Question about Uniden BC340CRS Base Scanner
The scanner is stuck in open squelch - Uniden BC340CRS Base Scanner
  • 99 Answers
Rotate the knob counter clockwise to close the squelch. If this does not work, remove the knob by pulling it off gently and make sure the "pot" is turning with the knob. Verify the knob and "pot" are not damaged.
Posted on Aug 31, 2010
    New Friend:
I am having the same problem... It is "stuck" in an open squelch.. however, if you put in WX mode works fine... so it must be something other then an open squelch problem..
Posted on Jul 06, 2013
3 Suggested Answers
Communicomm
  • 90 Answers
SOURCE: Unable to quit the squelch
This is an internal problem that can only be repaired by a technician familiar with Bearcat scanners. If you live near NJ, call 973-831-5900.
Posted on Jan 05, 2009
  • 120 Answers
SOURCE: scanner wont scan
provided you turned the squelch know and it didnt help, i would trace back from the squelch control to the first and second transistor you come to and that should be the squelch circuit. if you know how to check them with an ohm meter you can find out which one it is, if not you can just replace them both for under 5 bucks.
Posted on Jan 10, 2009
Squelch sound unit wont scan sound wont go away
I need to look at mine it could be a stuck monitor button or a q or chip failed . will get back with you. JR
Aug 10, 2016 | Uniden Bc340crs Bearcat 100 Channel Police...
Uniden BC340CRS
i need radio phone codes for my scanner.
Jul 06, 2013 | Radio Communications
Last night was working fine - as it was on I noticed that the scanner was just stuck on one channel - I hit scan ( I have several channels programmed) It wouldnt scan. Then when I turned the squelch...
Hopefully Resetting or Initializing the scanner will clear the problem and get it working again for you. Instructions for these procedures are on page 38 and 39 of the scanner operating manual. If you don't have the manual, you can download and print it, at no cost, here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
Bill B.
Listening in since the 60's
May 24, 2011 | Radio Shack Pro-82 Scanner
I cannot get the squelch to work and the scanner will not scan the channels
hi the solution to your problem is your scanner will not scan frequencies while the squelch is open you will need to open it and ajust VR1 VR2 please check these use a plastic screwdriver when ajusting be carefull not to damage any of the components goodluck
Jan 24, 2011 | Uniden BC248CLT Base Scanner
Scanner acts like it doent have squelch control
If your scanner is open squelched on one channel, try blocking that channel out. Some times a channel can get jammed if someone has a mic cue button stuck or something similar.
Try locking out that particular channel and see if you get your squelch control back.
Apr 07, 2010 | Radio Shack Pro-2052 Scanner
Squelch stays open
I have a problem with our photocopier sharp AR 452 U ---- codde error H5-01.
THANK YOU FOR A QUICK SOLUTION
Oct 20, 2017 | Uniden BC246T Handheld Scanner
Acts like squelch is stuck
I had the same problem. Your board may be fried. I had to buy a new unit.
Jan 28, 2009 | Uniden BC248CLT Base Scanner
Dec 24, 2008 | Uniden BC248CLT Base Scanner
Scanner wont scan
Oct 02, 2008 | Uniden BC278CLT Base Scanner
Squelch is open all the time
Often the potentometer (squelch control) becomes worn or dirty, this can be sometimes cured by spraying a WD40 or similar oil and then rapidly moving the control down and up. Do not use oil that is conductive.
Sep 11, 2007 | Radio Shack Pro-2096 Base Scanner
Uniden BC340CRS Base Scanner Logo
1,164 people viewed this question
Top Uniden Radio Communications Experts
Steve
Marvin
Marvin
Van Allen II
Van Allen II
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
