Question about GE WCVH6260FWW
You start the washer, the door locks, unlocks,
M/n: WCVH6260FWW s/n: GL204472T
You load the washer,. hit "star", the door locks, unlocks, relocks, tumbles the clothes back & forth, seems to fill with at least a little water, (up to this point it all appears normal), but then that's it! It just sits there, doesn't do any washing. The door later will unlock, but that's it. Any help would be greatly appreciated!!
I am mechanically inclined, so if there are things I need to check, voltage wise or whatever, feel free to let me know. Thx!
  • 641 Answers
SOURCE: GE Front Loader Washer - Not washing
It sound like a lid switch issue. If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Look that the switch is not broken or loose. If all is fine, you should replace the switch. Good luck!
Posted on Aug 27, 2007
SOURCE: GE Adora Front Load Washer
I went to the home depot site and they have various videos that explain about the washer and how it works. This made my understanding more clear as to how the washer works. Thanks!
Posted on Jul 25, 2008
SOURCE: Washer stops at 25min remaining and unlocks then relocks the door
I had to call a repairman for the same problem. Your pump is clogged with lint and debris so the water will not drain or slowly drains. There is a sensor that will stop the cycle if the water is not draining. Open the bottom panel at the front of the machine. (there are 2 or 3 screws) Then on the center right there is circle thing (about 2 inches in diameter) ** Important** place a small flat pan, etc underneath the opening and unscrew the cover. Water and other misc. junk will come out. Reassemble everything and you are set.
Why they don't provide this information in the manual I do not know. Easy repair for a common problem.
Posted on Jun 09, 2009
  • 574 Answers
SOURCE: I have a front loading GE wcvh6260fww that will
probably a bad door switch, if you can take the door or top off and find the wires running to the switch take the wires off theswitch and plug them together by wrapping electrical tape around them and then try the washer. If that dont work may be a bad control board
Posted on Sep 03, 2009
  • 6277 Answers
SOURCE: My GE front load washer
This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 04, 2011
I have a GE Front Load Washing Machine, Model Number WBVH5300. When I turn it on to any cycle, the door locks, the basket turns to balance the load, the door unlocks, relocks and begins to drain. There...
Hello & Welcome to FixYa
If the drain hose is positioned correctly and the door lock assembly is fine then the problem is either the drain pump that is bad and needs replacement or the drain pump relay on the control board is bad and replacing the board will be recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 14, 2011 | General Electric WBVH5300KW Washer
The door is locked. How do I get it open?
turn washer off then start new cycle and before it gets the chance to start, hit cancel and it should unlock the door
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer doesn't unlock the door at the
Hi There
I have found this for you to read. it's door unlock error. Hope this helpful and let me know how it goes.
F/dU Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I hit the unlock feature and my car relocks if i dont insert key within 30 seconds
thats a system to stop accidental unlocking of your car so if you dont open the door after unlocking it .....it locks itself if you just open the door once it wont lock itself again till you lock and unlock it
Oct 26, 2009 | 2004 Chevrolet Impala
GE wcvh6260fww front load washer won't start. pump makes a noise. The trap had some stuff in it. Cleaned that out. Cleaned the hose behind it out.Still just makes a noise at the pump when I turn it back...
need to check hose that comes off the bottom of the outer tub to pump. if there is trash still in the rubber hose then pump thinks it still needs to pump out.
Jun 20, 2009 | GE WSXH208A Front Load Washer
GE WCVH6260 stops unexpectantly
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped.
Check your drain with a good pour of water from a bucket, it must clear fast. It it doesn't snake it out; the prob lies there 99%. And don't push your exit hose too deep into the standpipe, 4 to 5 inches & not air tight.
Nov 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star WBVH5200 Front Load Washer
My GE Energy Star Front Load Washer is reading 5.9 instead of 59 minutes and not washing clothes. We cleaned the filter and still no luck. Please help.
Jul 30, 2008 | GE Energy Star WCVH6260F Front Load Washer
Cleaned filter, washer still won't run
WasherMama,
I think they all start out that way - sort of a self diagnostic check on all its functions (lock, turn one way, turn the other, unlock) before it actually starts washing. After I wait a moment (or longer) it relocks the door and only then does the water start to run and the cycle begin.
I hope I'm not just stating the obvious.
Jun 10, 2008 | GE WBVH6240F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE WCVH6260FWW Logo
126 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
