Question about E-Machines eMachines Desktop PC
Will not turn and will not stop beeping - E-Machines eMachines Desktop PC
    Problem Solver:
  • 8 Answers
Could be the problem that many people have have with the power supply killing the motherboard.  If the power supply is a Bestec ATX-250-12E then you most likely will have to replace the motherboard & power supply.    Which model of Emachine do you have?
Posted on Jul 20, 2010
  • E-Machines Master
  • 5,528 Answers
Beep codes can tell you what is wrong with your computer. (Assuming your motherboard uses the IBM codes that many manufacturer's use) If the continuous beeping involves long beeps, it's a memory issue. Pull out and reseat the sticks. (Try them one at a time). This involves opening the case, pushing down the clips on the ends of the memory stick and then pulling them up and pushing them back (keep the orientation the same and aligned). The memory is fully seated when the clips pop back into the memory stick's edge (there is a little shaped area that the clip fits into.).
If you here high-low beeps, then you have a CPU overheating issue.
Check your manual for the specifics on your machine's BIOS and then you can search for the beep codes for that motherboard.
I hope this helps.
(IBM is the only one with any continuous beep codes that I know; most codes have a repeat pattern with a short break to indicate the end of the code)
Posted on Jul 19, 2010
  • Nathan Beckman
    Nathan Beckman Mar 04, 2012
    I changed my cmos battery and removed the second stick of ram; it works now!
When i turn my syncmaster 2233 computer, it turns on but it makes a beeping sound alot of times and it won't stop.. I usually fix it by turning the power cable on and off and it will stop the beeping...
Remove the memory (RAM). Clean its contact points by an eraser. Fix it. If it does not work, try using another slot. If it still does not work,replace it with new.
sonsunny
Jun 14, 2011 | Computers & Internet
When you turn on the computer it makes a series of stringed beeps for a second also when turning it off, keyboard and mouse does not work
what's the beep pateren it does? here is the basic beep codes:.....
Error Code: Faulty Component:
1 short beep None (Normal Boot)
2 short beeps POST error
Non-stop beep Power supply or system board
1 long beep and 1 short beep System board
1 long beep and 2 short beeps Video card
1 long beep and 3 short beeps Memory
3 long beeps Keyboard
Non-stop short beeps Power supply or system board
(a key on the keyboard might
also be stuck)
None Power supply, system board,
or system case built-in speaker
Oct 01, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
My refrigerator beeps 5 times every few minutes and won't stop. The doors are closed. I forgot to turn it back on when I cleaned it yesterday so it was off for about 16 hrs. When I turned it back on, it...
The refrigerator is probably beeping because it is too warm. It has a sensor thaat will make it beep to warn you if it gets too warm. After being off for such a long time it will take a long time to get it cold enough again to stop the beeping. Give it time and it will stop.
Nov 16, 2009 | Electrolux Refrigerators
F 1 Error, blinking, beeping and will not stop even when turned off, so we had to turn the circuit breaker off to stop the noise.
You have a leak.
Either from the top lid seal or bottom lid seal. A s time goes by the water level activates the sensor causing the beep. It won't do anything until you fix the leak.
May 25, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dryer tries to start - then stops and beeps PLEASE HELP
Check the exhaust hose. If the dryer isn't venting properly it will either stop or the heater will turn off and the clothes will remain wet. If the hose is not clogged check the wall vent tube.
Apr 29, 2009 | Fisher and Paykel Dryers
Very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Nov 23, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Kia brake beeping
brake pad warning light pads need changed
Aug 17, 2008 | 2002 Kia Sedona
Beeps none stop
check all your keys on your key board. Is one pushed down?
Jun 15, 2008 | Acer Aspire 9500 Notebook
E-Machines eMachines Desktop PC Logo
371 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
