Question about Directron Com PCC-ST3 Personal Web Camera
Cam Im trying to use my cam, when i click to activate it, it doesnt show me it show a yellow face and says Please launch live! Cam Avatar. How do i get rid of this to put myself back on the cam?
  • Anonymous Dec 24, 2008
    same thing with me
    cant get rid of avatar
    tried uninstalling but nothing would do
    **** application
  • Anonymous Apr 14, 2009
    try to uninstall under control panel but says setup.exe has stopped working
I just bought a new webcam, the iHome Mylife Web camera.. and it keeps auto focusing! How do I get it to just stay on one focus level?
Hi - Try this:
1) In the Crazy Talk Cam Suite that came with the camera, click the Settings button.
2) The Settings dialog box displays. Select the Avatar Live! tab, unselect Face tracking to trigger head movement. Click OK.
3) In the main Crazy Talk Cam Suite window, unselect Enable Facial Tracking.
Good Luck, Mikeywaf
Mar 10, 2011 | Cameras
Cant adjust color to cam cant find sit on menu
Launch the logitech webcam toolbar from your Desktop
Start your webcam from the Quick Capture menu ( 2 film frame pic) Open the settings menu (2 gear wheel pic)
Open the "webcam settings" sub menu by clicking on the webcam icon
Adjust your colour from here
Jun 23, 2010 | Logitech QuickCam Pro 5000 Webcam
Avatar stayss on while we haveskype on and it wont
Are you using a Dell ? if so
To remove it, you need > Start > Control Panel- > Add/Remove programs -> Remove Live Cam Avatar. It might appear in more than one place
check your Skype set up
Before you can use your webcam in any chat program you have to configure it to that program
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
working OK ?
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
Apr 25, 2010 | Creative Labs Live! Cam Optia Pro Webcam
Driver cant detect webcam
Follow the instructions below and it will work.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program.
When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the
camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function
properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and
Speakers to the computer Audio Card.
2. Then click on the Video Settings.
3. The camera if Installed Properly will come up and show a video picture.
4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to
see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
(http://www.soft32.com/download_30.html )
1. Go to Messenger at the top left and click on it.
2. Next go down to Preferences and click on it.
3. Next Calling and Devices on the right and set the Microphone and Speakers to the
4. Next go to the Test Audio section and (in blue writing) click on “Open the call
setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
1. After you start Windows Live Messenger, expand the view by clicking on the square on
top left next to the red X.
2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.”
And then click on “Show the Menu Bar”.
3. Next go to the Menu Bar on right side, click on “ “Action.”
4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or
friends you are connected to.
D. AIM (AOL) Messenger
1. On the VIM sign-in window click on Edit.
2. Then click on Settings Enhanced IM.
3. Next click on Enhanced IM.
4. Then click on Audio Video.
5. The Audio and Video portion has drop downs so you can select the proper audio card and
video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window.
If you are currently participating in an AOL Live Video IM session, a message will display:
You must disconnect the current AOL Live Video IM conversation before running setup. Would you
like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers
and microphone are working properly. Follow the on-screen prompts.
Notes:
· The first time you use AOL Live Video IM, a message will display: Would you like to
first check your audio and video settings? Click the Yes button. The Audio and Video Tuning
Wizard will appear to help you verify that your camera, speakers and microphone are working
· images in AOL Live Video IM may appear reversed, or as a mirror image (text may
appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
After you get your camera installed properly, DO NOT unplug it from the USB port as it will
cause the drivers to be corrupt and render the camera unusable till reinstalled it properly.
Hope this helps. Bud
Sep 28, 2009 | Creative Labs WebCam Live!
Windows Live Messenge Cam Error
you need to configure your cam for msn
on top left next to the red X.
right side, click on “ “Show Menus.” And then click
Next go to the Menu Bar on right side, click on Action.
Jan 13, 2009 | Microsoft LifeCam NX-6000 Webcam
I need help with my acer orbicam 5610
http://www.theacerguy.com/category/orbicam/
Please try this site or go to the Acer site and download the drivers you need and for the orbicam. Just click on the driver to activate and your computer will do the rest.
Good Luck
Fehdi
Dec 19, 2008 | Computers & Internet
Philips web cam spc110nc
Philips Webcam SPC110NC doesnt work with Yahoo Messenger as advertised. Packaging says it works with MSN/Yahoo/AIM, but when troubleshooting Yahoo IM using AMCAP.EXE (as per the Yahoo webcam help site), it shows color space/compression used by this product is MJPG and this is the only option. Yahoo IM only supports RGB 24, I420, or IYUV.
Sep 07, 2008 | Philips J44414
Avatar and Face Accessories don't appear
Your cam may not support the effects, but still uses the same software package.
Just use manycam... it's free, and it works.
www.manycam.com
Aug 20, 2007 | Logitech QuickCam Express Web Camera
Taking pics with my cam
Try going to My Computer and see if the camera shows as a device there. If it does, double click on it. The webcam I have (a Logitech) will then show a live preview window with an option to take a picture over on the left-hand side of the window. If you do not have options on the left-hand side, go to Tools, Folder Options and select Show Common Tasks In Folder and click Ok. I hope this helps.
Jul 28, 2007 | Philips SPC700NC Webcam
Directron Com PCC-ST3 Personal Web Camera Logo
838 people viewed this question
Top Directron Com Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a Directron Com Computer and Internet Expert? Answer questions, earn points and help others
