Question about Gateway M305CRV Notebook
Fan error - Gateway M305CRV
Hi, I'm getting a fan error on boot, before OS loads... F1 to continue, F2 to enter Setup. The machine will work but misbehaves when it gets hot.
I want to replace the fan... how easy is this, and is it the CPU fan it refers to or another internal fan?
J
    Scholar:
  • 103 Answers
There should only be one processor fan in this model. The computer may allow you to continue to work, but you should refrain from doing this due to the potential heat damage to your Processor. The reason it "misbehaves" is because as the computer heats up, the processor loses functionality. Usually the end result is that the computer will lock up or crash. Occasionally you melt your processor and it must be replaced.
In terms of replacing a fan, it is more on the intermediate side of laptop repair. If you have never taken a laptop apart before, I would think really hard about doing so, or go to a website like www.eServiceinfo.com that sells repair manuals for your laptop. It will take a good amount of mechanical aptitude to do this and some knowledge of electronics.
Due to the age of the computer, it would not be cost effective to take it to a repair shop since it may cost you almost what it would be to buy a new one of the same model.
Posted on Apr 21, 2008
How to enter bios on gateway LT2802u?
i can tell you what to try... its going to be the delete key, f2, f10, or f12... when the machine is first starting to turn on (boot) steadily tap one of those keys and it will get you into the bios. try del first, if that doesn't work, then try f2... go down the line, one of them should work for you.
May 08, 2014 | Gateway M305CRV Notebook
My dell gx 270 desktop shows alert! previous fan failer. Press F1 to continue and F2 to run setup utlity. How to solve it?
The fan failure alert on your Dell, is caused by the timings. There is no bios settings, for this. You need a new fan that runs at 1400rpm or more. This will solve the problem, also a clean install solves this problem. Best to buy a new quite fan, keep the 5pin header from the old fan copy the wire colour for the pins, make sure the fan is pwm. In the worst case, you will have to change fan, and overwrite harddrive and do a clean os install. This will fix problem, other methods, like fan speed software will redduce the fan speed cook your motherboard, but will not solve the fan failure alert. Also enter bios by pressing f2 and clear log error before you install new fan and os.
l
Aug 18, 2011 | Dell OptiPlex GX270 PC Desktop
Start-up and shut down problems, When starting up it says, press f1 to continue, f2 to run set-up.... F1 works but I am getting tired of doing this. Now when the computer starts, it stops at...
Hi names Rui,
For your problem the computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this may be caused by any of the below reasons.
  1. New hardware has been recently installed.
  2. Error or confliction with settings in CMOS.
  3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS. Enter CMOS setup and save the settings and exit. If you continue to get errors continue to the next step.
If no new hardware has been added or you continue to get this prompt verify no error or conflictions exist in CMOS. Press the key to enter setup and verify that all settings are correct.
If your time and date are not set correctly, your battery is more than likely bad. Try setting the correct time and date, save the settings and then reboot. If after turning off the computer the time and date get reset again replace the battery.
If the time and date are correct and everything else appears to be correct try resetting the CMOS values to the defaults.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, your CMOS battery is bad. We recommended that the CMOS battery be replaced.
hope this will help you.
Jul 20, 2011 | Dell Dimension 2400 PC Desktop
Strike F1 to continue, F2 to run the setup utility
Got to BIOS by pressing F2,check or any floppy setting and disable it even in boot order setup.This will solve your problem otherwise replace the lithium CMOS battery.
As you have reset the BIOS setting to it's default setting.Floppy drive is enable by default whether your system have a physical floppy drive or not.
Dec 24, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Disk Boot Failure
Any system can be recovered, although it depends on what is wrong.. this error can mean no info on the hard disk, or damaged hd...more than likely whoever had the computer erased it for data's sake...I would've...get an os and load it.
Aug 08, 2009 | Computers & Internet
I have to hit the f1 key to continue the bootup process. Then I get a defective fan error message, but the fan is running, becasue I can hear it.
there may be more than one fan-- there also is a setting in the BIOS to disable the fan warning if you are SURE that the fan it is monitoring is working correctly.
Jun 24, 2009 | Gateway M350 Notebook
Strike F1 key to continue, F2 to run the setup utility
Please let me know what is the make and the model of the pc that you are using.. Also, go to the bios, under boot menu, make sure that you have hard drive as the first boot option.. For further queries please get in touch..
May 28, 2009 | Computers & Internet
MY LAPTOP(hp compaq presario v2000)BEEPS TWICE AND DISPLAYS PRESS F1 TO RESUME OR F2 TO SETUP!pls help
Hi, and welcome to FixYa
The computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this issue can be caused by any of the below possibilities.
Solution:
If no new hardware has been added to the computer or the new hardware has been removed and you continue to receive the error, it is likely that there is an error or confliction with the CMOS. Press the key requested to enter setup and verify that all settings are correct. If everything appears to be correct try resetting the CMOS values to the defaults and/or Reset Configuration Data. Additional information about how to do this can be found on document CH000976.
If all settings appear to be correct, save changes and exit CMOS setup. If the error continues to appear, enter setup again and restore all CMOS values to default.
· See our CMOS page for additional help and information with the CMOS.
· Additional information about getting into the CMOS / BIOS setup can be found on document CH000192.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, it is also possible that the CMOS battery may be bad or failing. Generally; when this occurs, the computer is not holding the time or date correctly. If this is occurring it is recommended that the CMOS battery be replaced.
regards
/Teis the Wiz - -> Vote "FixYa" :-)
Dec 05, 2008 | Computers & Internet
Unable to get to CMOS using any of the 3 methods
This machine is one of the first "legacy free" models which means there are no BIOS options to change. All settings and resources must be assigned by the OS.
For details, please check the "legacy free" FAQ on MS Knowledge base.
If you are trying to access the BIOS to change boot order so that you can boot from a CD, hold down the 'c' key during POST/boot. This will case your laptop to boot from CD-ROM.
Apr 09, 2008 | Toshiba Satellite 5005-S504 Notebook
To unlock my mobile
IBM compatible users may need to enter the BIOS or CMOS setup to setup or change how their computer's hardware is currently configured.
Solution: Because of the wide variety of computer manufacturers and BIOS manufacturers over the evolution of computers, there have been numerous different ways to enter the BIOS or CMOS Setup. Below is a listing of the majority of these methods as well as other recommendations for entering the BIOS setup.
Notice: If you are unable to get into the BIOS or CMOS setup because of a password please see document CH000235.
New computers Thankfully, computers that have been manufactured in the last few years will allow you to enter the CMOS by pressing one of the below five keys during the boot.
A user will know when to press this key when they see a message similar to the below example as the computer is booting. Some older computers may also display a flashing block to indicate when to press the F1 or F2 keys.
Press <F2> to enter BIOS setup
Tip: If your computer is a new computer and you are unsure of what key to press when the computer is booting, try pressing and holding any key on the keyboard. This will cause a stuck key error, which may allow you to enter the BIOS setup.
steps dont work for ya above:Try this :
Go to start
control panel
Click on User account
click on computer administrator.
Dec 04, 2007 | Gateway M305CRV Notebook
Gateway M305CRV Notebook Logo
1,004 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
