Question about Toshiba TEC BSX5 Thermal Label Printer
Software reloaded = Teklynx Labelview Drivers reloaded My tech here covered the sensor window with a post-it note and the ?no paper? error went and I could ?feed? the stock OK The post-it note was too thick and so was replaced with clear sticky which had texta on it ? this also allowed me to ?feed? paper with no problem But when I try to print I get a ?paper jam? error. The sticky has been removed and boot up to do a ?test print? and all is OK until the print is to be done then ?no paper? error It does not make any difference which type of sensor is set in the machine it comes up with the same error. His diagnosis was that the sensor is probably at fault. It is a Toshiba SX5
  • peter497 Jul 19, 2010
    did not fix the problem
  • peter497 Jul 20, 2010
    the supplier sent this:
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
    mso-para-margin:0cm;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    Your issue will be much simpler than a faulty sensor, please
    make sure you have the right printer driver installed, please follow the steps
    below.
    Open labelview, go to File -> Select Printer, in the small
    drop down window you should see TEC B572 – (V) on LPT1 or very similar, if you
    do not see that click the install button.
    In the installation window scroll down to TEC in the
    manufacturers list
    On the bottom right hand side make sure that Native Drivers check
    box has a tick in it, and that the Extended Drivers check box does not.
    In the list above (printer Models) select the TEC B572 – (V)
    model.
    Once selected click on the install button, it will then appear
    in the installed printers list above.
    Click the connect button and select which port you have the
    printer connected to.
    At this point you will have the right printer driver installed.
    Now open your label format and click on Edit -> Label Setup
    Make sure that the Width and Height match your measured label
    size.
    Click on the Options tab, make sure the Sensor Type says GAP,
    and that the Ribbon option says YES (if you are using a ribbon, if no ribbon
    then select NO)
    Now all you need to do is make sure the printer is loaded
    correctly, make sure that if you are using a ribbon that it is installed
    properly, going between the 2 upper printer compartments on a 45 degree angle,
    then print some labels, it is always recommended that you print more than one
    label, giving the printer a chance to line the labels up on it own.
    i followed this twice and could see the online light flicker as the file came through but it then went to 'no paper' i then did a threshold set and fed through about 10 label rows but in the end the result is the same - no paper error.
  • 3,083 Answers
I looked this problem up on the net, and ran across this web blog. They suggest a procedure to try, and maybe it will help you:
http://www.centurysystems.com/techsup/faq/tecfaqs.htm#3
If that doesn't help, the sensor could be bad, and needling replacement.
Good luck, and hope this helps.
Posted on Jul 19, 2010
    the suggestion did not fix the problem. should i try to get a replacement part?
  • Tom Carson
    Tom Carson Jul 19, 2010
    That's always hard to say, since the sensor could be bad, but also, the software detecting it can also fail, or hang up in some state where the cpu always thinks the sensors not detecting the paper. I have some things to do right now, but I will research this problem later, and get back with you. I'm suspecting there may be two sensors now, but I'm just guessing, since two sensors would explain why covering the first sensor, the paper fed, but then no paper was detected. That makes me think it's a software hangup or 2nd sensor. Will get back on this later today.
Hi I haven't used my phone for a couple of years. when I switch it on now it say.. error 102 reload software... what do I do?
You need to do a Factory Reset, AKA a Hard Reset. This removes everything on the phone and reloads the operating system. Your phone is a Blackberry?
  • Error 102 Reload Software - BlackBerry Support Community ... https://supportforums.blackberry.com/t5/BlackBerry-Device-software/... Hello, I've just had a problem with my Blackberry 9930 phone. I already tried updating the Blackberry Desktop Software and I also tried the phone,
  • Error 102 - Reload Software - Blackberry Torch 981 ... https://supportforums.blackberry.com/t5/BlackBerry-OS-Smartphones/... Hi. I took the battery out of my phone and when the phone re-booted I now can only see a white screen with the error 102 and states reload software.
  • How to Reload Blackberry Mobile Software - Snapguide snapguide.com > Technology > Explore
    • 3.5/5
    • 10 RATINGS
    • BY TAHANI ALGHAREEB
    i will teach you how to reload your blackberry soft ware when its got error 102 and not working by this steps. all you ... How to Reload Blackberry Mobile Software
  • JVM Error 102 on your BlackBerry? Try this solution BEFORE ... crackberry.com > ... > Classic > Z30 > Z10 > Q10 > Leap > OS 10.3.2 Video embedded · JVM Error 102 on your BlackBerry? Try this solution ... JVM Error 102 on your BlackBerry? Try this solution BEFORE wiping! ... "Error 102. Reload Software ...
  • Terpecahkan: Curve 9360 Error 102 (Reload software ... forumdukungan.blackberry.com/...Error-102-Reload-software/td-p/258111 Terpecahkan: Dear all, Saya newbie disini, BB saya curve 9360, sudah mati 5 hari dengan error 102 (reload software). Sudah coba ikut instruksi dari
  • How to fix an error 102 reload software blackberry torch ... www.askmefast.com > ... > Error How to fix an error 102 reload software blackberry torch 9810? ... How can I fix reload error 102 on blackberry torch 9810? Comment. Reply. Report.
  • ERROR 102 www.blackberryos.com/general-blackberry-issues/38452-error-102-a.html
    • 2 POSTS
    • FIRST POST: 2013-08-12
    2013-08-12 · how do i reload software on a bb 9360?? ... Join Date Dec 2010 Location Gainesville, FL PIN Jarmeling Device Passport OS 10.3.2.2134
  • May 20, 2016 | Cell Phones
    Errors with my Printer/scaner
    Jessica:
    This could be one of a few things... First, Windows 8 is a completely different animal from Windows XP! Try reloading your printer driver in Windows 8. If this doesn\'t work, you need to clean the paper pickup rollers at the front of the printer (where the paper first feeds into the machine. I use a Q-tip moistened (not sopping wet) with rubbing alcohol... gently scrub the whole pickup roller and then the feed roller next to it. Check carefully (with a flashlight) for any shards of paper that might be blocking the paper path. There is also a sensor flag (small finger of plastic) sticking up that the paper must hit to let the printer know that the paper is feeding through. If you do not see the sensor flag, it is either jammed or has been broken off when a piece of paper was pulled backward out of the paper feed area. First reload the printer driver, and try to print. If it doesn\'t print, check and clean the rollers and look for the sensor flag.
    May 31, 2014 | HP 1050 Plain Paper Inkjet Fax
    Is it possible to view prints sent to a Intermec PM4i printer? Reason is we are testing label printing to a label printer in the UK and would like to see what is being printed on line perhaps via a web...
    Hi Karen - with Label Printing Software such as LabelView Pro and others from Teklynx and Bartender you can have multiple software licences that can be linked remotely if your printers are network ready. Using advanced rather than basic software you will have full control of exactly what is being printed/not only having it viewable. I hope this helps
    Oct 20, 2011 | Intermec EasyCoder PM4i Printer
    Ive just turned on my Canon pixma mp250 printer and have an Error, the screen is flashing E 0 3??? have tried resetting but that hasn't had any affect.
    An E3 error code in a Canon MP210 printer is frustrating. This code reflects a paper jam that is not always apparent immediately and can be indicative of other problems.
    Remove the jammed paper by pulling it from the front or top of the printer. If it does not come out, restart the printer to eject the paper. If the paper fails to come out or rips, remove the cover and retry. Once you have removed all visible paper, check paper sensor paths for debris or damage, blowing it out as needed.
    Reload the paper as recommended and print a test page using the printer's software. If the error continues, the sensor that generates the error may be damaged. If so, take your printer to an authorized service center.
    Aug 31, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
    Printer keeps saying it has a paper jam and to remove the jam from the back. There is nothing there! I think it just wants me to open and close the rear door, but that only fixes it sometimes. How do I...
    This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
    Nov 22, 2010 | Ricoh Aficio CL1000N Printer
    The traingle is flashing orange the rest not flashing. the printer does not print
    In the Attention state, the Attention light is blinking and the Go and Ready lights are off. This state can be reached in the following circumstances:
    ● Paper tray is empty
    ● Door open
    ● Toner Cartridge Missing
    ● Paper jam/ Tray Misfeed
    Pressing Go attempts to reset after a jam is cleared or is ignored in the other error cases. It may be necessary to clear the error manually and press Go or close the top cover. If the error still persists, the device will return to the Attention state.
    Note
    The LJ1010 product series does not have paper out sensors. When the printer is in an Attention state because the paper tray is empty, the user must reload paper and press Go.
    Nov 13, 2009 | HP LaserJet 1010 Printer
    Qms 2200 paper mismatch error
    Initial Thoughts
    The problem seems to be a fault in a paper feed sensor. This would explain the size mismatch, since these sensors are how the printer detects the paper size. And, it would explain why printing starts two-thirds down the page, since these sensors are also used in timing where on the page to start printing.
    However, a document passes through three software applications before it actually prints. And, any one of them could be causing the paper size mismatch.
    Insight
    Although paper sensors are usually low-tech and easy to remedy, they are often difficult to find and can sometimes be difficult to get to. Most such sensors are simple switches (toggles) and others are optical sensors that work like the electric eye of a garage door opening system. And, the solution may be as simple as a tiny piece of paper stuck on one of them. However, sensors such as these are quite numerous on this printer and can be hidden anywhere.
    The three software applications I referred to are:
    1. The document rendering application, such as Adobe Reader, Microsoft Word, etc.
    2. The print writer. This is part of the device driver software package. It breaks up a print request and converts it to a standard format that the printer will always recognize and manages transmission of each page to the system spooler or directly to the printer.
    3. The printer firmware. I'm not sure of everything this does related to the print stream. But, part of it must manage resources, such as ensuring the right size paper is being fed.
    Jan 23, 2009 | Minolta magicolor 2200 EN Laser Printer
    Alarm light flashing
    Is the front cover on the printer(ifs its not the alarm light will keep flashing as there is a sensor that will trigger the alarm if the cover is not on or not on properly.Hope this helps?
    Dezzi
    Jul 16, 2008 | OKI MICROLINE ML-395 Matrix Printer
    Paper problem
    Allow the recycling process to continue.
    Mar 02, 2017 | Brother MFC-3220C Plain Paper Inkjet Fax
    Toshiba TEC BSX5 Thermal Label Printer Logo
    118 people viewed this question
    Top Toshiba TEC Office Equipment & Supplies Experts
    matt
    matt
    richie46
     steve
    steve
    Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
