Question about Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx
How can I Play music from Windows Media Player on a computer ,into A Behringer FX 1002 , add Vocals to the Music as it goes into the FX1002 and then store the Combined music and vocals back to the Computer where I can then turn the New Music and Vocals into a home CD.
  • 1,906 Answers
You must use the ubuntu linux operating system or, windows7 to do this
Posted on Jul 19, 2010
Qfx1222 usb/hp envy computer - no sound frm mp3 music files
When you connect your laptop to the behringer mixer via USB it effectively uses the mixer as the audio interface.
You will need to hear the audio through the mixer either through headphones or external speakers.
There is no way that I am aware of that you can route all audio back through your laptop's speakers.
Mar 16, 2017 | Music
What software do i need on my computer?
You could install VLC. It is free of charge and has everything to play your music and video's.
And the best thing it is for Windows and MAC.
VideoLAN Official page for VLC media player the Open Source video...
Jun 30, 2014 | Tascam DP 008 Digital Portastudio
I cant get sound from fx send to my computer
Open the volume mixer on the pc and make sure the mic port is on. When you find it, click on the "advance" tab and there will be a check box allowing you to add 4db to the volume of the mic. Also, make sure it is plugged into the line in or mic input on pc.
Mar 16, 2013 | Behringer XENYX 802 Mixer
Behringer XENYX 2442 FX: Turntable into CD/tape IN. CD/tape OUT connected to USB device IN. Why is there no signal from mixer to the computer?
If I read correctly, you have outputs on the Behringer (CD/Tape Out) connected to inputs on the Behringer (USB Device In). Is that correct? If so, try going from CD/Tape Out directly to the computer. If not, please explain what the "USB Device In" is.
Thanks,
Rich
Apr 30, 2012 | Music
Behringer Xenyx 502 Mic buzzing...PLEASE HELP
Get yourself anti-static spray and spray over the connector before inserting into the jack, most times its dust or static buildup which causes that buzzing sound and in other times replace your mic
Mar 02, 2012 | Behringer Xenyx 502 Audio Live Music Mixer...
How would i connect a Behringer 1002B Xenyx to a hercules mk4 mixer
The main output jacks of the 1002 are PSUEDO balanced so you can use TS to RCA connections from the 1002 to the MK4. It is not hte best design, but it will work... with two cables go from the 1002 main outs to the stereo ins of the MK4.
Sep 19, 2011 | Behringer XENYX 1002B Mixer
I have a problem with my behringer b3031a truth studio monitors.Slightly before a sound it's played (and during the playing) they make a little buzz. Ex. I turn on Windows Media Player and as long as...
The fault is not with the speakers... It is with the noisy audio system common in computers. Get a decent USB audio interface and use balanced interconnect cables to solve the problem.
Aug 02, 2011 | Behringer B3031A 2-Way Active Studio...
When i have my FX on and sending to main they make a horrible clicking (shorting out) sound. if I push the main mix button it shuts off the effects and the noise goes away...bad side...then I have no...
Check the 5 volts to the FX unit, If the voltage is low, the FX processor will keep reseting generating clicks, In a different product, the 5 volt filter cap was degraded and voltage dipped down to 4.5 volts causing resets.
May 31, 2011 | Behringer EURORACK UB2442FX PRO Mixer
I just purchased A behringer PMP4000. It has built in effects. When I follow the steps to add fx , as soon as I start turning up the fx send, It sounds like sweeping wind through the mains. How do I use...
Check the FX to main level to make sure it is not too high. Also check the main FX fader level. Try turning each of these down and see if that corrects the issue. The FX fader should control the volume level of the FX globally (mon sends as well as main outs), and the FX to main should only affect the mains output. Make sure FX to mon1 and FX to mon2 are turned all the way down.
Also check what FX program your using and that the FX IN button is depressed, try starting w/ #10 (small room) and see how that sounds.
Feb 28, 2011 | Behringer PMP4000 / B215XL Powered Mixer...
Boots slowly , takes 10min ( bad caps?) and have broken fx selector knob are parts available ? I'm in Canada and the music store I deal with says that Behringer is very slow to resspond to ...
Hi, It is not on selector knob, but it could be on capacitor(s). As stabilizer capacitor has role to maintenance the good power feeds to system. Please check it then.
Regards
Feb 12, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
Open Questions:
See all Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Questions
Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx Logo
145 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
