Question about Motorola Mobility RAZR2 V8 Cellular Phone
There are horizontal lines and a hole in the display what could have gone bad
  • 2,005 Answers
Display chip heat damage
Posted on Jul 19, 2010
Dell laptop display
This can be one of two things. The first is unlikely, the display cable has become loose. The second is more possible, the screen has gone bad and needs to be replaced.
Aug 17, 2015 | Dell Computers & Internet
Pink and Green Horizontal lines across screen
Normally, horizontal lines on an LCD or LED monitor indicate a bad control board inside the monitor. However, occasionally the problem can be caused by loose or bad cable connections. The only things that you can really do is to disconnect both ends of the monitor cable and reconnect them firmly. Also, you can disconnect the monitor cable completely and just leave the power cable. With only the power cable attached, you can turn the monitor on and off. The monitor should have a "startup screen" or display a message that says something like "Video Cable Disconnected". If the green and pink lines are still present without your computer connected, then the monitor has gone bad. The good news is that Samsung SyncMaster monitors usually carry a 3 year warranty, whereas most monitors only have a 1 year warranty. You may be able to have the monitor replaced at no cost to you if it's less than 3 years old.
Jul 27, 2013 | Samsung SyncMaster Computers & Internet
My Dell P2310H monitor has a vertical Blue line and a white horizontal line displaying on the monitor.
This occurs when you have lines of pixels go out or your video card has gone bad on your computer. You should hook it up to another computer to confirm which is causing the issue and repair/replace the problem device.
Apr 01, 2011 | Dell Professional P2310H 23inch Widescreen...
I have a 5 yr old Samsung HP-R5012 Plasma Display Television. A display model. Last night, horizontal lines appeared, then, the top half of the screen went black, with color pink and blue surrounding the...
All plasma an lcd TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Aug 11, 2010 | Samsung HP-R4262 42 in. Plasma Television
My become like horzantal lines+become not
Disconnect the Monitor from the PC, and keep it still powered on. If it displays horizontal lines, it means monitor has gone bad. If not then go to PC's BIOS, if it shows lines there then your graphics card/chipset has gone bad. Else its your graphics driver/operating system. Can try an update/reinstallation of driver.
Regards,
Shrey
Oct 09, 2009 | Dell UltraSharp 2000FP 20.1" Flat Panel...
Problem with the video. There is display of thin horizontal line in the middle, when i turn on the TV.But sound is good.
Well I have some questions:
Is this a plasma ? If so is the line going up and down or from left to right ? If going up and down it is an address problem and most likely the panel will need to be replaced or a part on the address boards has gone bad. If its left to right then the scan board has a bad component in it and will need replacing.
Hope this helps and ask more if you want
May 07, 2009 | Philips Televison & Video
Horizontal Light Only
If you have a straight horizontal line in the middle of the screen the vertical deflection has gone out. Itll need to be repaired, the vertical deflection IC is bad. Hope this helps.
Dec 12, 2008 | JVC AV-27020 TV
Screen displays Horizontal white lines
try adjusting the screen control down..if this has no control unit may have a bad video drive circuit or possible bad crt or fly back transformer ...just a wag
Feb 06, 2006 | RCA F36649 36" TV
Motorola Mobility RAZR2 V8 Cellular Phone Logo
51 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
