Question about Hoover Nextra HNWL 3166 Front Load Washer / Dryer
The washeers drum sounds a bit nosy I think smething might be stuck inside the inner drum. How do I get to check the inner drum?
The inside of the drum makes a clicking sound, and I located the noise at the back of the drum and the noise seem's to be in the central part where the bearings is located.
Posted on May 29, 2011
Knocking sounds on wash and rinse mode
causes is
bearings {check for drum play much as you would a car wheel
breast holder wires you can find them impaled on the outer nylon/ plastic drums and they rattle
something inside thats impalted on the inner drum knocking on the heating element etc
got kids?? if its dirty the soap drawer is where they go
lego houses monoploy bits metal figures lately its been kinder egg toys
nintendo plastic pens dolls heads action figures and etc...
Dec 02, 2014 | Washing Machines
Burnt smell bits of plastic found inside
A WM1814CW does not have a built-in water heater, so I think your
load may have gotten trapped between the spinning tub and plastic
front tub cover..Roll back the gray gasket to expose and check the
plastic ring for signs of 'friction' burn..As long as the splinters are
trimmed away and doesn't leak water you should be OK..Watch your
loads..Don't Overload!
Aug 18, 2014 | LG WM1814CW Front Load Washer
I have got a Hotpoint Aquarius + WF740 1400 spin speed. When the drum is moving slow inbetween cycles there is a wereing noise, In the wash cycle it clunks but it's ok in spin mode. When I move the drum...
there could be something stuck between the inner and outer drum, eg. a bra wire a common culprit.
inside the drum you have 3 lifters ( blue pillars). remove one of these by pulling it towards you.this will allow you to see into the inner drum. get a flash lamp and have a good look rotating the inner drum around.
if you see anything get a pair of pliers to pull in out as you cant get a nasty cut.
replace lifter as u removed it.
if bearings were gone would sound like a tractor while spinning.
Mar 18, 2011 | Hotpoint Aquarius WF000 Front Load Washer
My front load washer is making a loud noise and think it is the motor, i took the front bottom panel off and the sound was coming from the what looks like motor i guess not sure what to do
Remove the rear panel . remove belt . turn drum pully if you hear any noise it is the rear drum bearing and seal . Reach inside drum from front and lift up on inner drum. If this drum moves up and down or side to side you will also need to replace the inner drum. If turning the drum is silent try turning the motor if it makes a noise replace the motor
Oct 29, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a white westinghouse model lt 350r 15 years old front loader. it just wont spin and i can't get it to drain. it looks like the tub inside has shifted, it sounded funny the last few times i used it....
To drain it, take a shop vac to the discharge hose to vacuum out the water. If the inner drum is sagging inside the outer drum or when you try to turn the inner drum and feel any kind of thumping noise, probally means that the spider support has failed. It can be expensive to repair.
Aug 27, 2010 | Tecnik TKL9260 Front Load Washer
Loud squealing sound during spin cycle
Possibly a foreign article stuck inside the drum. When the machine goes onto spin this can rub against the outer drum causing such a sound.
This is commonly the underwire from a bra that has worked loose and lodged in one of the holes inside the inner drum. Have a careful feel round the whole inner surface of the drum to see if you can detect anything protruding. If you find a wire, grip it with a good pair of pliers and try to pull it out, remembering the shape that it probably has so it will need to be coaxed out accordingly. Anything protruding through the holes doesn't belong there!
I have removed three of these from our washing machine!
Mar 09, 2010 | Maytag MAV7700 Top Load Washer
When i try to open the door it sounds stuck makin a wierd nosie
check to see if the springs above the door are broken of it's the gear inside the operator that has been shreded you can find that our buy taking the cover off and theres a bunch of **** plastic dust means your gear has gone. you can change this gear.
Mar 20, 2009 | liftmaster Chamberlain Garage Door Opener...
Maytag Washer Noise While Spinning
Most washer models have snap-clips holding the front of the top panel down, with hinge-like clips at the back. Carefully pry up the top panel on the front of the machine using a tool that won't scratch the finish, such as a plastic or wooden wedge. If it does not pop loose fairly easily, then carefully examine the back of the machine to see if this is a rare model that has screws holding down the top panel. (But really, it _should_ just pop loose.) Once the top panel is tilted up to expose the inside, you should be able to see everything you need to see inside the body to evaluate a spinning drum problem.
Aug 04, 2007 | Maytag MAT13MN Top Load Washer
Hoover Nextra HNWL 3166 Front Load Washer / Dryer Logo
179 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
