Question about Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook
Dell Inspiron 6000 laptop (windows/xp sp3) No boot sector on internal hard drive
  • 734 Answers
Hi There,
Probably the easiest way to repair/replace the boot sector is using an XP install Disk. You need to insert the disk, restart the computer, and begin pressing the F12 Key during Bootup. You should be given a Boot Menu. Select your CD/DVD drive as the drive to boot from. Let windows XP do its setup and you will halt at a screen that gives you a chance to Press R for repair. Press R. You will be in DOS mode with a cursor blinking. Type FIXBOOT and press the enter key. Follow the propmpts.
If this does not fix your boot sector, go through the same whole process again but at the cursor type in FIXMBR and hit the entr key. This is to repair the Master Boot Record.
If neither of these tools get you booted back into Windows, then you could have any one of a number of other issues, It would be difficult to address them all in this forum.
I don't wish to be a doomsayer, but an Inspiron 6000 could easily be 5 years old, the same as the expected normal life of a hard drive.
Best of Luck.
TheSelkie
Posted on Jul 19, 2010
I installed a new internal hard drive in my Inspiron 1750 laptop. I am getting a No boot sector on internal hard drive error. How do I get it to boot up and get recognized?
Have you installed the Windows OS on the new HDD? Insert the new Windows OS in the DVD rom drive, shut down, Unplug, remove battery, plug in, at boot the new OS DVD should start and ask Press any key to boot from CD/DVD, tap key.
Feb 03, 2013 | Dell Inspiron 1750 Laptop
My dell inspiron 6000 wont boot up. error message Windows\system32\config\system is missing or corrupt
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Oct 26, 2010 | Dell Inspiron 6000 Notebook
No boot sector on internal hard drive. No bootable
A boot sector is a sector of a hard disk that contains booting programs stored in the other part of the hard disk. You boot sector might have been deleted or corrupted and you can't logon until you repair or recover the boot sector. To do this you must have your OS cd. Boot from OS cd the follow below steps...
Windows Vista
1. Insert the installation disc.
2. Restart your computer
3. If prompted, press any key to start Windows from the installation disc.
4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
7.
On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Boot from you hard disk then you're done!
Regards,
Jeep Brainy
Jul 29, 2009 | Dell Inspiron 6000 Notebook
INSPIRON 6000 on start up says no boot sector on internal hard drive.
Mickey it sounds like, the system files are corrupted on the hard drive. If you have the disks, I think they are the operating system and the drivers and utilities cd. You would install the operating system cd first and then when that is all done then go ahead and install the drivers and utilities.
If you can't get the operating system to install then the hard drive is bad and would need to be replaced.
Jul 08, 2009 | Dell Inspiron 6000 Notebook
I have just rep[laced my hard drive on my laptop (dell inspiron 6000) and have a no boot sector on internal hard drive / no bootable devices on the screen. what do i do next to fix this?
You need to run your installation/restore CD/DVD that came with the Dell. If you do not have them, you can order them from Dell for a nominal amount.
Jun 29, 2009 | Dell Inspiron 6000 Notebook
No boot sector on internal hard drive no bootable device-f2 for setup utility
If the bios or setup utility can't detect your hard drive then this can be a physical problem. I suggest that you reseat or tighten the cable connecting your hard drive to the motherboard. You need to open the hard drive panel then unplug and replug the hard drive cable.
Jun 10, 2009 | Dell Inspiron 6000 Notebook
No boot sectgor on internal hard drive
This is related to the boot sector file.So it wont work in the safemode also.Try and see that the hdd is detected in the system.If yes,then try booting thru th XP disc and run a repair
Mar 18, 2009 | Dell Inspiron 6000 Notebook
I bought a new hard drive, when i install in my pc there is no boot sector on internal hard drive, could you help me please.
If you use the Operating system disk and boot from cd,When you install,it will create the boot sector.
Jan 06, 2009 | Dell Inspiron 6000 Notebook
"no boot sector on internal hard drive"
i think you need to re-install your Operating System again since you got a new HDD wich is tottaly empty i assume so try to install your OS on the new HDD
let me know if it helped
greetings
Jan 02, 2009 | Dell Inspiron 6000 Notebook
Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook Logo
201 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
