Question about Honeywell Programmable Thermostat Heater
Furnace not running along with heat pump
Our old Maple Chase thermostat was replaced with a FocusPRO TH6220D. During regular operation the furnace does not come on and the system is running off only the heat pump. It turns on 1-2 hours before the wake time trying to warm the house off only the heat pump when the temperature outside is 35-40 degrees. We were away this past weekend, and my neighbor called to say the heat pump had been running continuously and there was a thick frost (1-2 inches) over the entire heat pump unit inside and out. Is there a way to make the thermostat use the furnace and the heat pump together. It does not seem to be very efficient the way it is working right now. I have turned it to EM heat so that it will not run only the heat pump, so I am running only the furnace. Also, we do not like the cycles per hour setting, is it okay to change it to a lower frequency? I believe it is set to 9 as per the installation manual. Thank you, Jeanette Heylen Bainbridge Island, WA
  • 3,361 Answers
Someone did not program your thermostat to operate according to your heat and air requirements.
Have it programmed correctly.
Posted on Feb 25, 2009
How can I connect an Intertherm furnace with a heat pump to a new Honeywell thermostat?
Ensure that that thermostat is for a heat pump and has connections for the emergency heat strips.
Feb 02, 2016 | Heating & Cooling
My gas furnace and heat pump runs at the same time???
its likely the outside control unit board its supposed to only kick on gas only when the temp is at freezing..
the inside thermostat is not selected for heat pump, open it an look at the jumper / switch.
or just replace the thermostat , then return it saying you couldnt figure it out. :P
there are a lot more variables here after that you cant know how to check.
Nov 05, 2014 | Honeywell VisionPRO 8000 Programmable...
It is 22 degrees here in Dallas, Tx and my heater doesn't seem to want to get it any warmer than 67 degrees. My unit is only a couple years old along with my Honeywell TH6220D. Just wondering if it could...
em means emergency heat,which means you have a heat pump.check out door unit,it might be all froze up,or covered in snow,sweep snow off gently. if it's froze up its not defrosting and you need a service call.if your back up heat is not working there might be little window on furnace,look for flashing light inside.if light is steady on its working.
Jan 12, 2011 | Honeywell Programmable Thermostat Heater
Furnace blowers continues to run after reaching temp
It actually sounds like you may have answered the question yourself. If the mercury isn't breaking contact, then obviously it's still calling for more heat. This is a common problem with the old mercury thermostats and are usually replaced with digital ones that are way more accurate. The are fairly cheap at Wal-Mart and such, and replacing one is basically all color coded.
Jan 27, 2010 | Electric York / Paragon A-111-20 Heat...
The furnace wont turn on even though it says it is
not all digital thermostats are compatible with the manufacturers circuit control boards in the furnace. Hunter has had this problem several years ago. Other than that you may have miss wired the unit. usually the furnace is used as backup heat (during defrost) or emergency heat if your heat pump konks out. Are you switching to emergency heat for a furnace call?
Nov 24, 2009 | Hunter Fan Company 5/1/1 Programmable...
My thermostat
Maple chase is the same I believe.Sounds like the thermostat is bad.I personally think the Honeywell 3000-4000 series thermostat are better.But the Maple should work!
Aug 18, 2009 | Honeywell Programmable Thermostat Heater
Wc wiring on thermostat
sounds like you have a heat pump the w2 on old thermostat is for a second stage heat. If you can give me a little more information on type of system you have (forced air furnace with heat/cool, Heat pump or boiler)? How many wires are on old thermostat? Is it a no programmable or programmable? How old is the furnace?
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
286 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
