Question about Toshiba TN50V71 50" Rear Projection Television
My Toshiba Cinema Series TN50V71 will not turn on. The power light comes on solid for a few seconds then it begins to blink and continues to blink but the TV does not show any sign of responding or trying to turn on at all.
ctf1800
  • 4402 Answers
SOURCE: Toshiba 55" 55H70 model. Turns OFF, but won't turn ON until I unplug it from the wall first.
sounds like loose connections on the convergance amps ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 25, 2007
ctf1800
  • 4402 Answers
SOURCE: Toshiba 65HX81 would not show any pictures power light blinking
how many times does it blink?
Slinteriors
  • 8617 Answers
SOURCE: Toshiba TP50H95 TV Won't turn on - Pete
You will need to trouble shoot the start up and shutdown circuits. Often this is a minor component failing causing the set to not power up or go into protective shutdown. Do you have the service manual for this TV?
Posted on Mar 02, 2008
SOURCE: Toshiba 52HM95 lights blinking
Mine was having the same problem. Just heard back from the shop and they said it's the light engine. They want $750 to fix!!!
Posted on Oct 29, 2008
ginko
  • 19396 Answers
SOURCE: toshiba 46H84 tv turned off light blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
Mar 08, 2013 | Televison & Video
Toshiba 50HP95 timer/Rex light blinking green. Tv wont turn back on.
place to begin if you are able is examine the power board for puffed up caps and or voltages coming into the board and out of it.
Aug 27, 2012 | Toshiba 50HP95 50 in. Plasma Television
Toshiba A135-S4527 starts to power up then shuts down.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 08, 2012 | Toshiba Satellite A135-S4527 Notebook
Toshiba TN50V71
Shorted horz. output transistor
Feb 09, 2009 | Toshiba TN50V71 50" Rear Projection...
Toshiba Regza with red LED blinking
hello the red blinking lights is a service code when this happens it means theres a power problem or a fualty circut. it happens alot with these new plasma and lcd tv's its very common since these units have built in protection and power loss a fualt or short will cuase this.
the tv needs service the tech will know what to look for according to the number of blinks.
hope this helps.
Dec 18, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
No video, shuts off then back on
I checked Toshiba's website and found the manual for the set. The self restarting was indicitive of a lamp failure. The red light was solid while the green light blinked. It would then restart 8 times before both lights would then begin blinking.
Sep 15, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 61' cinema series rear projector
check for loose connections and or bad convergence amp ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://www.hdtvoice.com/voice/showthread.php?t=28929
good luck
please mark the post with a fixya!
Feb 07, 2008 | Toshiba 61H71 61" Rear Projection...
Toshiba 50" cinema series
Try to unplug and replug back the power cord of the
tv and turn it on again. Sometime this work.
Sep 09, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba TN50V71 50" Rear Projection Television Logo
210 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
