I have a goodman ac, the wires came off from my house i have a red wire and a white wire on the ac there is a yellow wire and a blue wire. does the yellow got to the red?
    Scholar:
  • 149 Answers
Check against wiring diagram white and red are line current always but I'd check against any diagram you have of the unit
Posted on Apr 21, 2008
Need wire color diagram
Black = AC hot
Red = switched AC hot
Yellow = AC hot from a another source - another control panel as an example.
White = neutral
red w/white tracer = switched neutral
Green or green w/ yellow tracer = ground/earth ground
blue = DC voltage, ie, 12vdc, 24vdc
white w/blue tracer = dc common
Brown = AC 3 pahse - phase A
Orange = AC 3 pahse - phase B
Yellow = AC 3 Phase - phase C
shileds: think of current loops
2 cond
clear or red = +
black = -(neg)
3 cond
red = power (24vdc typically for transducers)
clear = + (signal output)
black = - (signal common)
Hope this helps, oh, and any panel I have design and wired this way is easily understaood by 99% of all service and electrical people I have worked with.
Apr 15, 2015 | Cars & Trucks
Which thermostat to use 4-wire Goodman gas furnace
blue is common. never let that wire touch any other color or you will short the transformer. Use a thermostat for single stage gas heat. R=Red W=White Y=Yellow which should go to the outdoor ac contactor and C=Blue which should also go to the outdoor ac contactor. If in doubt call a qualified Heating contractor to help you install. It can get quite expensive letting the smoke out of your parts.
Aug 21, 2014 | Heating & Cooling
AC and fan work fine can't get burner to come on
Open the furnace, access the control wires going to the thermostat & jumper the white & red wires to bypass the thermostat. the control wires should consist of Red, white, green, yellow, or blue.
Dec 06, 2013 | Goodman Heating & Cooling
What does the two wires from the furnace to OD unit connect to?
measure the voltage on coil of od contactor should be 24 volts
Aug 24, 2012 | Goodman Heating & Cooling
I HAVE A GOODMAN MODEL GSC130361 I HAVE A BLUE WIRE AND YELLOW WIRE AND A RED, WHITE COMING FROM INSIDE THE HOUSE HOW DO THEY GO TOGETHER
Look at the wiring on your thermostat in the house. The wires should connect to the same terminals that they are connected to on the thermostat. Red to R, Yellow to Y, Blue may go to C or O or B, you will have to look at the thermostat to figure it out, and White will go to W or W1, look at the thermostat to make sure on that one also.
Aug 18, 2010 | Goodmans Heating & Cooling
Hi Proper way on wiring furnace.
I can give you a start, For heat only, R terminal on furnace to Red wire to R or RH terminal on thermostat. W terminal to White wire to W terminal on thermostat. G terminal to Green wire to G terminal on thermostat. This will get you heat but not air conditioning.
Jan 06, 2010 | Goodman Heating & Cooling
I need wiring manual for goodman mini split.
outside unit L1 and L2 are load (input 240vac)
then you have control voltage, usually yellow and blue (24vac) this connects to some 18/2 thermostat wire which goes inside as white and red.
note: this unit may only need 24v control which is 2 wires from the inside unit and also 3 wires 2 hot 1 ground for line voltage.
STANDARD WIRING
on the inside unit you have green, white, blue and red control wires.
on your thermostat you have white, red, yellow and green
you run the wire from the outside unit to the inside unit. then run a 18/4 wire to the thermostat if wired and join the following wires.
inside unit thermostat outside unit
green------------------------green
white-------------------------white
red----------------------------red
blue-------------------------------------------------------blue
yellow--------------------yellow
Oct 08, 2009 | Heating & Cooling
Replacing old thermostat with new digital
Wire nut or tape the black off. The red is normally 24volt supply power to the t-stat. Blue may or may not be the common. Have a voltmeter?
Jun 24, 2009 | Goodman CKL30AR30 Air Conditioner
Goodman GMP100-5 Rev Furnace Manual
I don't know where you are located, but there is a Goodman distributor in Sacramento, CA. Also in Ontario CA. They are a distributor so they may be able to help you or tell where to find someone who will help. Goodman is also known as GMC or Janitrol.
Jan 07, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
112 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
