Question about Motorola FV200AA GMRS/FRS 2-Way Radio Walkie Talkie with 5 mile Range
My Binatone Marina 300 Walkie talkies give hiss & noise. Pressing menue and up or menu alone makes no difference. How can I have a quiet radio except when called?
  • andy300 Apr 23, 2008
    Many thanks for the advice. It would appear that ideally I need to purchase radios with CTCSS. What you pay for is what you get!
    Sergeant:
  • 250 Answers
Hello andy300,
Does the "RX" indicator show on the LCD screen constantly?
This radio does have a monitor function which disables the squelch control, allowing the user to listen to weak signals on the channel. Enabling this function in absence of any signals will cause the user to hear any background static or noise on the channel. You enable this function by pressing Menu + Up at the same time and disable the function by pressing Menu.
I assume that you are familiar with this function from the fact that you mention these keystrokes have no affect on the radio's behavior.
It is possible that the area you are using the radios in / channel you are using them on has a very high noise level. If the noise level is higher then the radio's automatic squelch threshold, then you would hear constant static, hiss, or white noise and the receive ("RX") indicator would show a constant signal. A local noise level can be caused by atmospheric conditions or very busy nearby adjacent-channel radio signals.
Try operating the radios on a different channel and see if that helps. If it is practical, you might try operating the radios in a different local area just to see if that has any effect at all. This would help you determine if the problem was a local one specific to the area you are operating in.
If it is local area related you might consider switching to a different model of radio that includes a Continuous Coded Squelch System (CTCSS) function (called "privacy codes" or "quiet tones" by come manufacturers. This function does not appear to be included in the model you are using and can help keep your radios silent unless you receive a call from another radio using the exact same privacy code.
If the problem persists regardless of channel or area, then you might have a problem with the radio that would require factory service.
Hope this helps. Best regards!
Ken
Go Ahead. Use Us.
Posted on Apr 22, 2008
One walkie talkie has static on every channel
It sounds like your monitor button is stuck and you are hearing the white noise. Try pressing the monitor button on your other radio and see if the noise is the same. If so, your button is stuck. If not...
Sometimes a lot of static can be an indication of a bad or poorly charged battery. To check for this trade batteries with your known good radio and see if it solves the problem.
Dec 27, 2013 | Motorola Walkie Talkie 2-Way Radio
Spy gear walkie talkie
Spy Gear walkie talkie????
You've not given me any other info, so how can I help you?
Please reply with the following info:
1. Make & Model of your radio.
2. Your question in regard to the radio, i.e,. THE PROBLEM WITH IT.
Unless I receive as much info regarding your radio, I am unable to give you an answer.
Cheers,
Peter
Mar 05, 2013 | Wild Planet Spy Gear Long Range Walkie...
How to stop crackle / hiss and be heard?
This is a simple PMR with limited features - see User Guide at http://www.manualowl.com/m/Binatone/Latitude-150/Manual/331957
Unit may be faulty so if still under Warranty return to Vendor and request replacement.
Jun 23, 2012 | Binatone Latitude 150 PMR Two Way Radio...
Binatone 950 action : hissing sound and receiver sign RX continually on. I assume it is broken but before sending it back any suggestions?
The solution for this is that you probably have it in cont. RX mode, activated by pressing the Menu and Down buttons at the same time, pressing menu should exit this function.
Jun 02, 2012 | Binatone Action 950 Long Range Two Way...
On the binatone walkie talkies (black and orange) how do you get the lock off? Thanks
It's difficult to answer without knowing which model, I know the Marina 300 came in black and orange however a few others have also had that colour variant. To remove the keylock from the Marina 300 you PRESS AND HOLD THE MENU BUTTON UNTIL THE KEY ICON DISAPPEARS. Note: The PTT, Call and Power will remain functional when keylock is on.
Nov 20, 2010 | Motorola Walkie Talkies 2-Way Radio
Do the Uniden walkie talkie (UHO36SX) on listening mode (RX) normally give out a loud rushing noise? It would be impossible to have it on in a quiet place waiting for someone to talk.
No, the radios should be silent (squelched) when not receiving a transmission. Appliances (computers, televisions, even refrigerators) can generate enough "hash" to break the squelch and give you that "rushing" noise. Make sure that the radios are at least 4 or 5 feet apart, and try moving them to different locations to clear up the problem.
Bill B
Jun 01, 2010 | Radio Communications
Have no info booklet need to get rid of feed back
To select the VOX level:
1) Enter the Menu. Advance through the Menu until
the vox icon appears on the display. The current
level (OFF, 1-3) will be indicated. Level oF (OFF)
disables VOX, while levels - set the
sensitivity of the VOX circuit.
2) Press either the up arrow or down arrow key to the desired VOX
sensitivity level. Use level 1 for increased
sensitivity to voice in normally quiet
environments, and use a higher level to reduce
undesired activation in very noisy environments.
3) Exit the Menu.
Feb 27, 2009 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
Motorola FV200AA GMRS/FRS 2-Way Radio Walkie Talkie with 5 mile Range Logo
710 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
