Question about Samsung HT-Z310T Theater System
Error message "Protect"
When i switch on the device it says "Protect". Please help
  • 4,234 Answers
The protect message indicates that a problem was detecteed in the final stage of the amplifier and the unit has shutdown to prevent further damage. Disconnect the speakers and try again. If hte message remains, the problem is internal to the unit and will require repair. Typically this involves the replacing of the final stage be it an IC or discrete transistors.
Hope this helps,
Dan
Posted on Jul 22, 2010
  • ABRsvcs Jul 25, 2010
    I'mnot sure what you thought we could do here, but your unit likely has a physical problem that a reset won't fix. If you can post the results of the simple test I suggested, I may be able to get you more detailed repair information.
    Thanks,
    Dan
  • 3 Answers
You can try to hold the stop button down for 5 seconds while the power is off to reset. If that doesn't work disconnect all the cables from the back expect the speaker cables and the power cable. then turn the unit on and reconnect the cables once the unit is on.
Card error message
try it. if it's write protectred than you cannot save pictures on it
Sep 18, 2013 | FUJIFILM FinePix XP10 XP11 Digital Camera
Wat is write protect
It's the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card, allowing the camera (or any other device) to write to the card.
Mar 18, 2011 | GE Cameras
I can't to format my 8 G flash(message:write protect) i used the Repair_v2.9.1.1.exe ,but it message that the usb flash not found. plz help me
Any time you see "write protect" it usually means there is a small switch on the device which prevents deleting data accidentally, even by writing over it.
Look for a small sliding switch and flip it to opposite position. That should fix it.
Dec 23, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
When I turn on my kodak easyshare c813 camera, I can't get past the ''Memory card is protected'' error message. Any ideas?
Yup.  Quite often on media cards there's a tiny switch to write-protect the card so important files can't be overwritten/deleted.  Simply put the switch to the other position and you'll be able to take photos again.
Please rate me if you found this helpful.  Thanks.
Mar 09, 2010 | Kodak Easyshare C813 Digital Camera
When i switch my navigon 3300 max on it says startup error! please check setup. how can i fix it?
I have updated and started my Navigon 4310 max and suddenly it gave an error message saying "Startup error! Please check setup" then it stops. I tried many times by switching it on and off but it didn't help. Please help me what to do!!!
Feb 02, 2010 | Navigon 3300 Max Car GPS Receiver
Memory card write protect?
i had same problem..couldn't solve it with tape over the lock switch and many other ways.. so i purchased a usb card reader (about $5 max) and now it works fine!...just make sure the lock is off!
Jun 02, 2009 | SanDisk 1GB microSD Memory Card
How to Unprotect a Write Protect Flash Drive
how to unprotect a write protect my flash drive & i cant copy paste any of my files to my flash drive it gives an error
error drive not found
Oct 18, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Waste ink near full error message
Canon Error Codes
L5000,5500,7000,8000: To enter service mode Data Registration, #, Ram Clear is under #8 clear
Faxphone 20 ram clear
Turn off the power switch
Turn off the memory protect switch (located on the bottom of the machine)
Turn the power on
Press function # 2 0 start
Turn the power switch off
Turn on the memory protect switch
Fax L770 fuser gear wears out easily under heavy usage. White gear with 2 sets of teeth.
Inkjet models such as the B160 will hold faxes in memory and refuse to print if excess ink has accumulated on the pad under the cartridge's nose. Remove the cartridge and wipe up excess ink with a cotton swab.
Nov 01, 2007 | Canon PIXMA MP780 All-In-One InkJet...
"Memory card is protected"
This error message indicates that the memory card is locked. The switch on the memory card is in the write-protect position. Reset the switch as shown on the camera screen.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Samsung HT-Z310T Theater System Logo
302 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
