Question about PNY 2GB microSD Memory Card
How to repair curepted memory card - PNY 2GB microSD Memory Card
  • 83 Answers
Hi friend first you install yours device then logoff yours system then logon again and click on start--->run --> write command cmd then click on ok,Now write commands step by step
1) cd\ press enter
2) c:/>format drive letter (eg d: f: e: etc) press enter
3) read message carefully and then press y
now yours flash drive formatted
Posted on Aug 03, 2010
How can i repair corrupted memory card?
Test yuor memory card in other cellphone,,
or plug it in on computer to see if the memory card is
still good or it was totaly corrupted.
if you mmc is real corupted,,you can use this to recover your files
download this and install it on your computer
memory card recovery tool
Nov 03, 2012 | Cell Phones
Where can i find a repair center in el paso tx for a memory card
Memory cards are a throw away items, the memory chip cannot be repaired.
Dec 05, 2011 | Electronics - Others
I gave my nokia7210 for display replacement and its memory card was removed. But after getting it repaired when I inserted the mem card and tried to access data. I get memory card not formatted error...
The tech who repaired your phone may spoil the memory card.Because,Before we unscrew the gadget we should remove all the hardware attetched. Besides,this problem occur only when The chip inside the memory Card was damage.So we could not repair this during this time.
Mar 29, 2011 | Nokia 7210
Where could i take my memory card to get repaired
I don't have a clue where you live, but a 1GB memory card from anybody is designed to be thrown away, unless you think you can find anybody to "repair" or even look at it for less than $15.
Just **** it up and get another.
Carl
Sep 12, 2010 | SanDisk 1GB microSD Memory Card
I acidentally dropped my camera memory card and stepped on it. Now the metal piece (the reader) is missing and the card won't read.
Compare the damaged memory-card with a non-damaged memory-card.
If you've broken-off the gold-coloured contacts from the edge of the memory-card, then your memory-card is broken beyond repair.
Tough luck.
Jan 04, 2010 | SanDisk 2GB microSD Memory Card
Same memory card been using but now indicates no memory card when i turn on
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, don't fret. Although professional repair would be more costly than the value of the camera, there is a very good chance that you can repair this yourself. Please see the following:
http://camerarepair.blogspot.com/2009/06/fixing-compact-flash-memory-card-error.html
May 16, 2009 | Canon PowerShot A70 Digital Camera
Win32 problem
Possibly missing or curept file. Reinstall Windows is wnat I do, if you are refering to win 32  error code.
Dec 08, 2008 | Computers & Internet
Sd card error on canon powershot s3
I get a memory card error everytime I insert a memory card. They are not locked and I have tried 4 different memory cards and nothing works. How can this problem be fixed?
Jul 28, 2008 | Canon PowerShot S3 IS Digital Camera
100Ct
Hi, Depends on what OS you are using. For this particular model (Libretto 100CT), it is probably either Win9X or RedHat (or some Linux variation). In Win9X, you might try F8 & run it in DOS and run: Scandisk c: /autofix /surface; Scanreg /fix If it is beyond repair you have to have access to the OS installer CD. Sometimes Win9X installer is also saved in the HD. Try checking if it is inside your HD and run setup. Hope this be of some help. Pls post again how things turn up. kind regards.
Jul 24, 2007 | Toshiba Libretto 100CT Notebook
PNY 2GB microSD Memory Card Logo
132 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
