Question about Amana Radarange Microwave Oven
Magnetron? Not heating food anymore. - Amana Radarange Microwave Oven
  • 3,037 Answers
Yes, The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts, then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Posted on Jul 20, 2010
Microwave not heating food model MA795B
1 door interlock
2 diode
3 magnetron
4 heat censer
5 dry joint on relay on timer board
6 Re: Jeff
Apr 12, 2012 | Goldstar Microwave Ovens
NO HEAT COMING OUT WHEN I HEAT UP THE FOOD.
No heat coming out because the magnetron tube which responsible for generating the microwave energy is not working anymore! You must replace it with the same rating. But before doing "condemning" the magnetron, its nearby fuse might be blown better replace it first (if blown) with the same rating its cheaper than the magnetron tube.
Hope my answer help you.
Apr 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave doesn't heat anymore just runs but nothing gets hot or warm
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts (including a fuse and the diodes), then most likely the magnetron is done and a new microwave is the way to go.
Benjamin
Aug 18, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Food will not heat everything else is working
If it does not heat, with all other functions working, the problem lies with the magnetron circuit. The magnetron is the part that makes the microwaves to heat the food. Typically, the magnetron fails and shorts out. Symptoms when this occurs is a loud hum from the oven and does not heat the food. The replacement magnetron costs are close to the price of a new microwave oven, so it rarely pays to have it fixed.
Feb 16, 2010 | Goldstar Microwave Ovens
Microwave still runs but is not cooking food
Sounds like a bad magnetron, i would replace the magnetron, Capacitor and Diode at the mag assembly, to be honest it will cost you more to fix than a new one.............
Sep 10, 2009 | Magic Chef CMV1000B Microwave Oven
Whirlpool mircowave will not heat
HI, the high voltage capacitor is unstable and, it has damaged the Magnetron. you will need to replace the Magnetron. it will run you about $191.30. this will restore the heating action in your microwave unit.
May 27, 2009 | Whirlpool MH6130XEB/Q Microwave Oven
Convection function not heating from underneath
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
May 19, 2009 | Daewoo KOC-925T Microwave Oven
Everything appears to work fine but it is not heating anymore.
If the microwave oven appears to be working but it is not heating the food, it is very possible that the magnetron, or its power supply has failed.
Jerry G.
May 03, 2009 | Hotpoint RVM1435 Microwave Oven
Microwave doesn't heat food anymore
Benjamin
Apr 21, 2009 | Frigidaire PLMV168 Microwave Oven
Microwave doesnt heat food
Microwave not heating problems are the result of one or more of the following problems -
1) Bad fuse
2) Bad diode
3) Bad capacitor
4) Bad transformer
5) Bad magnetron.
You would need to have special equipment to test the 2nd, 3rd, and 5th items.
Reply back of any other questions/help you may need.
Feb 03, 2009 | Whirlpool GH8155XM Microwave Oven
Amana Radarange Microwave Oven Logo
129 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Steven Clarke
Steven Clarke
foster_mommy
Level 1 Expert
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
