Question about Durabrand DU1301 TV
What are the default settings in the picture menu
I have sony DSC-W190,i want correct menu setting ,bcos if i take a picture its not clear,i think may be menu setting changed,idnt any idea about menu setting pls help.....
If the Menu settings in the camera is changed, then I suggest you to reset the Camera back to factory default. Initializing the Camera back to factory default will set all the settings in the Camera back to factory default.
To initialize the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
You can also try a manual reset;
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
The blurry image capturing can also adjusted by changing the ISO Settings or the Scene Selection modes.
Thanks for using FixYa!
Apr 07, 2011 | Sony Cyber-shot DSC-W190 Digital Camera
My jvc is showing black and white what do i do
Hello
Just reset the picture adjustments and se whether the colour comes up or not. If not, autotune it once more.
Reset resets all picture adjustments (tint, color, picture, bright, detail, color temperature, dig.
noise clear, Color Management and Dynamic Gamma) at once to the default settings.
Press the MENU button
To RESET
Use [up-down-prog up-prog dn buttons] To enter
The onscreen menu disappears for a moment,
and then the settings are reset to the default
setting for all the picture adjustments.
Press the MENU button when finished
To autotune
?† To AUTO TUNER SETUP
Up or Down button To operate
To choose CABLE or AIR
Press the OK button to start
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen
Mar 21, 2011 | JVC HD-61Z575 61" Rear Projection...
When i dial a number the phone cuts off and restarts
Please try resetting the phone to default settings and it should work. The default code should be the last 4 digits of your phone number unless you have changed it.
Restoring Phone Memory to Factory Conditions
This returns all settings to their factory default value and erases all user data including pictures, video, music, messages, contacts and downloaded applications stored on the phone.
  1. From the home screen tap MENU.
  2. Tap Settings & Tools.
  3. Scroll th screen up and tap 7.Phone Settings.
  4. Tap 5.Security, You're prompted to enter the lock code.The default lock code is the last four digits of your telephone number.
  5. Enter the Lock Code and tap DONE. The security menu appears in the display.
  6. Tap 5.Restore Phone. A prompt appears in the display asking if you wish to restore default settings and erase all user data including pictures, videos, music,messages, contacts, and downloaded applications stored on the phone.
  7. Tap Yes to reset and restore default settings or tap No to return to the Security list.
Mar 15, 2011 | Samsung Glyde SCH-u940 Cellular Phone
I messed with some of the picture settings and now i can't figure out how to change it back to normal.. help?
Go to the menu find reset
Initialisation
All camera menu and function settings will be restored to their
default values. However, values for DATE / TIME, LANGUAGE,
and VIDEO OUT will not be changed.
- Sub menus
[Yes] : A window to confi rm the
selection will be displayed.
Select the [Yes] menu and
all settings will be restored
to their defaults.
[No]* : Settings will not be restored to
their defaults.
May 06, 2010 | Samsung TL100 Digital Camera
The sound went out on my jvc hidef tv
Reset- resets all picture adjustments (tint, color, picture, bright, detail, color temperature, dig.
arrow To RESET
arrow To enter
setting for all the picture/audio adjustments.
Here is a LINK to download your owners manual
Feb 12, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Can't get the Date off the Pictures
First you have to go to the set up menu and set the correct time and date, then you can go back to the settings and select OFF for time and date. If you do not set the correct time and date , that default date stays in the picture.
Jan 21, 2009 | Polaroid i830 Digital Camera
Can't reset nikon D50 default settings
Press MENU and select the pencil icon to get to the Custom Settings Menu.
First select the "Detailed" mode under Menu > Setup (wrench) Menu > CSM menu, otherwise you'll only to get the first few items!
[R] Menu Reset: This returns everything below to factory default.
Dec 24, 2008 | Nikon D50 Digital Camera
Pictures are dark not focusing
to reset the D2x to its default settings:
1. press the Menu button.
2. scroll to the Custom Settings Menu (the pencil icon in the left column).
3. press the right side of the multi-selector to move the highlight into the menu.
4. scroll to Menu Reset.
5. press the right side of the multi-selector to move into the Reset CSM Menu window.
6. scroll to Yes.
7. press the right side of the multi-selector to reset the camera to its default settings.
Nov 03, 2008 | Nikon D2X Digital Camera
How can I set my option as 'default'?
This could be a firmware problem Tell Olympus Tech support team
Jul 20, 2007 | Olympus Camedia C-50 Zoom Digital Camera
Durabrand DU1301 TV Logo
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
