Question about Hamilton Beach 3-in-One (33134) 6-Quart Slow Cooker
Cooker's setting have rubbed off
The settings on my slow cooker are gone so I don't know which is low, etc.high,
  • 4 Answers
SOURCE: Rival 38651-C 6-Quart Slow Cooker
I is low setting and II is high
Posted on Nov 02, 2008
SOURCE: hamilton beach 3 in 1 slow cooker
You can call Hamilton beach Long wait on phone, but YOU CAN ORDER THE Crocks and Lids 1-800-937-8997. You can not order on line!
Posted on Apr 08, 2009
SOURCE: ronson slow cooker don't know which is high or low
on setting 1 (low),the slow cooker can operate all day and night if required
when set to 2 (high) it is very much like a covered pot on the stove.food will cook in half the required time
AUTO the slow cooker will cook on 2 (high) until the food reaches a pre-set temperature,then switches to 1(low) and maintains a constant slow cooking temperature.Auto is ideal for someone who is leaving the house for the day 8-9 hours please feel free to share this information.If you have any more ? please fell free to contact me.
bianca
Posted on Jun 15, 2009
SOURCE: Not sure high or low on the Ronson slow cooker
I just rang Ronson (co- Breville Group 1800800634) as I have the same problem. They have confirmed that 1 is low.
Posted on Sep 01, 2009
joedirty
  • 158 Answers
SOURCE: Hamilton Beach slow cooker stoneware replacement
http://www.hamiltonbeach.com/contact-us/warranty-usa.php
Posted on Oct 22, 2009
Della 12 Quart 1600-Watt Electric Pressure Cooker Multi-Functional Timer Slow Cook XL Part number: 048-GM-48261 Unable to get this cooker to slow cook.
it is possible that you have misunderstood the instructions
for a slow cooker you have low medium and high
press slow cook and on low and in 8 hours the food is cooked
I see from your statements that you expect the cooker to be set on slow cook but cook at a high temperature fast
if it says slow cook --9 hours and the temp is 125 degrees , have you waited 9 hours to see if it is cooked as the slow cooking process is by the gradual build up of heat in the container that is not expelled by radiation to the air
in a pressure cooker , that build up of heat also builds up pressure and so it cooks better
other solution--- if it is not right return it for a warranty refund or if out of warranty , junk it and get a different make
Mar 25, 2017 | Crock Pots & Slow Cookers
I pushed the cook time button but it still says zero what do I do
Hit the on/off button, so that the cooker looks like it is off, then hit the cook time button up the the number of hours you need to cook. This slow cooker has three settings: LOW, HIGH and WARM..... When your corningware slow cooker is initially plugged into a wall outlet, the display will show "0". This display indicates the programmed number of hours for which ameal will cook. The slow cooker can be programed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears. If 1,2,3,4,5, or 6 hours are selected, then the slow cooker will operate on the high setting. If 7,8,9, or 10 hours are selected then the slow cooker will operate on the low setting. To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the warm setting.
May 11, 2010
Nov 19, 2012 | CorningWare SC60 Slow Cooker
I have Ronson slow cooker with no manual, it has settings 1,2 qnd auto. Which is high and low, and what does auto setting do>
I also have a Ronson slow cooker.
Instructions from the book read as follows:
- On setting 1 (low), the slow cooker can operate all day and night if required.
- When set to 2 (high), it is very much like a covered pot on the stove. Foods will cook in half the time required for 1 (low).
- When set to auto, the slow cooker will cook on 2 (high) until the food reaches a pre-set temperature, then switches to 1 (low) and maintains a constant slow cooking temperature. Auto is the ideal setting for someone leaving the house for the whole day as most food will cook for 8-9 hours and be ready to serve when they return.
I always use the auto setting, unless I don't have as much time, and will then use setting 2.
Sep 15, 2010 | Crock Pots & Slow Cookers
Slow cooker will only stay on warm. How do I put
This slow cooker has 3 settings LOW, HIGH, & WARM
When you plug the slow cooker in the display should show a "0". When you press the "COOK TIME" button, the display should go to 1 then 2 then 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the "HIGH" setting. If 7,8,9, or 10 hours are selected, then the slow cooker will operate on the "LOW" setting. To start the cooking cycle press the "ON/OFF" button. To interrupt the cooking cycle at any time, press the "ON/OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the "WARM" setting. If the "ON/OFF" button is pressed when the the digital display shows "0", then the slow cooker will automatically start on the "WARM" setting.
If the "COOK TIME" button does not change the display numbers then unplug the slow cooker and hold both buttons down as you plug the slow cooker in. Keep the buttons pressed for a count of ten, then release them and the slow cooker should work correctly
Feb 11, 2010 | CorningWare SC60 Slow Cooker
Need a manual for the corningware sc60
The manual basically says... This slow cooker has 3 settings LOW, HIGH, and WARM. W hen you plug the slow cooker in the display shows "0". When you press the "COOK TIME" button, the display should go from 0 to 1 to 2 to 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the HIGH setting. If 7,8,9,or 10 hours are selected, the slow cooker will operate on the LOW setting. To start the cooking cycle, press the "ON/OFF" button. To interrupt the cooking cycle at any tim, press the "ON?OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the WARM setting. If the "ON/OFF" button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
If the "COOK TIME" button does not change the display numbers, unplug the slow cooker. Hold down both buttons and plug the slow cooker in and keep them pressed down for a count of 10. Release the buttons and the slow cooker should work now.
Nov 28, 2009 | CorningWare SC60 Slow Cooker
Ronson slow cooker don't know which is high or low
bianca
Jun 12, 2009 | Crock Pots & Slow Cookers
Lost Manual - not sure which is high or low
Hi. I'm a Ronson Service Centre.
I grabbled this blurb from a Ronson Slow Cooker Manual. Not the same model, but it has the same settings:
On Setting 1 (Low) the Slow Cooker can operate all day and night if required.
When set to 2 (High) it is very much like a covered pot on the stove. Foods will cook in ½ the time required for 1 (Low)
When set to Auto, the Slow Cooker will cook on 2 until the food reaches a pre-set temperature, then switches to 1 and maintains a constant slow cooking temperature.
“Auto” is the ideal setting for someone leaving the house for the whole day as most food will cook for 8-9 hours and be ready to serve when they return.
Mar 15, 2009 | Crock Pots & Slow Cookers
Corningware slow cooker 6qt
If you choose the auto selection the slow cooker will cook for three hours on high then will automatically reduce to the low setting.
Aug 22, 2008 | Crock Pots & Slow Cookers
We are having difficulty timing our slow cooker recipes in the KC271LC .
The manual doesn't say what the levels are, but the cover says the AC power rating is 340 watts. Most of that would be going to the heater, and low temp should be about half that. If you need a copy of the manual, here's the download link:
http://www.euro-pro.com/europro/manuals/KC271LC.pdf
Oct 31, 2007 | Euro-Pro KC271LC Slow Cooker
Hamilton Beach 3-in-One (33134) 6-Quart Slow Cooker Logo
67 people viewed this question
Top Hamilton Beach Crock Pots & Slow Cookers Experts
Mohamed Ismail
Mohamed Ismail
Lawrence Oravetz
Are you a Hamilton Beach Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
