Question about Proform Crosswalk 500 Treadmill
Even while on manual setting the speed automatically goes up and down, how can i fix this? For instance, I set the speed to 2 and it jumps up to 4.2 for a few seconds, goes down to 1.9, back up to 3.xx, etc, and finally settles somewhere around 2ish. The product is Proform Crosswalk Advanced 525x, but that was not a selectable option in your drop down list.
    President:
  • Proform Master
  • 832 Answers
1. You may have a belt and deck problem. Test by the following procedure: a) without the power on stand on the walking belt b) push the belt in the direction it normally turns c) if the belt is very difficult to turn (on most treadmill) this means that you have high belt/deck friction these parts will probably need replacement. On occasion, you may have already damaged the DC board if you have high belt/deck friction. If the belt walks freely, you have a different problem. 2. If it passes the belt/deck checks, you may have a DC board output problem. If the belt tests ok and you have a speed variation, try this test: a) Set the speed to 2.5 MPH. Let the treadmill run without anyone on the belt. Check to see if the speed is constant or if there is a variation. b) If there is no variation, step on the belt. If the speed slows down or speeds up, you may have an output problem on the DC board. This is the board that connects directly to the motor. 3. You may have a short in the motor. If you turn the machine on and have erratic speed, you could have a problem in the DC board or the motor or both. With a simple multi-meter, you can test on the continuity scale to see if you have a closed circuit between either DC motor lead and the common earth ground. You should always have an open circuit. 4. You may have a speed signal problem. Your controls on the upper panel send a signal to the lower electronics to help them set the appropriate speed. If there is a problem in the signal generator, the communication links, or in the feedback links, you will have erratic speed operation. a) Communications test- Look on the board for a flashing signal as you increase speed on the treadmill. Most boards have a signal feedback test light. If a LED flashes, your communication is ok. b) Feedback test- If your unit is equipped with an optical feedback (disk inside a sensor) you can swap the feedback unit with the incline (it is the same part on many Icon machines). If it tests ok, you don’t have a problem here. If it is a magnetic feedback unit, you can test continuity with a multi meter or replace with a new part to test. Many times passing a kitchen magnet in front of the signal will make a speed display on the console if the magnetic sensor is good.
Posted on Jul 19, 2010
    New Friend:
I have a Proform 625 that was doing the same thing. It was a speed calibration issue. When I ran the calibration, the max speed went to 11.7mph - it was only supposed to be 10mph. All it took to fix was running the calibration and using a Phillips head screwdriver to turn a little yellow screw on the side board under the cover. Directions for calibration were taped under the cover or you can find calibration directions for Proforms online.
Posted on Jan 30, 2013
How do i set the cruise control on my 1994 mercedes c220 elegance automatic
Cruise Control
Any given speed above approximately 22 mph (35 km/h) can be maintained with the cruise control by operating the lever.
-see photo
  1. Accelerate and set: Lift lever briefly to set speed. Hold lever up to accelerate.
  2. Decelerate and set:
    Depress lever briefly to set speed. Hold lever down to decelerate.
    Normally the vehicle is accelerated to the desired speed with the accelerator. Speed is set by briefly pushing
    the lever to position 1 or 2. The accelerator can be released. The speed can be increased (e.g. for passing)
    by using the accelerator. As soon as the accelerator is released, the previously set speed will be resumed automatically. If a set speed is to be increased or decreased slightly, e.g. to adapt to the traffic flow, hold lever in position 1 or 2 until the desired speed is reached, or briefly tip the control lever in the appropriate direction for increases or decreases in 0.6 mph (1 km/h) increments. When the lever is released, the newly set speed remains.
  3. Canceling
To cancel the cruise control, briefly push lever to position 3.
When you step on the brake or the vehicle speed drops below approx. 22 rnph (35 km/h), for example when driving upgrade, the cruise control will be canceled.
4. Resume
If the lever is briefly pushed to position 4 when driving at a speed exceeding approx. 22 mph (35 km/h), the vehicle resumes the speed which was set prior to the cancellation of the cruise control. The last memorized speed is canceled when the key in the steering lock is turned to position 1 or 0.
Note:
If the engine does not brake the vehicle sufficiently while driving on a downgrade, the speed you set on the cruise control may be exceeded and you may have to step on the brake pedal to slow down.
As soon as the grade eases, the cruise controlled speed will again be maintained as long as the brakes were not previously applied, or the lever may be used to resume the previously set speed if the brakes were applied.
http://www.benzworld.org/forums/attachments/w202-c36-c43/153145d1197313761-pdf-owners-manual-w202-1995-2000-1999-c280_owners_manual.pdf
Feb 14, 2015 | Mercedes-Benz C-Class Cars & Trucks
What is the difference between automatic ac and manual ac
manual AC you set fan speed etc, auto you just set the temp where you want it and the fan will automatically adjust it's speed to maintain the temp you selected, it also automatically goes from recirculate to fresh air.
Oct 10, 2011 | 2003 Chevrolet Impala
I have a model 31420E skyscan & have lost the instruction manual. Also I live in Sydney Australia and don't know anywhere here to get help.
I couldn't find the manufacturers' web site but I found the following , which may help;-
The unit automatically receives the time signal everyday at midnight and makes any required adjustment to the time displayed.
The WAVE OK indicator and the Tower Icon on the display will show if the time signal is successfully received or after manually pressing the SET/WAVE button
You can trigger a Signal Receive operation at any time by pressing the SET/WAVE button, which will activate the Signal Search function of the unit.
To Manually Set the Clock
To Set the Year and Date
1. Press SET/WAVE button after setting TIME ZONE and DST
2. Press + or - button sequentially to set the year (holding down the button will change the year at a high speed)
3. Press SET/WAVE button to confirm the year set and start the date process
4. Press + or - button sequentially to set the current date (holding down the button will change the date at a high speed)
NOTE: The weekday changes automatically depending on the year and date
To Set the Time
1. Press the SET/WAVE button after setting the calendar
2. Press + or - button sequentially to set the minutes (holding down the button will change the year at a high speed)
NOTE: Once you the press + or - button, the seconds will reset to 00
To set the 12/24 HR mode and the Temperature Mode
1. Press SET/WAVE button after setting the time
2. Press the + button to toggle between between 12HR and 24HR (military) modes
3. Press the - button to toggle between C and F temperature display mode
4. Press SET/WAVE button to confirm and quit the set mode
Dec 20, 2010 | Watches
Air conditioner goes off when fan speed is increased
when it's on 'auto', the fan adjusts according to the temp in the car and the temp setting you have it set at. try setting the auto temp control down to 65, then hit the "-" one more time to send it to "LO" - the fan should automatically jump up to max.
Jul 01, 2010 | 2001 Audi A4
I have a proform 785..the problem is the speed and incline decreases all of a sudden like within a minute...i raised the speed to 4 and it dropped to 2 within 1 min and same thing with the incline it...
Unplug unit remove motor shroud then start calibration procedure.
Press the Stop and the Speed Up keys down while inserting the safety key. If you cannot get into calibration then upper console needs to be replaced.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. At this point if it show 2F FF or Fail then upper console needs to be replaced.
Press either incline key and the incline will calibrate automatically
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON WALKING BELT.
Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled.
The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments.
It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure.
After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing.
Press the Stop key once and remove the safety key.
Jun 11, 2010 | Proform 785 CS Personal Trainer Treadmill
Installing
1. if your internet service provider did not provide these to you, they would stay blank. (most cable broadband internet would have these blank, for instance)
2. because you havent entered any dns entries. more importantly, most of the time what is more important is that you router is set to obtain dns from your ISP (service provider) if that is set correctly, its ok that they are all 0's
3. whether or not your connection should be set to the automatic type can only be answered by your service provider, most cable and some DSL broadband would be set to automatic, some DSL will be set to PPPOE, which will require the username and password given to you from your ISP. If they did not give you one, most likely this would be set to automatic.
4. DHCP server functions is what allows your individual computers in your home to share the internet if you have more than one machine. even if you do have just one machine, it should still be set to automatic.
5. The router name is for your reference, so you should name it something that is meaningful to you.
Mar 21, 2009 | ASUS (wl500g) Wireless Router
Car window doesn't go down automaticly
first i would check the owners manual to see if that can be changed with user input. if not then your module might need to be reprogrammed. those settings are stored in the body control module, if the battery went dead the module probably lost the settings and reverted to default settings. you can have your local GM dealer check that for you.
Feb 20, 2009 | 1998 Cadillac Eldorado
Return to full auto setting
To set the camera to shoot fully automatically (camera selects f-stop, shutter speed, exposure, etc), turn to Mode Dial to the green rectangle icon, right next to the "P" on the dial.
To reset all settings to their original default settings, the procedures are on page 100 in the manual.
1. Press the Menu button and use the Jump button to go to the Setup 2 menu (far right).
2. Use the arrow keys to scroll to "Clear Settings" and press the Set button.
3. Scroll to "Clear all camera settings" and press the Set button.
4. Scroll to "OK" and press the Set button.
Sep 18, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Bandwidth speed always scales down to 24mbps
First Contact your Internet Srevice Provider and ask them your same question. They may have some System Maintenance going on.
Sep 21, 2007 | NetGear WGR614 Wireless Router
Proform Crosswalk 500 Treadmill Logo
804 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
