Question about Panasonic PT-56DLX75 56" HDTV
Bulb has gone out and now makes a loud noise
The lamp has gone out which I understand needs to be replaced. But this morning when i went to turn it on is when i found out the lamp burnt out so while i was waiting for the tv to warm up, before i actually figured out the lamp burnt out the tv started to make a loud buzzing/cranking noise which scares me so One i need to know if this is normal because the lamp burnt out and Two when i replace the lamp should this fix the buzzing cranking noise, Thank you for what ever information you can forward
    President:
  • 1,619 Answers
The noise depending on where it came from may be normal. You wont be sure unless a TV repairman checks the boards to know for sure, or you could replace the bulb and hope for the best.
Posted on Jul 19, 2010
Samsung HL-85887W (HL556887WXLXAA). TV picture is dimming and loud hum from lamp area. This TV went through 2 lamps during warrenty period. I understand there are several lamp numbers and would like to...
You need a color wheel--common on these sets. Get a real phillips bulb and you should be set for awhile. The cheap generic bulbs are fine to get you through a few MONTHS....but NOT much longer. . An E22H-120/132 watt lamp is correct--and if you can replace just the bulb-(NOT hard at all to do) it will save you a LOT of money.
Mar 02, 2014 | Samsung HL Televison & Video
Loud pop
Check the lamp.
Pull it out and look at it.
More than likely the lamp has shattered inside the set and needs replaced.
Bulb replacement is made for consumers and can easily be replaced.
Need any more information, respond to this post and I will reply.
Dec 30, 2007 | Panasonic PT-45LC12 45" Rear Projection...
Tv sound buzzing lamp
Contact any service technician.
Oct 09, 2013 | Mitsubishi WD-Y65 65" HDTV
Replaced the lamp bulb on my samsung HLP5663. It went on right away. Though the problem was fixed. Turned the tv on a little while ago and the picture is gone. The timer light is blinking. Any ideas what's...
Now tv turn on.Hear alots of clicking or squiling,loud motor noises turn on?Alot of clicking,the Ballast board it dead,this board help ignite the projection lamp.Tv also have a colors wheels.The colors wheel is dead,if hear squiling noises,loud motor noises.
Jul 14, 2010 | Samsung DLP HL-P5663W 56" TV
Sharp XR-10X projector. Makes a loud whirring noise when trying to turn on. Bulb starts to turn on then doesn't. It's not the fans because I opened up the projector, disconnected the fans and it still...
the colorwheel motor bearings are starting to go. you'll need to replace the colorwheel. you can get the part from a sharp service center and do it yourself or send it to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 14, 2010 | Sharp XR-10X Multimedia Projector
Fan noise loud, bulb burst. Replaced with new bulb. Noise even louder! Unit shuts itself off.
the bulb may have burst from overheating from a fan not working to cool it down. and it can be replaced. it does take, however, a while to replace it because you have to take half of it apart. but make sure it's the fan first. take the lamp door off and remove the lamp. use something small and thin to push in the switch that the lamp door usually activates. turn the projector on and see if the lamp fan and the colorwheel (the multicolor glass disk) are spinning. if the fan spins, the noise may be from the colorwheel motor going bad. the fan can be purchased through an infocus authorized service center. check the website for the closest one. but the colorwheel for the x1 cannot be purchased seperately from the optical engine, and that costs a fortune. but here is the part number for the 80mm fan- 526-0152-00.
May 23, 2009 | InFocus X1 Multimedia Projector
RD-JT40 powers on but nothing shows
check the lamp,
does it look clean inside
is it fully home on the connecting pins
are the lamp door and fan switches made correctly
Feb 26, 2008 | LG RD-JT40 Multimedia Projector
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Panasonic PT-56DLX75 56" HDTV Logo
152 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
