Question about Vacuums
How do you replace the belt on the Kirby, Model No D50, Serial No. A442867
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Generic problem for all Vacuums
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
This is an older Kirby vacuum and the front brushroll section of the vacuum and the front brushroll section will come off, 1st you have to remove the front cover (the Kirby Emblem) and under that there is a Kirby spoon or hook and you need to dial off the belt off the belt shaft, once that has been done remove the bottom plate and un-install the Kirby brushroll, check to see if the brushroll spins freely, if it does go onto the next step, if not clean off the hair and thread from either end and then re-check the brushroll, if it still binds up then replace the brushroll and belt with Genuine Kirby belt and brush. Then use the dial to place the belt onto the Kirby spoon / hook. Once the belt is on the hook, install the bottom planter and place then housing of the Kirby on the vacuum and use the lever on the top to secure the fan housing dial the belt onto the pulley and you should be good to go.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Don – The Vac Man
Posted on Apr 21, 2008
My Kirby isn't picking up everything. The roller does spin.
If your model has the indicator light make sure it glows bright when the brush roll is spinning. If it isn't as bright or flickers when vacuuming the carpets replace the belt. Be sure to replace belt at least once per year.
Mar 07, 2017 | Kirby Vacuums
How do I replace a belt in my classic iii kirby vacuum cleaner
The below link leads to an excellent video on replacing the belt. It's for a newer model, but I believe they're pretty much the same.
http://www.kirby.com/Portals/0/videos.html
Jan 15, 2011 | Kirby G4 Bagged Upright Vacuum
How can i get a manuel . I don't know how to hook up the parts for the shampooer to clean carpet . Need ASAP.Kirby vacuum model #293001 serial G.
I haven't been able to locate Kirby manuals, but they do have good instruction videos for hooking up the shampooer, changing the belt, etc. Just click on the video you need.
Oct 08, 2010 | Vacuums
My belt broke on my kirby G-5. I havent put a belt on it in 10 years. I having problems getting it on.Can u tell me the right way? Thank you.
Greetings,
I recorded a video repair of replacing the belt for the Kirby generation vacuum cleaner. The following video will walk you through step by step on how to replace your Kirby belt, as well as doing some basic maintenance to the roller brush to prolong the life of your belt as long as possible.
How to Replace the belt on a Kirby Ultimate G Vacuum Cleaner;
I hope that this video was helpful to you in repairing your Kirby. If you found the video to be helpful, please kindly rate the video helpful by clicking on the Thumbs Up Icon below.
Thanks for watching!
Chris J.
Nov 21, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How to change g5 belt
1)First, you turn the square belt lifter on the front of the power nozzle until the red arrows line up (belt off)
2)Remove the power head from the front of the machine. Now turn the belt lifter the other way and line the green arrows up again. This releases the tension on the belt
3)Turn it upside down and release the two clips that hold the metal baseplate on and remove the baseplate.
4)Grab the brushroll and pull it out of the power head. Slide the new belt onto the center of the brushroll. It will hang loose...it doesn't have to stretch around anything yet. MAKE SURE THAT THE BRUSHROLL SPINS FREELY!! If it doesn't, you'll burn all new belts quickly due to the added strain on the belt.
You can get a replacement belt here:
Kirby G5 Replacement Belt
Nov 02, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby g4 brush wont turn belt ok
your belt has probably been stretched to the point where it will not work so good.
Jul 02, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How do you attach the belt for the roller-brush on a Kirby Generation 3, up-right vacuum-cleaner?
Greetings,
Please see the attached video on how to replace the belt on a Kirby Generation Vacuum Cleaner. This is an easy to follow step by step direction on the proper way to replace the belt, as well as do basic maintenance on your Kirby's roller brush which will prolong the life of your belt greatly if done regularly. I you find this video to be helpful, please be kind and rate it well by clicking the thumbs up icon below.
Feel free to request a repair clarification if you have any quesitons on how to replace the belt on your Kirby.
How to Replace the Belt on a Kirby Generation 3 (G3) Vacuum Cleaner:
Chris J.
Jun 14, 2009 | Kirby Generation 3 Bagged Upright Vacuum
REPLACING BELT KIRBY CLASSIC III
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11562&thid=806061
Posted by JETALBOT on July 19, 2008
I CAN'T REPLACE THE BELT ON THE CLASSIC III (KIRBY). CAN YOU HELP ME? ELAINE
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The belt install on a Kirby is to raise the height adjustment to the highest level and then dial the belt off counter clockwise so it is loose and not on the fan pulley, release the top lever on the bell housing, then remove the bottom plate and unhook the brushroll on one side, slide the old belt off and then slide the new one on, replace the brushroll with the screws facing the carpet and re-hook the bottom plate on the Kirby. Then take the bell housing and hook that back on to the Kirby and lock it down. Then dial the belt on clockwise all the way and the belt should be on the fan pulley. The belt should be ready to go, plug in your Kirby and then do the step down on the vacuum height adjustment until the tone changes, then try to see id it picks up, if not go one more height adjustment and that should be the correct setting.
http://kirby.com/
Customer Service – U. S. & Canada
1-800-494-8586
Hours 8:00 am to 5:00 pm (EST)
Mail To: Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 19, 2008 | Kirby Heritage II Vacuum
Belt
I don't know where near you, but most local repair shops should have the belts for kirby.
Jun 18, 2008 | Kirby Generation 3 Bagged Upright Vacuum
How do i put a belt on my kirby vaccum
here is a link to a site with step by step instructions for replacing a belt on any G series kirby...it also works for the new model.
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps! :)
Feb 24, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
106 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
