Question about G3 Targa Telemark Binding
The tour throws on my targas drop off my heel pretty often when they are flipped down into tour-mode. I have tried to adjust them to where they stay put for the uptrack while skinning but then they are too tight to flip up into ski-mode. I have heard of people running the throws on top of the heel block instead of the groove but that does not seem very secure as a way to fix the problem. Please advise. Thanks
Where will I get a classic collection of high heels?
High heels give a stylish look to my overall physical appearance. Nothing can look hotter with a mini-fitting skirt than high heeled boots. An open toe sandal with a two-inch heel looks quite decent with a Chudidaar. I feel that in addition to style it also gives a lot of attention. It also adds style to the way I walk. I went to the Gold Heels store last time to purchase a pair of heels and I found that they have a pretty good collection of heels. I have visited many other stores as well, So I found many varieties of design and also the availability of many rare shades here!. So if you are looking for the best store to find some cool heel collections, I would suggest you try it out!. You might find the pair of heels that you were looking for, from here!.
Dec 09, 2017 | Clothing Accessories
Binding adjustment
There is (should be) a screw visible on each of the toe and heel pieces when looking down from directly above. That screw will adjust the height of the piece that clamps down on the top of the tabs on the heel and toe of your ski boots. For proper height measurement, use a credit card (or similar thickness card) and make sure you can somewhat freely slide the card side-to-side under your boot when it is in the binding and clamped down as when you are skiing. Too much play, and you will feel a sloppyness while skiing. Too little and you risk the binding not releasing properly caused by stiction. You can find demonstrations on YouTube also.
Apr 04, 2014 | Fischer Skis Fischer RC4 Z 17 Freeflex...
Heel of shoe is worn out of both shoes,bought them march 2011 adidas tour 360 size 11. they are my sons who is fifteen and golfs a lot.
The heel can be replaced at a shoe repair shop. The golf course can tell you where they can be fixed. Not all have the parts needed to fix these.
May 22, 2011 | Adidas Tour 360 LTD Golf Shoes
NEED HELP SETTING VOICEMAIL.TRACKBALL IS STUCK, GOES LEFT,RIGHT,& DOWN,NO UP.NEED INSTRUCTION MANUAL.
You can download the user manual (as well as other guides) here:
http://docs.blackberry.com/en/smartphone_users/subcategories/?userType=1&category=BlackBerry+Smartphones&subCategory=BlackBerry+Tour+9600+Series
If the trackball won't go in one direction, try putting one drop of denatured alcohol onto the trackball and then moving it all around, that should fix it. If it doesn't, lift the trackball up slightly -- very gently -- with the blade of a small pocket knife and blow compressed air underneath it.
Jan 22, 2011 | RIM BlackBerry? Tour 9630 Smartphone
Where can i find an instructional booklet for these bindings? i need the instructions to adjust settings on them..
The bindings are all pretty standard. If you a little confused just take them into your local snowboard shop and they will walk you through it.
Apr 02, 2010 | Targa Rome Snowboard Bindings
Have Rome Shift bindings and the one insert/nut popped off at bottom that holds the Upright on. How do you fix it?
Do you still have the nut/piece that came off? If im not mistake the shift has a cover piece that hides the bolt/pivot point for the highback. It should be a noticeable piece on either side of the heel hoop
Feb 10, 2010 | Targa Rome Snowboard Bindings
1997 Dodge Ram 4x4 1500 transmission shifting problems.
good day, you may try replacing your automatic transmission fluid, a good run will be noticeable, hope this helps, have a nice day
Feb 08, 2010 | Dodge Ram 1500 Cars & Trucks
Open roof cars
get a honda or toyota,.......
Jul 06, 2009 | 1985 Toyota Cressida
G3 Targa Telemark Binding Logo
1,134 people viewed this question
Top G3 Rock & Ice Climbing Experts
Betty L Kidd
Betty L Kidd
ray gallant
Are you a G3 Rock and Ice Climbing Expert? Answer questions, earn points and help others
