My key board dose not work right can not make the @ symbol with the key right key it make the @ symbol with the number 2 key I need help to fix this proble.
    Scholar:
  • 103 Answers
Maybe you haven't press SHIFT key then @ key at the same time.If the problem still occur. Try the alternative way below
press ALT 6 4
to do this hold ALT then press 6 and 4...the number should be press at the numeric keypad and be sure the numlock is press or ON.
Posted on Jul 19, 2010
Hello, I need help. when I press number keys i get symbols. As of right now number key 3= 1, 4= 2, 5= 3. When I press 1 i get a (1/2)
Is this on a laptop? If so, see if there's a Fn key that changes the KB to symbols, tap it again to disable. Same thing with a smartphone.. disable an icon or led that shows unique symbols.
Feb 21, 2018 | Computers & Internet
Numeric key pad on right wont work on aspire 7741 notebook
Maybe you need to press the Num lk (number lock) key at the top of the keyboard, then Press and Hold the FN function key at the lower left portion of the keyboard then hit the number key you want..
May 06, 2012 | Acer Aspire 7741z
Where is the "tm" symbol
There is no "tm" symbol key on a keyboard, you need to enter an ALT key to type the trademark symbol.
Hold down the "ALT" key while typing 0153 and it will enter this: ™ when you release the ALT key
Mar 04, 2011 | ASUS Eee 4G Notebook
Dear Sir , If you start copying a Class 10 / 11
I understand the pain and how difficult it is to work on a science document!!!!!!!!!!!!
By the way if you are using the office suite applications such as Word 2007 or word 2010, you can insert the symbols easily.
To insert a symbol or special character into your document, follow these steps in Word 2007:
1. Position the cursor where you would like to insert the symbol or character
2. Open the Insert ribbon
3. Click Symbol in the Symbol section
4. A menu will appear with a small selection of symbols
5. If you don't see the symbol or character you'd like to insert, click More Symbols
6. Use the controls to select between symbols and special characters. Additional tools on the symbols tab will help you expand or narrow your selection
7. When you find your symbol or special character, click it and then click Insert
8. When you're done, click Close
The symbol or special character will appear at the appropriate place in your document.
Hope this helps!!!
Well, I am helpless regarding developing a keyboard with all those scientific symbols,.LOL
W
Jan 07, 2011 | Logitech 967437-0403 Keyboard
Replaced Drum Cartridge - Alarm light still on and still says "replace Drum Cartridge. How do I reset?
Try this procedure, it should help fix the problem,
Turn Printer off. While holding down Enter and Menu keys, power the printer on. You should see PCU Diag Mode displayed. Hit Menu key 6 times till Counter Set is displayed. Hit Enter key Dev xxxxx displayed, left 3 numbers are blinking. Hit (down triangle symbol) till numbers are 000. Hit Menu key, right 2 numbers are blinking. Hit (down triangle symbol) till numbers are 00. Hit Menu key. Drm xxxxx displayed, left 3 numbers are blinking Repeat steps 7-10. Dev tm xxxxx displayed. Repeat steps 7-10. Drm xxxxx displayed. Repeat steps 7-10. Life xxx displayed. Life should be set to 005. Hit Menu key. TNL xxx displayed. TNL level should be between 90-110, if you have problems, try changing TNL. Hit Enter key Counter Set is displayed. Hold down Form Feed key and insert blank paper into manual feed slot. You should get a beep confirming reset. Power printer down and back up, you are done.
Oct 06, 2010 | Sharp FO-4400 Fax
Some of the keys on my keyboard are producing wrong symbols not all of them mostly tge right hand side of the keyboard for example when i press the letter 'o' it produces /6 and the p produces -* how do i...
this means that your number lock is turned on.
there is a Fn key on the board. hold that and look for the number lock key and press it. each system is different so it will be either NumLk, NumLock, or a 1 with a lock symbol. Acer generally places this on a F key many times F7.
Jun 03, 2010 | Acer NSK8458AN Keyboard
How can i make a forward slash on a mexican keyboard. on an american keyboard there is useually one symbol per number on the top keys so you onle have to press shift then the nuber to get the symblol...
On these keyboards, the non colored symbols are typed by holding down the shift key and tapping the symbol. If you want to type the colored key, then you have to hold down the Alt Gr key and tap the colored symbol key.
Jan 13, 2010 | HP Pavilion dv6000z Notebook
The@sign
I had the same problem. When I pressed shift and that comma key I got a " instead of a @.
I looked to see what on the leyboard you normally press to get a " and that's the number 2 key.
Tried pressing shift and the 2 key and hey presto, I got a @.
So it looks like @ and " have swapped places.
So shift and 2 for a @!
Lizzie H
Oct 24, 2008 | Computers & Internet
The pound symbol
I am unable to answer your problem that why you are not getting the required symbol if it is there (Hope that you are pressing the no. 3 with Shift key pressed).
But if you need a Pound sign you can get it by pressing 0163 key from the right side numeric keypad while pressing the alt key (i.e. alt+0163).
Remember that you cannot use the upper number key for this purpose.
Feb 06, 2008 | Acer NSK8458AN Keyboard
Computers & Internet Logo
89 people viewed this question
Alun Cox
David Payne
David Payne
