Question about SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive
I purchased this device and it doesnt show up on my computer.How can I fix this?
  • 83 Answers
May be problem related wiyh window change pc checking it and then find out where is problem. and then ask Q again
Posted on Aug 03, 2010
Touro 1tb is lite up, but this isnt showing on my computer, it was working perfectly fine yesterday and now it doesnt, I have tried a different USB cable and this hasnt worked, please advise?
Hello Stellafox,
The issue you describe is generally a simple hardware failure but without further diagnostics it would be impossible to advise you as to where the failure resides. If you are technically capable, follow the directions below, if you even have to consider how capable you are, take it to a repair shop and ask them to try these steps.
First, connect the device to a different computer, listen carefully for clicking scratching or ticking sounds, if you hear any report back including your country and state/province and I can recommend a nearby recovery facility. If not proceed to check within computer management(Windows) or in disk utility(Mac) to see if the device is registered. If not remove it from it's enclosure (voiding any warranty) and repeat this step. If the device does not show up on Disk Management on two or more devices, striped of it's enclosure, again refer back and I will recommend a data recovery facility near you.
If it shows up at either stage, the problem is most likely logical in nature, check the size of the drive and ensure it roughly matches the stated size(won't be exact). If it does but the partitions show up as RAW or UNALLOCATED, advise and I can recommend a software solution for recovering your files, if it does not show up or shows up in a place like Device Manager but either does not show up or shows up as 0GB and or Uninitialized but refuses to initialize, again hardware failure we can connect you with a pro.
If you are looking at a software solution, ensure the computer you are connected to has sufficient space to recover all of you files or purchase and connect a new drive of appropriate size before proceeding. We can recommend software for this purpose or if you'd prefer a company who can dial in remotely and assist you with the recovery process.
Of note if you got to the step where the drive is removed from the case and it not only showed up but also has access to your files, back them up to a second device then purchase a USB/eSATA enclosure to put the drive into as the failure was in the enclosure and not the drive.
If none of these steps work or you get very different results, report back, be specific and include all the details you can think of and we will help you assess your next diagnostic step.
Hope this helps,
Chris
Oct 12, 2014 | Hitachi Touro Desk 1 TB USB 20 External...
How to eject a stuck dvd in a desk top computer?
by "My computer doesnt show that the dvd is in the computer" are you referring to the disk or the drive? If the drive is not showing in my computer try using this file: [COLOR="Red"]- (recommended fix)[/COLOR][/B]
And here's a method [B](CdGone.zip)[/B] that will do a procedure automatically for you if you're afraid to edit the registry manually.
(automatic fix, post #7, download file: [COLOR="Magenta"]CdGone.zip[/COLOR])
Unzip the file, then launch it.
http://www.geekstogo.com/forum/files/file/8-cdgone/
Jun 24, 2014 | Protron TPL-C01
My dell inspiron 560 wont recognize any disc it acts like nothings in it how do i fix it?
Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Check BIOS by pressing F key (correct F key is noted during boot) and make sure BIOS see's the Optical Drive.
Nov 20, 2012 | Dell Inspiron 560 (Intel Pentium Dual Core...
Firmware repair for Samsung SpinPoint T133 Series (HD300LD) 300 GB Hard Drive
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. There is a connection problem such as a bad cable
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
One bad lead can cause a computer to continue on a cycle to shutdown or fail to detect a hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure connection and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 11, 2012 | Samsung SpinPoint T133 Series (HD300LD)...
External drive doesnt show on computer wen i plug
install proper driver for your external device
Jan 18, 2010 | Electronics - Others
Internet just stopped working. doesnt show any
Please remove and reload your NIC drivers.
Open the device manager, find the network devices and delete them. Reboot to have Windows reinstall the devices.
Dec 26, 2009 | Gateway 7330GZ Notebook
Computer wont read mp3 player when connected
is the USB device enable in the computers bios
does any usb device detected by the computer.
or
go to the control panel/system/device manager
does it show usb devices
Feb 25, 2008 | Samsung YP-K3 MP3 Player
Not working
Is the drive connected propperly ?
look at the jumper settings if its IDE
if it is connected propperly and still doesnt show up
( verify its showing up in My COMPUTER)
try it on anoter PC to see if it works.
Just cause its new doesnt mean it works
If it works and you did connect it propperly the let me know
IS IT READING ANYTHING ?
Is IT SHOWING UP IN YOUR DEVICE MANGER?
Click START, (right Click) my computer, select properties then device manager, it shoud show up in DVD/CD-ROM drives
if it doesnt then right click on anything and scan for hardware changes. If it doesnt show up then it isnt connected propperly.
Oct 13, 2007 | LG GSA-E10L (8801031212552) DVD±RW Dual...
SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
57 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
