Question about Sea and Sea MOTORMARINE II-EX 35mm Point and Shoot Camera
I have a Sea & Sea motormarine 2, 35 mm camera. I used it about 2months ago and it was working fine. I went to use it today put new batteries in, loaded the film and shut it up. when looking in the viewfinder I can see the red light luminating on the left of the screen and the yellow light on the right. The film is not advancing and there is no response when the button is pushed as if taking a picture. I then tried the film rewind button and again no response. Any ideas whats wrong?
    New Friend:
  • 3 Answers
I have a new IN the BOX Motormarine II, you can purchase from me as well as a 16 mm 5.6 I'll throw in for $250.00. That should fix your problem.
Posted on Feb 26, 2013
4 Suggested Answers
pishta68
  • 593 Answers
SOURCE: rewind!?
If it is an SLR, there is a recessed button on the bottom of the camera that you push, then you flip the little handle out of the supply rear on top and crank clockwise, after the film is rewound and the real spins real easy, lift the supply real with the little handle and the back will pop open.
Posted on Feb 19, 2008
  • 685 Answers
SOURCE: what if the rewinding lever doesnt rewind ?
Change the batteries under the camera. This camera is electronic. With a new battery, the camera will reset the mirror and you can **** the shutter and lower the mirror. If this does not fix the problem you may have a shutter or advance problem and the camera would have to be send off for repair. Start witht he battery, that is the fix 9 out of 10 times.
Posted on Feb 28, 2010
SOURCE: Sea & Sea MOTORMARINE II-EX 35mm Film Camera
Check this manual:http://www.seaandsea.com/PDF_manuals/MOTORMARINEIIEX.pdf First read page 42 to make sure you have correctly wound the film up to avoid accidentally exposing over your pictures. Then check page 32 for instructions on removing the back panel.
Posted on Mar 14, 2011
Sea & Sea MOTORMARINE II-EX 35mm Film Camera instruction how do i get the film out
Feb 13, 2011 | Sea and Sea MOTORMARINE II-EX 35mm Point...
Hi there, I used my camera in sea for many times, always was working nice. But some days ago I went to sea and the camera stopped working the flash. I left overnight off and next day it was working...
It still amazes me how many people buy these cameras that are seemingly "waterproof" and eventually have the very same problems you are now having. The only true underwater camera is one in an underwater housing.
Oct 25, 2010 | Olympus ? 1030SW Digital Camera
The camera has barely been used since purchased some years ago, and it seems that I can't get it to do anything at all. Batteries are new, worked fine for a while then nothing. What could be wrong? Camera...
It almost certainly needs servicing.
These cameras are especially prone to jamming up due to dried out lubricant films if they are not regularly used.
Get the seals replaced at the same time as they must be replaced at least annually.
Jul 09, 2010 | Sea and Sea MX-5 35mm Point and Shoot...
I have a pretty old Pentax 35 mm that has not been used in awhile. The film advance crank is stuck. I put new batteries in it (I don't know if I needed batteries for it to advance and for the shutter to...
Given the age of the camera and the fact that it hasn't been used for a while, it's quite likely the lubricants have dried up, causing the mechanical parts to stick. I'd suggest taking it in to a reputable camera shop for a CLA (Clean-Lube-Adjust), the camera equivalent of tuning up your car.
Jul 06, 2010 | Pentax K1000 35mm SLR Camera
Disassembly of Sea and Sea Motormarine II camera
I have A Brand New still in the BOX MOTOR-Marine II contact me @ laradon611@yahoo.com. This should fix your issue.
Jun 06, 2010 | Sea and Sea MOTORMARINE II-EX 35mm Point...
What are the steps to replace engine coupler in a mercruiser 165hp
First put the boat in forward, then undo the 6 nuts that hold the outdrive to the transom, then undo the 2 nuts that hold the end of the lift cylenders to the outdrive, tie the rods up out of the way. Wiggle and pull the outdrive free, the coupler will be hanging from it. It is worth checking the support bearing in the gimbol housing as well as the u?js in the coupler.
Aug 16, 2009 | Sea and Sea MOTORMARINE II-EX 35mm Point...
Car used 2 days ago fine. Went to start today and the remote only opened the driver door. Put key in ignition and hazards went off then made a clicking noise when tried to turn over and the lights on the...
Yes, this sounds like a flat battery. You could try to get a jump start off someone else, so that you know it is definately not the engine. Otherwise, purchase a new battery and you should be fine.
Jul 25, 2009 | 1999 BMW 328 Series
Key noise how to silence on v3xx
go to menu,,,settings,,,sound settings,,,kepad tone.
Jun 17, 2009 | Sea and Sea MOTORMARINE II-EX 35mm Point...
Dimagez3 Battery Options
Hey bray598,
According to the manufacturer this camera comes with AA alkaline batteries so unless you bought defective batteries the ones you purchased should work fine. I would make sure the batteries are inserted properly, and make sure when you turn it on the battery cover and/or the memory card cover are closed. I hope this helps.
Sincerely,
Allan
Go Ahead. Use Us.
May 16, 2008 | Konica Minolta DiMAGE Z3 Digital Camera
Sea and Sea MOTORMARINE II-EX 35mm Point and Shoot Camera Logo
133 people viewed this question
Top Sea and Sea Cameras Experts
Are you a Sea and Sea Camera Expert? Answer questions, earn points and help others
