the power supply back) and then again check the light status.
Even after this if same light status is there please try to reset the router ( there will be small pinhole button on the back side of router) just press it for 15 seconds and then release it.Wait for 2 mins and check the light status again.
It will fix your problem.
Please share the results.
Dec 09, 2010 | Linksys WRT54G2 Wireless Router
How do i hook up my belkin f5d7230-4 router to hughes net internet when there is only one ethernet port?
Connect that one port to your Belkin WAN (Internet)connector (Yellow Port). The other ports go to other computers, to their Broadband RJ45 connectors.
Here's from the manual:
1. Unplug your existing modem’s power supply.
Find the cable connecting your modem and computer.
Unplug it from the modem and plug it into the gray port
on the Belkin Router.
If you are replacing an existing router, find the cable
connecting the computer and old router. Disconnect it from
the old router and plug it into the gray port on the new router
2. Connect the new cable (provided in the box) to the yellow
port on the Router. Plug the other end into the modem.
G WIRELESS ROUTER Quick Installation Guide
3. Plug in your modem’s power supply. Wait 60 seconds for the
modem to start up.
Plug the Router’s power supply into a wall outlet, and the
other end into the black port on the Belkin Router.
As the Router wakes up, lights will come on; recheck your
connections if the “power” and one of the “wired” lights
are not lit up in green after 20 seconds.
4. Locate the CD in this guide and insert it into your computer
The Setup Assistant should appear automatically.
If it doesn’t, open the CD in My Computer (Windows®)
or the Finder (Mac OS® X) and double-click on the
“Setup Assistant” icon
Nov 15, 2009 | Belkin (F5D7230-4) Router (587009)
The d-link light does not turn on when power plug
Check the power adapter of the dir-615 for output supply. It might have short circuited due to voltage surge.
Oct 19, 2009 | D-Link DIR-615 Wireless Router
Conect the router?
1. Unplug your DSL modem’s power supply.
the old router and plug it into the gray port on the new router.
port on the Router.
modem to start up.
4. Locate the CD in this guide and insert it into your computer.
If it doesn’t, open the CD in My Computer and double-click on the
“Setup Assistant” icon.It will guide you through he rest of the setup.
If you need more help please post back,If this help please rate as a fixya.
May 17, 2009 | Belkin (F5D72304F5D7000) Router
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
