Question about Car Audio & Video
Ford escort 97 wont start
There is a tapping sound when i try to turn it on
  • Cheryl English Mar 25, 2009
    mynes a 96 ford escort, it worked fine, but now it wont start. Its also turned off on me a few times during driving, the CD player goes off and on right before it does that.
    Now it wont start at all, The engine makes no sound, but I hear a tapping sound inside my car, mostly when the key is half turned.
    The heater will work, the beeping starts when the key is in, and the lights work. But nothing happens when i turn the key to start, no startup sound, nothing.
  • 8,617 Answers
Youre in the wrong section I am strictly televisions and major appliances. maybe one of the other experts may be able to help you out
Posted on Apr 23, 2008
I have a 97 Ford Escort. For the past year it has a hesitation problem. Sounds weird but it mostly happens when I turn a corner and also when I go from 1st to 2nd gear or try to speed up in 3rd or 4th...
Could be a problem involving a flap of metal inside a rusty muffler. Possibly a loose piece of the catalytic converter. You could tap of shake parts of the exhaust system and listen for rattles. Similarly, it could be a problem with debris in the fuel tank, a loose. broken, or moving fuel pick up, or dirt in the fuel filter. It might even be related to a malfunctioning pcv valve(after market valves sometimes cause more problems than they fix). It sounds like is more motion related then pressure related if it happens on turns and accelerating.
Sep 28, 2010 | 1997 Ford Escort
What the timming marks set at on a 97 ford escort 2.0 l
here you go...
let me know if there is anything else you need
Apr 12, 2010 | 1997 Ford Escort
97 Ford Escort 2.0 - Starting issues. It has a
regardless if its a factory or aftermarket alarm, the single click sound is an indication that the starter solenoid is failing
with the solenoid mounted on the starter, about the only thing the shop could have did wrong is not clean off the surfaces where the start mounts and that is assuming you have oil leaks under the vehicle and/or they even removed the starter.
honestly, it just sounds like bad luck with a failing starter solenoid
Mar 25, 2010 | 1997 Ford Escort
1998 ford fiesta 1.3 fuel pump problems
tap on tank while someone is turning engine if it starts its the fuel pump if it doesnt check spark them find fuel psi relief and check for gas
Mar 03, 2010 | 1998 Ford Escort
I have a 1997 Ford Escort. I went out to start it
Check your battery, The terminals, ( can be cleaned with a can of soda, pour it on it will bubble) Are all the connections tight? Do you have ANTI- Theft on this car?
Sep 20, 2009 | 1997 Ford Escort
1997 Ford Escort will not start
try checking the timing belt.
Aug 13, 2009 | 1997 Ford Escort
97 escort wont start with new serpentine belt
check to see if the injectors are working....
Jul 07, 2009 | 1997 Ford Escort
97 escort smoking and misfiring
You need to check the timing if that checks out you should do a compression test and make sure its not a blown head gasket
Jun 05, 2009 | 1998 Ford Escort
97 ford escort will not start
check all your conections clean with a wire brush sounds like a bad conection. let me know. Phil
Jan 12, 2009 | 1997 Ford Escort
Car Audio & Video Logo
124 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
