Question about Desa International Powerfast Heavy Duty Staplegun
My staples keep coming out crooked/bent and not in the surface I'm stapling? What am I doing wrong?
5 Suggested Answers
SOURCE: Need staples for my Swingline Heavy Duty Tacker #800
I have 8 boxes of 1/4" staples, 1000 staples per box, and I haven't an 800 or 900 staple gun, so I'd like either an 800 or 900 Swingline staple gun or for someone to buy my staples.
Posted on Jan 31, 2009
  • 384 Answers
SOURCE: how do i load the Desa Powerfast heavy duty
Turn Stapler over.
Posted on Aug 06, 2009
  • 87 Answers
SOURCE: Can't find staples for this unit
If you know the size it needs, you can get replacements from Grainger.com, or McMaster-Carr.com. both of these should have what you need.
Posted on Oct 09, 2009
Testimonial: "Thanks"
SOURCE: I have a Desa International 'Handy Master' Model
Swingline staples should work: http://www.amazon.com/Desa-International-36806-1000BX-Staple/dp/B000BQREV6
Horrible price, though.
Posted on Jan 06, 2011
How to shoot staples out of a trutac staple gun
Hello, there. The TruTac (TT50) is a bottom load staple gun. This video on the TruTac (TT50 and TT21) may help to answer this and other questions: http://bit.ly/1Xv7jeZ. Once the staples are loaded, keep the tool flush with the surface while stapling. If you have any more questions or need more detailed instructions, please contact us at customercare@arrowfastener.com. Thank you!
Jun 07, 2015 | Arrow Fastener Staple. TruTac Forward...
How do I change staples in a bizhub600
Depend on which staples. Saddle stich (example, Church service program with staples in the middle type) or booklet/corner with the staple on the left side or the corner. open finisher pull out the big section to the left side see to blue/green handles rear one is for corner staple which goes the fastest do to being used the most. when you pull them out there is a plastic guide they should follow if they don't line up power off the machine close all door power on machine. the stapler should go to default location which allows the staple cart. to be removed. DO NOT THROW THE CART AWAY!!!! YOU will be replacing the staples in the cart. Once out Push at he bottom pull the top. DO NOT PULL THE WHITE WRAP ON THE NEW STAPLE UNTIL INSTALLED in the cart. Had customer do that staples spilled on the floor customer installed the staples in the wrong direction.
Also be careful the is a tiny black accurator the mite come out keep it that's what tells the copier the staple is installed give to technician to reinstall.
Feb 10, 2014 | Konica Minolta Bizhub 600 750 Image...
I am having problems getting the staple to go all the way in -- recovering dining room chair seats. I have lost the manual -- does the dial with + and - have something to do with it? Stanley TRE500...
Hi Rita,
Yes, the + and - adjusts the depth of the staple. You should check the setting periodically as it has a tendency to move as you handle the stapler.
Also, holding the nose of the staple flush and steady on the surface helps to drive them to the proper depth.
Hope this helps. If it does, I'd appreciate a 4 thumbs up, keeps me working... Thanks,
Handie Andie
May 08, 2011 | Electric Stanley Tre500 Staple Gun /...
Stanley light duty staple gun loads and shoots but staples not coming out. nothing jammed as far as I can see. Should I open it up and have a look at the interior? Thank you Denise
It sounds to me like you must have a staple that has seperated and probablygot stuck in staple feed shute' I wouold carefuflly remove side plate and see if there is a staple in there crooked or if their is is small metal chip left over from manufacture.I hope this helps you.THANK.
Apr 07, 2011 | Stanley TR40 Light Duty Tacker
Swingline heavy duty stapler wont staple??? staples come out crooked
I'm having the same problem,...... Ugh,.. The stupid lil bendy thing that u put in the groove for the staples that u attach to the spring took me forever to put in place.. And I think it make have gotten out of place when I finally kept it in place long enough to close it,.
Aug 05, 2010 | Black & Decker 5700 Powershot Forward...
Electric stapler won't staple???
hi there. i hope i can help you? what you need to do is open the stapler up check for any stuck staples? where they come out. dont put two many in at any one time. please make sure you are putting the correct staples in? is there a sound when in normal use? if yes it may well be a blockage. also check the fuse in the plug just in case ? i hope this will help you,
May 01, 2009 | Kitchen Appliances - Others
Instructions on unjamming swingline electric stapler model 270; jam is at the front of the stapler; staplers come out either broken, flaten or crooked and does not secure document.
First, are you using the recommended staples for this stapler? Many heavy duty electric staplers don't use "standard" desk staples. Second, try unplugging the stapler, unloading the staples, and if possible, reach a couple of fingers into the stapler and try manually pushing up on the staple head to see if you can get the driver blade to come down. Does it come down smoothly, or does it seem like there is something stuck in there? If you aren't sure about disassembling the unit (my usual method-but I'd recommend having the parts diagram handy), try using a flashlight to look at the underside of the staple head, where the staples come out - can you see anything stuck in there? If so, you might be able to use a small knife blade or small dental pick to get jammed staple pieces out.
Mar 03, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Stanley Sharpshooter electric staple/nail gun-Hi-Lo knob moves
This is an ongoing problem with this tool. Between inadvertently moving it while using it and the constant rebound of the tool, the setting gets changed. The only suggestion I have is to duct tape the setting wheel into position.
Feb 12, 2009 | Stanley Staple/Nail Gun Elec
Desa International Powerfast Heavy Duty Staplegun Logo
594 people viewed this question
Top Desa International Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Desa International Tool and Hardware - Other Expert? Answer questions, earn points and help others
