Question about Jandy AquaLink RS OneTouch RS8 Pool or Spa Only (Pump Heater + 8 Aux) RSP8 ()
We had an intense thunder storm and lightening the other night. My indoor Aqualink RS8 has a blank screen and is unresponsive. It apparently is not getting any power. The Spalink controller is blinking with the top row of buttons blinking on/off and non-responsive to pressing any of the buttons. The main power panel appears to be working all right and all the button selections work in the Service mode. When in Auto mode, the system still comes on and off as with the original programing times, even without the Aqualink RS 8 being active. I've shut the system down, restarted without the battery in. Check the battery and voltage reading on the 4 pin connectors (Red & Green) all are reading to specs per the Troubleshooting Guide from Jandy. I also have a AquaRite Clorinator and have checked the wiring to the main power panel. The 4 pin connector also appears to be okay, along with the correct voltage reading. Does anyone have an idea why I might have a "dead" Aqualink RS8 indoor panel and flashing Spalink panel? What tests or steps might I do next to identify the problem and if I can fix it myself??? I would appreciate any help
  • David Hilton Jul 19, 2010
Click on this link below to contact the Jandy company and to view the owners manual
http://www.jandy-downloads.com/pdfs/OneTouch_Manual.pdf
http://www.jandy.com/html/products/controls/wireless.php
Posted on Jul 24, 2010
  • 3,083 Answers
First of all, we can assume the lightning damaged at least the Aqualink RS8 panel. The flashing Spalink panel is possibly ok, since it's blinking, and that could be because it's not detecting the Aqualink. It's hard to troubleshoot a system like this without good substitution parts, since that's what a repairman would do to pinpoint the bad unit, and then they would simply replace it. I would replace the Aqualink first, then go from there- that's the most logical way to troubleshoot this system. Good luck, and hope this helps.
Posted on Jul 19, 2010
    tbreeze47 - Thanks for your reply. Are there any tests that I can do to check the integrity of the All Touch Aqualink board? Obviously, I'd like to save some money, if possible, by fixing what can be fixed without just replacing parts. Thanks in advance for your help.
    Regards,
    Dave Hilton
  • 2,272 Answers
The circuit internally have gone short.There are many other facing this same problem.Some have got this indoor panel dead due to moisture collected on the indoor panels circuit board.The panel is not very strong to handle the humidity effect.It gets short. It has to be replaced. To get any other part and also the indoor panel board please click on the link below http://poolparts2u.com/products.asp?catid=0&scatid=27 ------ Thanks.
I purchased a home a little more than a month ago that has an Aqualink RS8 system installed. A couple weeks ago, we noticed that in the indoor control panel was not lit, so we checked the outside panel. ...
open the aqualink control box remove the top panel see if the 4 pin red connector is plugged in and tight if it is check to see if the one inside is connected if ok check to see if wiring is cut
Sep 27, 2014 | Jandy Aqualink All Button RS Control...
Erase a program jandy aqualink rs8
set up then to program highlight program and delete
Aug 04, 2013 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
I want to know how to cancel a program on an AquaLink RS8
go into system setup find program then delete the one you dont want if using a all button just press cancel
Jul 15, 2012 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Jandy pool installation for RS8
1 check to see when you change from pool to spa the acuators are moving if not turn on or make sure wires not cut if not give me more info 2 make sure landscaping is on aux that is plugged in to relay if you need more info email me
Jun 21, 2012 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Jandy aqualink rs8 need manual
go to jandy website they have them in PDa form
Apr 02, 2012 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
The fuse on my circuit board keeps blowing after a thunder storm. Need to replace the entire circuit board for my RS8 system. Any sugestions on where I can purchase just the circuit board? Mike
unplug all the aux plugs but mark them replace fuse turn on if it still blows need a new board if not plug in auxs 1 at a time till it pops then check out that aux for shorts sometimes the relays short out
Mar 17, 2011 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
AquaLink RS8 switchs itself from Pool to Spa pump
make sure no programs if ok remove spa side remote plug if ok then replace spa side remote istill does it reset board but before write down all auxs and jvas
Mar 15, 2010 | Jandy AQUALINK RS TELELINK KIT
Jandy AquaLink RS OneTouch RS8 Pool or Spa Only (Pump Heater + 8 Aux)  RSP8 () Logo
655 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Craig Butler
Craig Butler
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
