Question about Cobra LI 7020 WX-EVP Two Way Radio
The radios wont charge
Cobra7020 two way radios the charge light comes but they wont charge
My battery light has been coming on and off for a couple of weeks now and saying "Service Battery Charging System".
Have your charging system tested. The battery light is turned on when there is a charging system problem causing an over/under charge condition. You may possibly have an alternator problem. If the battery is not being charged properly, the computer will start shutting down electrical components for protection and to keep enough voltage supply to enable the vehicle to continue running
Jan 27, 2016 | Cars & Trucks
Car wont start has charged battery lights and radio come on new starter. drainging battery even though the battery is fully charged its reading its not tempature gauge reading hot but its not runn
If the problem began when (or soon after) installing the new starter, start checking there. Ensure that all cables to the starter are tight. As a second possibility, if the new starter was actually a rebuilt replacement, the solenoid could be faulty. (I went through three rebuilt starters on my son's truck until we got one that worked properly.)
Mar 06, 2014 | 2004 Ford Mustang GT
1996 acura tl wont start
charge the battery?? or jump the car.. could be a dirty battery connection, not enough power getting to starter
Sep 12, 2012 | 1996 Acura TL Series
I have a 2003 Monte Carlo the radio an interior lights wont come on an the car wont start
Make sure the battery is well charged, also open the fuse box and check if any of the fuse is burnt then replace it. thanks for using Fixya.
Sep 06, 2011 | Chevrolet Monte Carlo Cars & Trucks
My 1995 chevrolet silverado wont turn over. it acts as if it wants to crank but doesnt. the dash lights light up but my headlights and radio wont come on. My battery is fully charged and my alternator is...
Sounds like the starter may have some issues. However, the headlights and radio not coming on is a sign that either the battery is not charged up sufficiently, or there are some blown fuses.
Also, the connections should be checked at the battery for corrosion which can block the electricity from flowing freely from a 'charged' battery to the starter or the lights.
Good luck on this repair.
Jan 12, 2011 | 1995 Chevrolet Silverado 2500
Battery not charging light comes on at idle rmp
SOUND LIKE ALTERNATOR NOT CHARGING BATTERY.BEFORE BUYING A NEW ALTERNATOR CHECK ALTERNATOR WIRES AND FUSE.IF YOU HAVE TO REMOVE ALTERNATOR.TURN OFF RADIO BEFORE REMOVING NEGATIVE BATTERY CABLE.SO YOU WONT LOSE PLAYING CODE.
Apr 18, 2010 | 1998 Cadillac DeVille
My 03 x type jag wont even try to turn over? Dash lights are fine but windows, mirrors and starter dead! All the dash lights and monitor and radio work but wont even tryto start? Transmittion wont come out...
Sounds like all of the high drain devices are disabled due to a weak battery. You are still getting dash lights and radio because they are very low drain devices. Try charging the battery to test for now. It could be a failing battery, or your alternator and or voltage regulator could be going out and not charging the system. But first, try to charge the battery, and see if you can start it, if you can, let it run for at least 10 minutes. If your alternator/VR is going out or is already out, you should have a guage, or idiot light telling you that you have low voltage. If its a light, you should see a red battery lit up on the dash, if its a guage, it should be directly in the middle +/- a little. If you are able to run the vehicle for a while with no light coming on, or guage showing low voltage, its safe to say you drained the battery, or it is failing. If its a few years old or more, i'd go ahead and replace it. Hope this helps :)
Sep 17, 2009 | 2003 Jaguar X-Type
94 4.3 wont start
CHECK THE FUSIBLE LINK THAT COMES OFF THE STARTER POST.THEY LOOK JUST LIKE A WIRE, BUT THEY GET STRECHY WHEN THERE'RE BLOWN.IF THIS IS THE CASE YOU WILL NEED TO FIND THE CIRCUT THAT CAUSED IT TO BLOW,AND REPLACE THE LINK.
Aug 24, 2008 | 2004 GMC Safari
Cobra LI 7020 WX-EVP  Two Way Radio Logo
22 people viewed this question
Top Cobra Radio Communications Experts
Steve
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
