Question about Whirlpool AD70USS Dehumidifier
Basement dehumidifier freezing up. Only 2+ yrs old. Where do I purchase and how do I add freon? I do not see an area where it is added. Thanks! It makes this awful humming noise and that is what I found out. Ice ice ice...las )-: the thing weighs a ton and I am not looking forward to buying another. Have a wonderful day!
    Top Expert:
  • Whirlpool Master
  • 20,097 Answers
Any of them may freeze up when the temps get lower in the basement
Posted on Dec 02, 2017
  • 1073 Answers
SOURCE: I've had the dehumidifier since
the unit has a sealed system leak that has to be repaired by a whirlpool servicer
Posted on May 06, 2008
  • 389 Answers
SOURCE: My whirlpool dehumidifier freezes up !! whats the problem?
Your dealer who looked at it was almost certainly right in his diagnosis. "Freon" was originally a trade name for a limited range of refrigerant gases (the stuff that's pumped around in the pipes of dehumidifiers, refrigerators, freezers and most other coolers), but the name is often used colloquially to refer to any refrigerant gas.
When it's manufactured, each machine is filled with a measured quantity of refrigerant gas. This can leak out slowly over time, and freezing up is the common sign that this has happened. Most refrigerator engineers should be able to refill your machine and check for leaks at the same time.
Posted on Mar 21, 2009
bozcro
  • 867 Answers
SOURCE: White westinghouse dehumidifier freezing up
hopefully its not the coolant pump seizing. the only simple thing that goes wrong with those is the water full switch, which turns off every thing. try playing with the float thing in the tank, you shoud here clicking of the switch on and off
Posted on Jun 15, 2009
  • 441 Answers
SOURCE: Dehumidifier freezing up
it can be fixed but not economically, I would hold onto the unit the new ones are not good at all,
Posted on Jul 10, 2009
heatman101
  • 43501 Answers
SOURCE: i HAVE A WHIRLPOOL DEHUMIDIFIER THAT IS ICING UP
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier2_bing.gif is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Posted on May 05, 2010
Whirlpool Basement Dehumidifer is freezing up about l/3 from the bottom. Compressor will not turn off. Coils were cleaned and cleaned fan is running freely. Sitting in well ventilated area and temp...
IIt may very well be that the the air intake filter needs to be removed and cleaned. But, before doing this, turn the unit OFF & unplug it. Allow the unit to completely thaw, before removing the filter.Never operate the unit without the filter in place, As this could damage the unit.
Hope this helps you & thanks for choosing FixYa.
Sep 11, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
A very old, extremely heavy dehumidifier sat in my mother's basement for decades. I decided to dispose of it, but I was unaware of the freon inside it. In order to extricate the dehumidifier I had no...
Yep the ref is all gone, The EPA says that the oil is hazardous, actually its just mineral oil the at one time had ref. R-22 in with it.
Jul 03, 2011 | Dehumidifiers
Coils freezing up
The largest culprits for freeze up are dirty filter, dirty coil behind filter....and on certain occasions, low on freon.
May 12, 2010 | Goldstar DH2510A Dehumidifier
Doesn't collect water, freezes on top
clean filter and then check the coil behind the filter to see if clean. Biggest things that freeze a unit are dirty filter or coil...or low on freon.
May 10, 2010 | LG LHD45EL Dehumidifier
Cycles every 3 minutes
It may be in a basement that is to cool. Unless this is a special low temp dehumid it needs to be in the upper 60's to work correctly. Also a 50 pint is for a pretty good size area, if it is in a small area or if the temp is to cool in the basement it is in it will freeze up and cycle off. 3 min is awfull quick though. It may be low on freon also. Just a couple things to think about.
Jun 20, 2009 | Whirlpool AD50USS Dehumidifier
Mar 20, 2009 | Whirlpool AD70USS Dehumidifier
Lg lhd65el dehumidifier icing up
This will need to be serviced. LG has a 5 year warranty on these models. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is 2 years old.
Jul 28, 2008 | LG LD65EL Dehumidifier
Whirlpool AD70USS Dehumidifier Logo
306 people viewed this question
Top Whirlpool Dehumidifiers Experts
Marvin
Marvin
Mike
Gil Shultz
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
