Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
My mower wont run. Unless I put gas in the carb...please help...
I think my mower is doing the same thing. There is no fuel getting to the carb but there is fuel being pumped through the filter. I took the bowl off the carb hoping I would find an obvious problem but nothing looked out of place. Get this, when I put the bowl back on the carb, it started! I mowed the lawn thinking I inadvertantly fixed the problem. A week later I went to mow again and the same thing happened agian, it wouldn't start. So, I did the same thing and took the bowl off the carb, looked at it and again nothing looked out of place, put the bowl back on and again, it started!
I think the float is somehow sticking. When I look at the inside of the bowl it has slight vertical rub marks as if the float is rubbing and possibly sticking to the side of the bowl but why would it start doing this after two years? I'm no expert technician but I know floats don't grow and bowls don't shrink. Hopefully someone out there will have a solution for both of us...any takers?
Posted on Aug 20, 2010
Lawn mower instructions why wont it work
check for spark at plug if spark at plug then squirt some starting starting fluid in carb see if will start it should run long enough to burn out starting fluid if does check for water in gas if is drain tank and carb bowl put in fresh gas not and repeat not old gas you were using strat lawn mower if still dosnt start rebuild carb and add and additive called seafoam to the gas this is good stuff follow instrution on bottle
Sep 02, 2014 | Garden
MY LAWN MOWER WONT START AND RUN UNLESS I POUR GAS IN THE CARB INTAKE . PUT NEW FUEL PUMP DIDNT MAKE A DIFFERENCE .WHAT IS THE ELECTRICAL PART ON THE BOTTOM OF THE CARB
The electrical part on the bottom of the carb is a fuel shut off solenoid. When you turn the key on, the plunger inside this mechanism retracts, allowing fuel to enter the carb. If you remove this it is easy to bench test with an alternate power source. Hope this helps.
Sep 11, 2013 | Husqvarna Lawn Tractor  25 HP 54in Deck...
Truck wont start unless i put gas in carb and once it starts it wont stay running unless foot is on pedle
is this a carb model or a injection and what year and model would be of a help
Nov 12, 2012 | GMC Cars & Trucks
My b&s 6.5hp log splitter wont stay running unless i spray gas directly into the carb... this is where it's get funny, i took a carb off my
If your gas is E-10 then there is a strong possibility that the line from the tank is blocked, also could be a filter and even sludge in the gas tank all caused by E-10 seperating and becoming thick.
Sep 11, 2012 | Briggs & Stratton Briggs Stratton...
KEEP GOING ONLY IF YOU KEEP PUSHING THE PRIMER BUTTON
You have a clog in the gas flowing into the carburetor. Get some carb cleaner (the spray kind is fine). Drain or siphon the gas out of your mower and discard. Put a little fresh gas and a little carb cleaner in the tank. Run it through. Do this a few times if necessary. When you get new gas, add a gas stabilizer like Sea Foam.
May 05, 2010 | Mtd 22" Yard Machine Push Mower
Craftman 11 lawn mower...wont start have checked the plugs and it has spark and the carb works fine but still does not run...please help
Hi..my name is Keith..and if you have sparkand it wont start..i would suspect old gas..lawn mowers are very sensitive to gasoline..and it likes fresh gas..but if you do have gas in it that is more than a month old..it needs to be drained and not mixed with fresh gas..but im just going on what you are saying about having spark and the carb is working fine..i hope this has helped..if not please write me back
Jul 04, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Try to start mower and turns over but wont start unless you pour gas in carb then it will start and run fine. 1648s scotts mower with a kohler motor.
Does it continue to run after you start it by pouring gas into the carburetor or does it die again?
If it continues to run, it sounds like your choke is not working. Probably disconnected -- check linkage.
May 05, 2009 | Garden
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
297 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
