Question about BenQ FP222Wa - Flat panel display - TFT - 22" - widescreen - 1680 x 1050 - 300 cd/m2 - 700:1 - 5 ms ... LCD Monitor
BenQ 22'' has a dark blue blob about 2cm on the bottom left of screen and the total bottom of screen right across and 5mm high is black with colored lines. Is the monitor kaput ?
MicrowaveSvc
  • 9098 Answers
SOURCE: benq monitor fp51g
What's the owner's manual say that means?
Posted on Jan 15, 2007
SOURCE: BenQ FP737S-D 17" LCD Monitor blank screen
Hi Mate,
Ive worked on a few monitors since then. From what I remember, one side of the foil needs to be removed. Under this foil are 4 plugs for the back lights. Mark them before you remove them so you know which way to put them back. Also unplug cable from board that comes from the front buttons. Remove 4 screws on side of screen. This will remove the steel housing that the circuit boards are mounted on. ***** Make sure you wear an earth strap or static electricity will fry the boards. If you dont have an earth strap, try to work on the monitor in a static free environment. eg on a steel table that has been earthed, and dont wear nylon clothing. There should be 2 circuit boards that will need all the screws removed to pull both out at the same time. The "PF" will be on the reverse side of the board or the "component side". There is a ceramic fuse (white), but this will not be the problem if you can see the screen with a torch. To find the fuse I spoke about, please see my previous listing.
All the best,
MB.
Posted on Feb 07, 2008
viziks
  • 220 Answers
SOURCE: Benq 17"Lcd monitor fault
Resolder the power transistors on inverter board and also check them.If display is not there at all some of this 4 transistors C5707 should be defective.Check associated fuse and Fet which drives the transistor.
Also check with Benq ,Normally offers three year warranty.
Samir
Posted on Mar 24, 2008
SOURCE: BenQ FP731 17" LCD Monitor Problem
Had the compete dark screen problem. Green/amber power light was coming on and off as expected but no image would appear on the screen.
Found PF751 to be open.
Thnaks for the help people.
Posted on Oct 08, 2008
freetek
  • 5568 Answers
SOURCE: BenQ FP91G+ 19" LCD Monitor black screen
Possibly either the backlight lamp or its associated power supply has failed. Power buttons (mostly LEDs) have constant availability of low voltage (for some other circuits too) otherwise they wouldn't 'wake up' on command from a computer as some do.
The blackout could also be due to a failed main power supply so the incoming video is no longer being processed.
Posted on Nov 01, 2008
Whats the color codes for a 2001 dodge ram 1500 stereo wiring harness?
2001 Dodge Ram 1500 Radio Wire Colors
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black/Dark Green
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Mar 30, 2016 | Dodge Cars & Trucks
Hi i would like to know how to fit my kenwood KDC-149 cd receiver headunit into my car. (wiring). My car is a Proton satria 98 model hatchback..the previous headdeck that it had fitted in it was (sony...
HI,
I Don't have the color code for Proton satria. I can give you details of Kenwood and Sony Head unit's wring color code if it helps you. Both have the same color coding. Their harness connector will be different. Use the following chart for wring kenwood to the existing wring for sony
Kenwood sony
Memory / Constant 12V(+) Yellow Yellow
Switch / Accessory Red Red
Ground Black Black
Illumination Orange/White NIL
Antenna Remote Blue Blue
Amp Remote Blue/White Blue/white
Left Front (+) White White
Left Front (-) White/Black White/black
Right Front (+) Grey Grey
Right Front (-) Grey/Black Grey/Black
Left Rear (+) Green Green
Left Rear (-) Green/Black Green/Black
Right Rear (+) Violet Purple
Right Rear (-) Violet/Black Purple/Black
You can connect the illumination wire Orange/white with the red wire.
If you need any more assistance feel free to contact me by fixya
AJIN
Nov 07, 2011 | Car Audio & Video
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Dec 25, 2010 | JVC Car Audio & Video
Need the radio wiring diagram for a 95 camaro
yellow is power . red is ignition or acc. black is ground. front speakers : left positive tan, left - grey , right - light green , right + dark green , rear speaker : left - yellow , left + brown , right - light blue , right + dark blue . this is for the fatory wire color code if u need the actual wire color code for cd player it is . white is front left , grey is front right , green is rear left , purple is rear right. solid colors are positive and wires with the colors listed with black stripes is for the negative
Mar 08, 2010 | 1995 Chevrolet Camaro
I need color codes
Constant 12V+ Black/Yellow
Switched 12V+ Red/White
Ground Black/Light Blue
Illumination Orange
Dimmer Pink
Antenna Trigger Orange/Red
Antenna Right Rear
Front Speakers 4" Doors
Left Front (+) Dark Green
Left Front (-) Brown/Red
Right Front (+) Purple
Right Front (-) Dark Blue/Red
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Light Blue
Right Rear (+) Dark Blue/White
Right Rear (-) Dark Blue/Orange
Feb 19, 2009 | 1996 Dodge Intrepid
Need a wire color code for a ford radio f58f-18c815-aa
Notice, this is from the 2005 Ford F150 Wiring Harness. Other radios should be the same or very close. From the main 24 wire connector on back of radio (C290A).
Pin 1- Light Green w/Violet stripe - Voltage always
Pin 2- Light Green w/Yellow - Accessory delay relay output
Pin 3- Light Blue w/Red - Instrument illumination
Pin 4- Black - Ground
Pins 5, 6, & 7 - Not used
Pin 8- Orange w/Light Green - Speaker, left front +
Pin 9- Grey w/Light Blue - Speaker, left rear +
Pin 10- Orange w/Red - Speaker, right rear +
Pin 11- White w/Light Green- Speaker, right front +
Pin 12- Dark Green w/Orange- Speaker, right frt -
Pin 13- Black w/Light Green- Ground
Pin 14- Grey w/Black- Vehicle Speed Signal
Pin 15- Red w/Black- Voltage supplied in Start
Pins 16 & 17- Not used
Pin 18- Light Blue w/Red- steering wheel signal
Pin 19- Dark Green w/Orange- steering wheel return
Pin 20- Dark Blue- Parking Aid mute signal
Pin 21- Light Blue w/White- Speaker, left front -
Pin 22- Tan w/Yellow- Speaker, left rear -
Pin 23- Brown w/Pink- Speaker, right rear -
Pin 24- Not used
Good Luck
Feb 09, 2008 | Car Audio & Video
Blue dots and blue color
my sony is 4yrs also it has blue dots on the left side from top to bottom and a blue blob on rt. bottom corner no longer under warr. please send repair solution.
Jan 12, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
BenQ FP222Wa - Flat panel display - TFT - 22" - widescreen - 1680 x 1050 - 300 cd/m2 - 700:1 - 5 ms ...  LCD Monitor Logo
24 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
