Question about RTO Case W14 1570 2090 2290 2294 2590 3594 4490 Water Pump
Pto will run until load is applied then it will stop.There is no detent feel to the engagement cable and handle when it is engaged..I know where to adjust for the detent but maybe pressure valve or popit is stuck. Pto has not been used since last year.
2 Suggested Answers
  • 634 Answers
SOURCE: My PTO will not engage without grinding but works
when u engage u have to push in clutch and wait for spinning gears to stop the engage pto and let out clutch, excessive spinning of gears can be caused by low transmission grease also causing grinding
Posted on Jul 17, 2009
Any adjustment for hino dutro tipper pto.
When engaging the pto it is important that you have the clutch disengaged so that the pto gear is not spinning in the box.before it engages.
The pto gear runs off the counter shaft of the gear box and is spinning all the time the engine is running
when engaging the pto ,you are physically engaging a gear ( like selecting 1st gear) so you have to stop the counter shaft spinning so that the pto gear will engage with slashing
Jun 14, 2015 | Garden
Why does my engine shut off after running for awhile with PTO engaged; will restart with PTO disengaged, but shuts off when i attempt to engage PTO?
Does this only happen when the engine is warm or at operating temperature or all the time even when cold? In older engines, a 'bad ignition coil' would fail when the engine warmed up and would not start again until cool or at ambient temperature.
Apr 27, 2014 | Garden
Pto clutch electrical
1. Check battery (specific gravity and load test). 2. Check voltage going into battery while running without and with pto engaged. 3. Make sure unit is running at full throttle whenever electronic PTO is engaged otherwise it wont keep battery charged up.
Feb 24, 2014 | Garden
On my 42in cut hydro. Husqvarna, The mower will not disengage until the speed is reduced to a low idle
Before you do anything else check to make sure the blades are engaged on thier seat ( the star) and the blade bolts are tight.
If you have an electric PTO this does not apply to you.
After confirming that your blades are tight check the operation of the PTO cable and the pivot bracket by lowering the deck all the way. Laying on the ground on the discharge side of the mower you will be able to look at the components and see and touch whats not moving freely as you engage and disengage the PTO lever. Look for a stiff PTO cable, stiff pivot bracket, missing return spring, broken spindle brackets and broken deck bracket welds.
Of course you should never work on any mechanical device while it is running.
Oct 31, 2012 | Husqvarna Garden
John deere 2210 engine dies when engaging pto, seat switch good
are you sitting in the seat or have you jumped the safety switch under the seat before you engage the PTO I believe our tractors use an electric solenoid to apply hydraulic pressure to a wet clutch inside the trans axle I would think it would be OK with your chipper I have a 450 tiller that was built for the older 400 models 425 445 455 that I now use with my 2210 If I hit a large root or stone when using it with my old 445 it would stall the tractor at full power. Now with the 2210 it will actually slip the clutch on the tiller s PTO shaft I think the correct approach would be to increase your RPM s gradually or start increasing the power just as you trip the PTO switch. You want enough RPM s to create enough hydraulic pressure to run the PTO circuit so that you don t slip the wet clutch anymore than necessary and you want the RPM s low enough so that you don t shock the mechanical systems too severely at start up
Let me know how it works
Feb 02, 2012 | Garden
PTO Issue
It sounds like you got the cable to tight. The brake cable applys the brake to the pulley to help stop the blades when PTO is disengaged. With it being tight it might be applying the brake and that is the reason your blades are not running at full speed. If you keep using it that way it will wear out your brake and possibly damage a pulley. I suggest you loosen the brake cable or replace it with a new one.
Aug 31, 2009 | Garden
PTO switch shuts down tractor
if the pto bearing is locked up it will stop a motor dead this is a common problem. You will have to get a new clutch assemble. The other thing that it could be is the deck has a locked up spindle.
Aug 19, 2009 | Oregon Scientific Electric PTO Clutch for...
Briggs 14 HP Vanguard runs well until PTO is engaged
First thing u might want to check is the governor--Make sure the spring and linkage is hooked up properly and the governor is moving freely.
Jul 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
RTO Case W14 1570 2090 2290 2294 2590 3594 4490 Water Pump Logo
235 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
