Question about Boating
Motor runs fine if not in gear or at low rpms wont go over 10 mphany ideas? starts to backfire and shake has a 350 mercruser in a baretta 21 foot boat 4 barrel carb
    Champion:
  • 243 Answers
This Could Be Many Things But If You want To Try A Few Yourself,
Fit New Spark Plugs,Clean The Carburetor,If It Does Not Show any Signs Of Improvement ,Nothing Lost Take It In For Diagnostic Check
Posted on Mar 30, 2013
  • 50335 Answers
SOURCE: Ihave a 1982 mercury inline-6-115hp am having carb-boat motor
floats are sticking in the carbs . rebuilding is the only cure
Posted on Apr 26, 2010
finish line
  • 207 Answers
SOURCE: 350 CID Kodiak 5.8 L chevy marine engine has water in oil
stuck thermostat bad water pump impellar about only 2 causes first check thermo should be located in the housin where all the hoses go into the motor u can check it with a pot of boiling water and a temp gaige put in water nd see what temp it opens at shop cost estimate $85.00 with part impellar estimate depending on location $200.00
Posted on Jun 27, 2009
SOURCE: I have a 1994 Yamaha 40 HP 3 cylinder 2 stroke
all 3 carbs had A  clogged jet totally dis assembled and cleaned the carbs put them back on and the engine runs great I will need to fine tone the needle valves once I put some fresh gas in it.
Thanks John
Posted on Jul 09, 2009
  • 5655 Answers
SOURCE: when the boat is in
The last comment you made about the hose cuffs and running good- Was that in gear or neutral? If you are using the boats throttle lever there is a cam lever for the choke which limits the throttle. It may be out of sync in the control box. If you have operating cables disconnect them at the engine and see what range of motion you have in the motor itself. Then hook up the controls and see if the cables prevent the motor from opening the carbs.
Posted on Aug 01, 2009
  • 5655 Answers
SOURCE: brand new 350 motor rev's fine but will not pass
We are going to assume there is no Rev limiter in the ignition circuit.
Disconnect the throttle, move the throttle lever by hand and see what RPM you pull. It should be able to go higher than when you had a load on it. Check your throttle stops.
If you have a 4 barrel with a secondary, look at the mechanical linkage. If you have a vacuum operated secondary, see if you have any open vacuum ports.
If this is a vacuum secondary, there are springs you can buy to change when the pulldown occurs.
Check for a clogged gas filter, kinked hose, or hole in the gas line before the fuel pump.
If this new engine is running the same carb and ignition as the old motor, check your base timing and advance.
If you have not used this boat before the new engine was installed check your prop pitch and size. The prop is like changing gears, you need to adjust throttle stops so you do not over rev or under rev. Let us know what you found.
Posted on Sep 16, 2009
Car was running fine all of sudden started running rough at low rpms
run the fault codes
could be a injector problem , low fuel or ignition control module problem
Oct 19, 2015 | 1995 Chevrolet Monte Carlo
2001 ford taurus, 3.0 vulcan motor. just rebuilt the whole motor, backfires out of the intake, seems to be out of firing order. i triple checked my work and can't find the problem. whistling sound of...
Back firing out of the intake is because the valves/cams are not set right. When you did the timing belt . did you set the crankshaft mark at top dead center of the compression stroke. If it's at the exhaust stroke this would cause backfiring and violent shaking.
May 22, 2011 | 2001 Ford Taurus
Backfire - Husqvarna YTH20K46
I find my 2148 runs much happier on the medium grade shell than on the cheaper gas. I did have a nasty POW, which resulted in bent pushrods, or perhaps the bent pushrods caused the POW. After replacing the pushrods, and adjusting same, the backfiring stopped altogether. knock on wood. The 21 is a B&S engine which has a propensity to the bent pushrods. Fortunately for me, my neighbor is a wiz at those fine adjustments.
Mar 22, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
1984 Aspencade backfires in midrange RPMs
1. Check timing belts and ignition timing.
2. Service carburetors
Jun 12, 2009 | 1984 Honda GL 1200 Aspencade Gold Wing
Wont keep idle, car stalls out
I had this same problem on my 2005 monte carlo, took mechanic a while to figure out it was the idle air control valve. They also replace the idle air control motor.
Jun 01, 2009 | 2005 Chevrolet Monte Carlo
Boating Logo
76 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
