Question about Dishwashers
Bosch Diswasher Have Bocsh SMU 2046 UC diswasher. Aprox. 11 years old Has always worked well. Recwntly is not cleaning at 100% as before. Seems to run through cycle as normal and sort of cleans but leaves stains in coffee cups and flatware seems filmy, sometimes a little guk left on dishes, all uncharacteristic of past performance. Tried a thermometer during cycle and water temp is around 151 F during wash, 136 F at rince. and 154 F at dry time. Have checked arms for cloging and are free wheeling. What's left to look at except sort of cleaned dishes ? Any insight to this problem would be greatly appreciateg. Gerald
  • QALY Apr 22, 2008
    Thanks, Will try this, but how do you know if the pump has enough pressure?
  • 19,396 Answers
Remove the drain hose and check if you have any residual into it. After 11 years your appliance may need a thourought cleaning.
Check also if the pump has enough pressure.
Posted on Apr 22, 2008
When troubleshooting my shx46a05uc bocsh diswasher it show a flashing light on the delicate/Eco button and regular wash light stays on. What does that tell me?
sounds like the electronic switch usually a Thyristor is not switching when you push the eco button, You could try disconnecting the the machine from the mains then push the buttong in and out a few times to see if the push button has a bit of dust on the contacts..
Sep 18, 2013 | Bosch 24 in. SHX46A05UC Built-In...
What year is Bosch dishwasher SMU 4052 UC?
The FD number will tell you manufacture date
eg 8709
09 = sept
87 = 2007
9103
03 = march
91 = 2011
Hope this helps
If you can't work it out, message me you FD
Mar 01, 2013 | Dishwashers
I have a bosch diswasher which is quite a few years old no sgs3042gb/03. the water isn't getting hot and it doesn't dry?any help will be grateful
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 13, 2011 | Bosch Dishwashers
Early in the wash cycle, my Bosch diswasher makes a chirping soun
yes the problem from the heater.
if the sound coming from boiler heater means
1)scaling on the boiler tank(tank to be cleaned).
2)check any loose connection on the heater wire.
Jan 09, 2010 | Bosch Dishwashers
Bosch diswasher SGS5942 does not heat up
this is a common problem with dishwashers.the thermostats are faulty and be replaced by someone who knows what they are doing.
Oct 24, 2009 | Dishwashers
Water does not make it to the jets
You need to take a flexible wire and stick it in each of the jet holes, all of them. Then run the machine, so the water can dissolve the soap. repeat the process w/o dishes/ soap (lather rinse...repeat)
The Best!
May 19, 2009 | Bosch Dishwashers
Bosch dishwasher
hi there,
just sent the diagram off to you.
please let me know when you get it.
thanks,
c
Oct 07, 2008 | Dishwashers
Bosch Dishwasher Model SMU 2046
First check the screen in the water inlet valve ( you have to take off the lower panel below the door and disconnect the water supply. If that doesn't work or isn't plugged, replace the valve.
Jul 09, 2008 | Dishwashers
Diswasher doesn't clean
your water heater is set too low in temp.
you can turn up the heat or get an on demand heater under your sink for the dishwasher. you get a tax rebate too.
the heater in the new washers are too small to effectively heat the water to hot.
and always add a bit of bleach to your wash. the hot water will neutralize it.
or get an old dishwasher.
Mar 24, 2008 | Kenmore Elite 45986 Front Load Washer
Dishwashers Logo
280 people viewed this question
Top Dishwashers Experts
