Question about LG LSC27910TT (265 cu ft) Side by Side Commercial Refrigerator
My LG LSC27910TT refrigerator stopped working suddenly
  • 713 Answers
Hi, It's either the start device on the compressor or you have a bad compressor. You'll have to pull it away from the wall and take the bottom back panel off to check the compressor. It will likely be real hot to the touch from what you described happening. If there is a little white colored box on the left side take that off and remove the wires, etc. and shake it... if it rattles and debris falls out then that's the problem. It's fairly common and they make a kit to replace it with a better designed part that's real easy to install yourself. If your compressor has a label on it with a blue indian head symbol, then you're out of luck as that brand pretty much sucks and is destroyed by heat. It would mean a new compressor and then you'd be lucky if the new one even worked from the factory. Avoid those Tecumseh compressors at all cost.
Posted on Jul 19, 2010
This same problem just happened the same model Refriderator LSC27910.
Posted on Nov 22, 2011
3 Suggested Answers
  • 161 Answers
SOURCE: My LG side refrigerator and freezer LG LSC27910TT
You have a bad main board. Call LG customer service for your options.
Posted on Jan 24, 2010
heatman101
  • 43501 Answers
SOURCE: Hey our refrigerator has stopped
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 11, 2010
How do I fix the water dispenser on my LG refrigerator?
#1 cause is the water filter. There may be other blockages in the line. Change the filter one more time and allow the air to purge out of the line. You will make a mess.
Nov 12, 2014 | LG LSC27910TT (265 cu ft) Side by Side...
My LG lsc27910tt ice maker arm is stuck in the up position and won't budge.
there is a good chance that some ice has jammed in there somehow. have you tried defrosting the machine... that would be the first thing to try.
Oct 11, 2014 | LG LSC27910TT (265 cu ft) Side by Side...
How to investigate the problem with the ice dispenser on my LG LSC27910TT?
what is it doing? is it making ice? is water getting to the tray? are ice cubes small? large?
Jun 05, 2014 | LG LSC27910TT (265 cu ft) Side by Side...
Hi, our LG LSC27910TT just lost complete power. Tried other outlets...nothing. It's only 3 years old and of course warrenty has expired. Any suggestions or if anyone else had this issue do you know...
More then likely you have a blowen fuse on motherboard. remove cover after you unplug the box. the cover might be on top or back of box. the fuse is on the board. It looks like old car fuse. you should be able to buy at sears. If this dont work you will have to change the board. hope this helps.
Aug 20, 2011 | LG LSC27910TT (265 cu ft) Side by Side...
Hey our refrigerator has stopped working completely. There is no power being accepted by the machine and it has completelly shut down and will not start up again. What should we do? It is an LG LSC27910TT
heatman101
Sep 10, 2010 | LG LSC27910TT (265 cu ft) Side by Side...
I own a LG LSC27910TT fridge, and it is not running, i checked the breaker and it is on, i also plugged another item into the outlet and it works. Please help. I sthere an internal fuse that may be bad?
check the rtc overload contactor on the side of the units compressor,it supplies power to the compressor,remove it and if it rattles when shook,this is a good sign its defective
Feb 23, 2010 | LG LSC26905TT Side by Side Refrigerator
LG LSC27910TT (265 cu ft) Side by Side Commercial Refrigerator Logo
612 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
