Philips projection tv
Have a philips projection tv model # 55p8341a. has an orange picture than cannot be adjusted. Where can i start to fix the problem?
  • 8,617 Answers
Sounds like the red CRT is defective. But could be the red drive circuit also. If you turn the color level to zero is the picture red or black and white. If the red/orange is still there i would suggest its the red CRT. I have a source for Phillips CRTs that cost 135.00 with free shipping. If you end up needing one let me know and I will post the link.
Posted on Apr 21, 2008
Philips model #50P8341A Picture is clear but orange.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 12, 2011 | Philips 50P8341 50" Rear Projection...
Philips 50P8341 50 in. Rear Projection Television
normally when something like this happens, we could right away propose what can be done, in your case, since youve already changed a lot of parts on that tv, you can at anytime fix it. the tv alone is not fixed yet as of the moment but to some it up, experts have already given you some ideas on how to fix the tv. cheers. hope youll fix that tv in no time.
Mar 12, 2008 | Philips 50P8341 50" Rear Projection...
How can i fix my tv when the color scheme is unbalanced.
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 16, 2011 | Philips 60PP9202 60" Rear Projection...
All of the people are red and I have no blues and green
This is a fluid problem...in the lens...
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 28, 2010 | Philips 55PW9363 55" Rear Projection...
Picture is doubled and multi-color
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 20, 2009 | Philips 55PP9363 55" Rear Projection...
60" Philips Magnavox Projection TV Red Screen
be able to help more if you post model# and chassis.........meder's tv
May 19, 2009 | Philips Televison & Video
sounds like your cooling fluids in the tubes needs to be changed. Repairman told me it was common on the philips.
Sep 09, 2008 | Philips Magnavox 9P6034C 60" Rear...
Pillips projection tv
I HAVE A PHILIPS M#55P8341A THERE IS DOUBLE PICTURE ON THE SCREEN IF YOU HAVE ONE PERSON THERE YOU SEE TWO OF THEM ONE IS RED THE OTHER IS GREEN?
Jul 09, 2008 | Philips 55P8341 55" Rear Projection...
Philips model 50p8341a projection
color is off. Faces are orange sometimes, all orange, or red? Tried the remote to fix however did not work.
Nov 22, 2007 | Philips 60P8341 60" Rear Projection...
Tv randomly shuts off
Replace power relays on power board...
Bill
Oct 08, 2007 | Philips 55PP9401 55" Rear Projection...
Televison & Video Logo
343 people viewed this question
Top Televison & Video Experts
Electro Med Services...
